Welcome to the North American Subaru Impreza Owners Club Sunday August 30, 2015
Old 10-20-2005, 07:02 PM   #1
psun786
Member#: 93318
04 WRX wagon
Question For those Autometer EGT that not JUMPING~
I bought a sport-comp autometer EGT gauge w/ probe and have it installed by my mechanic. Sometime, the needle would "jumping around" within a range of 300 degrees, specially if the reading is over 800. Also, the gauge reading is a little lower than normal (450 @ idle).
After some research, I believe might be more of a bad grounding point than dead probe (ground w/ dash clock). So, where did you guys ground your autometer EGT? <-- of coz, for those ppl who have properly working EGT.
[NO, this is not under rain nor the car is wet]
psun786 is offline   Reply With Quote
Old 10-20-2005, 08:01 PM   #2
Uncle Scotty
Member#: 16200
OK buy Nates beans
westcoastroasting.com
There really need to be 2 grounds.....the light circuit should be seperate from the gauge circuit and ya gotta have 'NON-dimmed' power for the gauge or ya get funky readings.
....and just where is the probe mounted???? It should be ~750F at idle
Old 10-21-2005, 02:38 PM   #3
Tgui
Member#: 44771
I have a similar thread going concerning an Autometer EGT guage + probe.
How long has your probe been installed?
I plan on pulling my probe tonight to look for any signs of damage.
On the groun issue, I had both the light and guage circuits on the same ground for 6mo w/o any issues (seemingly).
I'll share what I find.
Tgui is offline   Reply With Quote
Old 10-21-2005, 06:22 PM   #4
psun786
Member#: 93318
04 WRX wagon
The probe and gauge are new and the installation was done by a very skillful subaru mechanic (probe tapped in manifold). I checked and re-ground the gauge (not gauge light) to chassis instead of clock. However the needle still "jump around" after 800f degree. the jumping range is around ~300 degree. BTW, my idle EGT is around 500 f with COBB stage 2.
I am not sure if the jumping is the result of a ultra sensitive probe. I have the autometer #5247 probe.
Old 10-21-2005, 06:42 PM   #5
Master2192
RIP 10/12/83 to 02/10/08
Member#: 83254
98 2.5 RS
04 WRX
BTW, where is a good place to place a chassis ground. I installed my Autometer AFR Gauge last night (i know, i wasn't looking at getting an "accurate" reading). And the reading changes when i turn on lights or the HVAC fan.
When i did the install i used the Ground wire off of the cigarette lighter. I think i'm going to drill a hole in the firewall and clean the area and put down a ground wire. Do you think that will be a better ground than the lighter one?
It seems alot more accurate when the lights are off, it swings back and forth and does touch some of the lean lights. With the lights on, it will swing to about 1/2 of stoic and then swing off the gauge and come back. So i definitely think my ground needs a better connection.
Old 10-21-2005, 07:12 PM   #6
psun786
Member#: 93318
04 WRX wagon
many ppl said grounding to chassis will give u a better reading. there are plenty bolts & nuts under the dash to tap for a chassis ground. just open the lower dash panel and look under the steering column.
Old 10-23-2005, 11:01 PM   #7
Master2192
Member#: 83254
98 2.5 RS
04 WRX
I grounded it to the ECU surround. I used a meter and found that to be the strongest ground in the car. The voltage still drops about a 1/4 of a volt when i turn on the lights though. But it doesn't have as much of an effect on the gauge as it did before.
Damn these Cobalt Gauges look nice at night
For those of you that are not working today Matt_H Mid Atlantic Impreza Club -- MAIC 19 12-23-2006 07:07 PM
where can I find an NPT fitting for an Autometer EGT probe? Anyone have an extra? Wagon Joe Electrical & Lighting 0 09-20-2004 05:02 PM
Looking for an Autometer EGT probe chrisdeaner Private 'Wanted' Classifieds 0 08-18-2004 01:25 PM
autometer egt gauge not working. abqkid Electrical & Lighting 1 03-31-2004 11:59 AM
For those of you that removed passenger manifolds for EGT probe install... BeavisNuke Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 12 07-09-2002 03:30 PM
