Old 10-19-2005, 06:06 PM   #1
tweakling
Member#: 33072
'95 EJ20g v1 STI RA
BRP, 2001 GC8 chassis
Default Exhaust recommendations for a JDM EJ20G in a GC8?
I'm currently in the process of dropping the motor and full drivetrain from a '95 ver. 2 STI RA into my '01 RS, and I've decided that I'm going to need a bigger exhaust (I'm considering upgrading the up/down pipes as well). The only problem is I don't know what aftermarket parts are compatible. I've searched around the forums a bit, but I must not be using the right key-words since I haven't found anything that addresses this specifically. Any suggestions/recommendations/general information would be *highly* appreciated.
Thanks!
-Rob
tweakling is offline   Reply With Quote
Old 10-19-2005, 06:26 PM   #2
subbyspeed
Member#: 16274
2001 GM6 2.0L vf30
e30 black/rust
I've got a usdm swap.. I'm pretty sure the dimensions and what not are the same for yours.. But if thats the case, any wrx exhaust stuff will work. The only difference on the wrx exhaust on a GC chassis is the back muffler hanger back by the differential won't work.. But you don't need it.. Get some kartboy or sti exhaust hangers, and it won't move at all.
subbyspeed is offline   Reply With Quote
Old 10-19-2005, 06:36 PM   #3
andys
Member#: 53455
2004 Forester XTI-RR
dark
2.5 inch straight pipe after the down pipe. cheap and good and it's not really that loud. I have it. I like it.
andys is offline   Reply With Quote
Old 10-19-2005, 06:45 PM   #4
Matt Monson
Member#: 832
99 2.5RS, '85 911
'73 914 and 2012 BRZ
Anything for a USDM WRX will work. The world is your oyster. I am personally partial to the Stromung divorced wastegate DP and full exhaust.
On the up-pipe take a close look at yours before you do anything. Early STi's generally had catless uppipes. The gain to be had from an aftermarket on is marginal if you have no cat (which you shouldn't)...
Old 10-19-2005, 10:23 PM   #5
Jaxx
Member#: 177
The 93 W/EJ20K
Series 10 FRS
as matt said get a wrx exhaust
by far the best deal is the 279.00 turbo back that is on ebay there is a thread on it in 2.0
Old 10-20-2005, 03:03 PM   #6
tweakling
Member#: 33072
'95 EJ20g v1 STI RA
Excellent. This certainly opens up my options. Thanks for your responses.
-Rob
need: SMJ foldout page for 94 JDM EJ20G (plug R1) supermoose Subaru Conversions 2 07-03-2015 02:09 PM
purolator pl14460 for 93 jdm ej20g? 93typeRA Pre-2002 Factory Turbo Powertrain 3 08-11-2009 08:55 PM
Need: SMJ foldout page for 94 JDM EJ20G (plug R1) Please! chrisc1991 Subaru Conversions 1 01-20-2009 09:28 AM
contemplating a jdm sti in to gc8 swap. rallyblues Subaru Conversions 8 06-30-2004 04:12 AM
kind of exhaust recommend for 2.2L? yeng Normally Aspirated Powertrain 9 04-29-2004 10:34 PM
