Welcome to the North American Subaru Impreza Owners Club Friday February 12, 2016
Old 10-20-2005, 02:53 PM   #1
wannabejdm
Member#: 82900
2004 Wrx STI
Blue ofcourse
Default wastegate? how does it work?
If i drill a hole into it a catless uppipe(sti) and weld a wastegate(external) onto it? Will it be the same as buying a uppipe already with the hole for a external set up? I was just wondering b/c my firend has a 38 mm external wastegate that he said he would give to me. But would this work if i do this? Wouldnt it be the same if i drilled the hole and welded?
wannabejdm is offline   Reply With Quote
Old 10-20-2005, 03:50 PM   #2
Lachlan
Member#: 19470
1981 Brat GL
I don't see why it would be different--a hole is a hole right? All you're doing is relieving pressure on that side of the turbo.
Lachlan is offline   Reply With Quote
Old 10-20-2005, 04:09 PM   #3
wannabejdm
Member#: 82900
2004 Wrx STI
Blue ofcourse
so you think it will work?
Old 10-20-2005, 04:10 PM   #4
Lachlan
Member#: 19470
1981 Brat GL
You just have to fab the pipe so the wastegate fits on
Old 10-20-2005, 04:41 PM   #5
USF97J4x4
Member#: 83035
Just take the uppipe off. Conserve weight.
USF97J4x4 is offline   Reply With Quote
Old 10-20-2005, 04:48 PM   #6
Lachlan
Member#: 19470
1981 Brat GL
^I know you were trying to be funny, but something went wrong...
Old 10-20-2005, 10:24 PM   #7
wannabejdm
Member#: 82900
2004 Wrx STI
Blue ofcourse
anyone else?
Old 10-20-2005, 11:01 PM   #8
Tats
Member#: 5692
WTF? YES! I am
better than you!
You'd have to mod your up-pipe and down-pipe to use an external wastegate. So it can redirect exhaust flow around the turbo.
You really do not need one unless you have a huge honking turbo and creep issues. You can make big number on an STi with an internally gated turbo upgrade.
Save your time and money.
Oh..BTW...wrong forum.
Tats is offline   Reply With Quote
Old 10-20-2005, 11:09 PM   #9
Lachlan
Member#: 19470
1981 Brat GL
Not necessarily--many turbos have wussy waste gates and when you put on a TBE you get boost creep. You can either port the waste gate, which you can only do so much of, or get an external gate. If you're getting it for free it might be worth it, although you either have to get it to dump into your dp or deal with it dumping into the atmosphere directly.
Old 10-20-2005, 11:24 PM   #10
wannabejdm
Member#: 82900
2004 Wrx STI
Blue ofcourse
i dont care about dumping it into the atmosphere i had a turbo integra like that. i just made a hose and had it leed to the ground.
Old 10-20-2005, 11:27 PM   #11
ai42
Member#: 71348
1999 EJ207 RS.TI
VW Golf TDI 40mpg baby!
Err are you talking about free air wastegate? I've heard a Lancer turbo (non Evo of course) with open air wastegate and that thing is simply sounds like a rocket booster when the boost hits (and the wastegate opens up fully). I agree it should work however.
ai42 is offline   Reply With Quote
Old 10-20-2005, 11:29 PM   #12
ai42
Member#: 71348
1999 EJ207 RS.TI
That better be high temp silicon (which is very expensive) otherwise it will simply melt.
External wastegate uppipe... how does it work? meo Built Motor Discussion 11 10-13-2009 07:36 PM
Turbo-back exhaust...how does it work? Silver_SportTrac Newbies & FAQs 7 02-24-2002 05:02 AM
intercooler...how does it work slapey Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 5 06-12-2001 10:28 AM
RWI on Kumho 712.. how does it work? Prostho Brakes, Steering & Suspension 2 02-24-2001 09:11 PM
Boost cut... How does it work? Shik Legacy Forum 15 07-28-2000 12:11 AM
