Welcome to the North American Subaru Impreza Owners Club Sunday July 31, 2016
Old 10-20-2005, 05:45 PM   #1
kingtut12
Member#: 81123
2002 2.5 WRX BY
RIP 02' 2.5WRX PSM
Default Rough idle and stalling directly related to MAF
Hey guys
As some of you know I 've been having weird issues with idle and low RPM driving, and stalling out at stoplights.
Well, this may not be news to some of you gurus, but I figured out today while I had my UTEC dashboard on, that the MAF % changed when my radiator fan kicked on, AND thats when my car starts acting funny. as soon as the fan turns off, idle goes back to normal. At 1st I though it was just a battery voltage fluctuation from the draw of the fan switching on. BUT... I blew into my intake filter (Perrin BIG MAF) and the car immediately ran rough until I stopped. If I blew hard, it died - everytime.
So, at this point should I shield the Intake filter from radiators fan airflow path or will I be able to adjust my 500-1000 - 0% fuel column?
As far as low RPM driving, I wonder if the fact that I do not have fog covers are allowing more air than necessary into my intake and thats why when i try to take off quickly or start to build speed my car stutters a bit? Any thoughts on this?
kingtut12 is offline   Reply With Quote
Old 10-20-2005, 06:13 PM   #2
ride5000
Member#: 32792
2003 GGA MBP
12.9 / 105+
sounds like a big issue with turbulence.
is the bigmaf an intake/air filter? i thought it was just a maf pipe, but i could certainly be wrong.
Old 10-20-2005, 07:03 PM   #3
kingtut12
Member#: 81123
2002 2.5 WRX BY
RIP 02' 2.5WRX PSM
Well, I suppose the Big Maf part is just the pipe and the filter is a standard foam filter. But it is all sold together.
Explain more on the turbulence issue. BTW, I was fooling around with some sheet metal and made a quick shield to temporarily put between filter and radiator - it worked perfect, never idled rough or stalled out.
But on the other hand, by removing the shield and adding fuel in the 500-1000rpm - 0% load column, it didn't seem to really help much. I was figuring since the MAF was reading more air when the radiator fan kicked on, then it would fool the ECU , thus requiring more fuel. But that did not seem to be the solution...unless I didn't add enough fuel.
Old 10-20-2005, 10:51 PM   #4
cdvma
Member#: 21980
2002 PSM WRX (Sold)
2009 BMW X5
You adding fuel would just be eliminated by the fuel trims. This is very interesting...its probably mis-measuring the amount of air because its getting lots of flow over the sensor that is not consistent throughout the tube. However the chances of that are so low that I believe something else is going on. I'll have to think about this one for a bit.
cdvma is offline   Reply With Quote
Old 10-21-2005, 12:25 AM   #5
kingtut12
Member#: 81123
2002 2.5 WRX BY
RIP 02' 2.5WRX PSM
Yea, It's really odd. I just went out and started the car again and sure enough, if any air whatsover is blown toward or at the intake filter, it chokes it dead. Now, if I rev to 1000 and hold it while the radiator fan kicks on, then it does not die, but it does idle very roughly, and does die as soon as i let off gas. Can someone else humor me and try this? Let me know.
Old 10-21-2005, 10:25 AM   #6
cdvma
Member#: 21980
2002 PSM WRX (Sold)
2009 BMW X5
Can you record a log from the UTEC while you do this? I'm curious as to what happens to the MAF volts. IIRC one of the UTEC logs (1-6) captures MAF volts to two decimal places - use that.
Old 10-21-2005, 05:39 PM   #7
kingtut12
Member#: 81123
2002 2.5 WRX BY
RIP 02' 2.5WRX PSM
Ok - i will do that on Sunday. I will be outta town til then.
VERY Rough Idle then Stall (wanna borrow HKS SSQV) Scoobie2.0 Mid West Subaru Owners Club Forum -- MWSOC 2 10-04-2009 11:13 AM
Rough Idle, occasional stalling...fuel issue? Madmike05STi Newbies & FAQs 18 10-04-2009 09:22 AM
1995 2.2 liter rough idle and an occasional stall stevefazek Normally Aspirated Powertrain 2 09-20-2009 11:16 PM
what to check for irratic idle and stalling? jacky599r Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 14 01-27-2009 01:05 PM
Spark plug=very rough idle and CEL? Bunuel Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 5 07-22-2002 11:59 PM
