Old 10-19-2005, 10:29 PM   #1
G.Subramaniam
Member#: 64528
Default Anyone blown engines with J&S and or Water Injection
Anyone blown RS-T engines with J&S and or Water Injection
G.Subramaniam is offline   Reply With Quote
Old 10-19-2005, 10:41 PM   #2
ai42
Member#: 71348
1999 EJ207 RS.TI
VW Golf TDI 40mpg baby!
I'm not sure if there are but there is no subsitute for good fuel delivery and engine managment. If you want it to last do it right.
ai42 is offline   Reply With Quote
Old 10-20-2005, 09:33 AM   #3
8Complex
Member#: 922
16 WRX (white)
04 FXT (red)
You can blow a motor with anything.
A J&S will certainly help, though. And water injection, as long as you don't use WAYY too big of a nozzle, works very well as well.
Old 10-20-2005, 11:01 AM   #4
Matt Monson
Member#: 832
99 2.5RS, '85 911
'73 914 and 2012 BRZ
Unless you lower your compression, you are going to blow your engine no matter what EM you run...
Old 10-20-2005, 11:33 AM   #5
8Complex
Member#: 922
16 WRX (white)
04 FXT (red)
Not necessarily true... I could run an RS-T at 4-6psi for years without blowing the motor, so long as it's tuned decently.
Old 10-20-2005, 01:04 PM   #6
Sko
Member#: 90396
2005 Legacy 2.5i
Brilliant Silver Metallic
Tru dat, also once you do blow that stock short block, throw in an STi shortblock and hold on to your pants!
Sko is offline   Reply With Quote
Old 10-20-2005, 01:19 PM   #7
Crawford/I-Speed
Vendor
Member#: 12347
ECU ReProgramming
Dynapack AWD Dyno
We ran Aquamist one summer. It worked great....until the pump failed at a track event, knocked the motor like hell and took out bearings, piston and crank. That inexpensive pump cost us quite a bit in repairs.
Nothing against Aquamist, but we steer away from injection on street or track cars. Drag cars...that's another animal
Chris
I-Speed USA
Crawford/I-Speed is offline   Reply With Quote
Old 10-20-2005, 06:23 PM   #8
Hitokiri
Member#: 2604
1999 2.5RSt
RBP
mine is still holding strong.
J&S and WI here
The J&S doen't see much activity though. I use it mostly as knock detection / safety when tuning
Hitokiri is offline   Reply With Quote
Could methanol or water injection be a replacement for sleeving a 2.5ltr block? tino Water/Methanol Injection, Nitrous & Intercooler Cooling 7 08-05-2005 09:15 PM
U-tec and methanol/water injection on STI modifyd Engine Management & Tuning 4 03-17-2005 09:06 PM
Nitrous or Water Injection??? Spoolin16PSI Water/Methanol Injection, Nitrous & Intercooler Cooling 21 03-04-2004 11:10 AM
Anyone blown their engine with J&S Safeguard installed??? FLaBrit Normally Aspirated with bolt-on Forced Induction Powertrain 9 08-25-2003 10:16 PM
J&S Safegaurd and Aquamist Water Injection replacement killer Water/Methanol Injection, Nitrous & Intercooler Cooling 3 05-30-2002 05:27 AM
