Welcome to the North American Subaru Impreza Owners Club Wednesday September 2, 2015
Go Back   NASIOC > NASIOC Subaru Models > 'Old School' Subaru Forum
Old 10-21-2005, 01:56 AM   #1
totally_clueless
Member#: 99074
Default Need help with 86 GL Wagon Clutch Info
Have a 1986 GL Wagon. Think it's a 1.6 Over 180K miles.
Clutch is about gone. Slips in every gear whenever the car is going up hill at any angle.
My regular mechanic says the clutch cannot be adjusted, and will have to be replaced. And more than that, that it's not an easy job, and will cost a great deal in labor.
True? What are my options? How much should I expect to pay for this work, including parts?
Many thanks!
totally_clueless is offline   Reply With Quote
Old 10-21-2005, 09:56 AM   #2
Calebz
Member#: 54398
1980 CB400 Hawk
1996 GrandCherokeeLimited
Your mechanic is mistaken. the clutch is adjustable. pretty easy to adjust. IIRC, the adjustment nut is 10mm (don't remember for sure, haven't adjusted mine in a while)
Not terribly difficult to replace either.. However, it does involve either dropping the tranny, or moving the motor out of the way.. (either sliding it forward or removing it)
Sounds to me like your mechanic doesn't know anything about subarus and is scared of them.
Calebz is offline   Reply With Quote
Old 10-22-2005, 01:15 AM   #3
Flowmastered87GL
WCSS Drunk
Member#: 8914
2005 Baja Sport
Regal Blue Pearl
What he said. If its slipping maybe try loosening the clutch cable... if that doesnt fix it then its probably too worn.
Flowmastered87GL is offline   Reply With Quote
Old 10-22-2005, 01:23 AM   #4
cocheeze
Member#: 96964
1969 360/1987 gl 4wd
Green/Silver
or your mechanic knows plenty about subarus, and wants to make a buck or two off ya...
Unfortunately, dishonest mechanics are not as uncommon as they should be!
I changed the clutch on my '83 Gl Wagon in about 4 or 5 hours, and I had never done it before...
About two years later, I changed both halfshafts AND the clutch on my girlfriends '89 gl sedan, and that job took me about 5 hours total, including the time it took me to take the old halfshafts down to a machine shop to get the wheel axle assembally pushed off w/ a hydraulic press.
If it takes me that long w/ basic tools and little experience, then a competent mechanic should be able to shave an hour off at least wouldn't you think? With a shop, air tools, other mechanics, most likely a lift, and all the other benefits of being a professional mechanic, I would sure hope so.
Good luck!
cocheeze is offline   Reply With Quote
Old 10-31-2005, 07:53 AM   #5
sixpack subaru
Member#: 64974
1995 WRX,APEXi,HKS,$
Faded, Stonechipped Red
Subaru Stars
Good luck!
Too right mate!!
Get a wrx box in and out in 1hr 45 mins!! That includes changing the flywheel!! I think my record on a dual range outback is 13minutes for trans out! EJ25 (SOHC), BOTH headgaskets, engine out, back in, valves adjusted, running, washed hands, wrote warranty story-in....wait for it......
3hr 59 mins, (sounds better than 4 hours dont it?)
Not that I'M pullimg my own cord or anything!
CHeers,
Sixpack Subaru
sixpack subaru is offline   Reply With Quote
Old 11-04-2005, 08:06 PM   #6
ballitch
Member#: 74907
98 cam'd EJ251
Wrx Tranny,slowr than ish
i honsetly think just about anyone can change a clutch is these cars. get a engine hoist, a friend and some metric wrenches and sockets, label everything you take apart and replace the clutch. there are poeple here that will guide you through this if you dont understand something.
~Josh~
Old 11-07-2005, 11:03 PM   #7
Caboobaroo
Member#: 72335
89's RX/XT6
Blacksssssss
and since its a '86 GL, it should be a 1.8 liter, not a 1.6 liter...
Caboobaroo is offline   Reply With Quote
Old 11-11-2005, 12:49 AM   #8
ballitch
Member#: 74907
98 cam'd EJ251
and if you want a stronger pressure plate and clutch, buy an XT-6 clutch kit and have your flywheel machined down to XT-6 specifacations. you have the EA-82 motor, SOHC, 8-valve motor.
~Josh~
Need help with my GL 10 Tranny woes! Jeramiah 'Old School' Subaru Forum 2 02-17-2007 12:27 AM
I need help with my 02 Wagon Suspension! Hate my Teins natoli4 Brakes, Steering & Suspension 50 03-23-2006 08:21 PM
air conditioner on 86 gl wagon wvance 'Old School' Subaru Forum 1 06-21-2005 10:59 PM
CA: FS 86 GL wagon drebone8 Private Vehicle 'For Sale' Classifieds 1 10-05-2003 09:40 PM
Need help with old GL tranny... Bohanan @ work Normally Aspirated Powertrain 1 04-19-2001 09:04 AM
