Old 10-20-2005, 11:39 PM   #1
legacy2003
Member#: 38338
2003 Outback Sdn H6
Default what would i be looking at for power/torque (ballpark) with this setup (hybrid)
i have a 2000 rs currently with an 02 wrx swap in it. well, my block's compression isn't very good anymore, and i can get my hands on an ej22t shortblock for less than $200 (has to be rebuilt), but i figure with the stronger block and slightly more displacement the ej22t seems to be the route to go (i would like to eventually run a 20g or green turbo and jdm ver. 7 heads). so, what i'm wondering is what kind of power i would be looking at out of the ej22t block with 02 wrx heads, everything else being wrx except the block, including stock td04. i'm sure this has probably been covered, but i searched and couldn't come up with any ball-park power figures (let's assume a stock wrx motor vs. this setup stock). any ideas?
what's the legacy turbo rated at stock... isn't it somewhere around 180 crank?
-mike
legacy2003 is offline   Reply With Quote
Old 10-23-2005, 01:24 AM   #2
DamienX
Member#: 66331
160hp and 180 ft/lbs of torque at the crank
DamienX is offline   Reply With Quote
Old 10-24-2005, 01:22 PM   #3
Matt Monson
Member#: 832
99 2.5RS, '85 911
'73 914 and 2012 BRZ
The sky's the limit. Look up Crawford Performance and Axis Power Racing on google and you can see what has been done with that block using WRX heads. They offer several different levels of build. And since you are going to rebuild it anyways, dropping some forged slugs in there to bump the CR a bit is worth the effort...
Old 10-27-2005, 05:36 PM   #4
MrH00nel2
Member#: 80474
2002 Z06
1200whp
if you keep the wrx heads you will be choking yourself. get the v7 heads like you wanted and the green. you will be looking at some nice power. low 12s at least
thats my .02
MrH00nel2 is offline   Reply With Quote
Old 10-29-2005, 09:23 AM   #5
sixpack subaru
Member#: 64974
1995 WRX,APEXi,HKS,$
Faded, Stonechipped Red
Subaru Stars
-mike
I love the way people simplify the trade like that......... would you like a job with me?? quoting power figures on standard parts? So with this std legacy Crank, and this Std WRX Block and these injectors, and this hand and this puilling action....!! AHA!! Lots of LAUGHS
Cheers man, have a good night!!
Sixpack Subaru
sixpack subaru is offline   Reply With Quote
What would i be looking at... wrxnoob10 Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 1 10-19-2009 03:20 AM
Cobb Stage Two... What should I be looking at next? rex_runner Newbies & FAQs 27 02-19-2009 05:21 PM
what kind of power would i be looking at here? legacy2003 Subaru Conversions 1 10-23-2005 04:08 PM
what kind of power would i be looking at here (hybrid build)? legacy2003 Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 3 10-22-2005 09:21 PM
What kind of power/times will I be looking with this setup? BALISTC Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 4 04-08-2003 08:19 PM
