Welcome to the North American Subaru Impreza Owners Club Saturday September 24, 2016
Old 10-21-2005, 03:52 PM   #1
_sti_05
Member#: 72313
16 STi
Default weird noise after turbo install
well i searched and searched and found nothing,
i just finish installing my fpgreen with supporting mods.
perrin 815 injectors
perrin big maf
perrin inlet
turboback
utec (was already on the car)
when i start up my car everything is ok, i let it warm up for a bit, then when i rev it up alittle and let go of the pedal, i can hear a kinda metal on metal sound. sounds like the fans on the turbo are hitting against the housing. i can only hear it after i rev it up and release the pedal not during idle or when i rev it. could i have an exhaust leak? maybe between the turbo and downpipe? i heard about using a piece of pipe to hear the leak, but what excatly am i hearing for?
any guru's wanna give me some info.
Thanks
_sti_05 is offline   Reply With Quote
Old 10-21-2005, 04:47 PM   #2
ai42
Member#: 71348
1999 EJ207 RS.TI
VW Golf TDI 40mpg baby!
Do you have a catalytic converter? Failed cats like to rattle. But usually they will rattle at idle and stop as the revs get higher. As for the pipe thing. Get a largish pipe (2-3") a foot or so long and put it up to your ear. Put you hand over the other ear or put in a earplug so you can point the pipe around and isolate where it is loudest and likely the source.
Also not a bad idea to torque down all the exhaust bolts after you've warmed it up and let it cool again.
ai42 is offline   Reply With Quote
Old 10-21-2005, 05:42 PM   #3
_sti_05
Member#: 72313
16 STi
no cat's but i will try the pipe thing when i get home. i also noticed that the turbo,dp and oil feed line gets really hot like after a couple of minutes being on. any idea what could be causing that? its really weird.
Old 10-21-2005, 05:57 PM   #4
USF97J4x4
Member#: 83035
Well, for one exhaust gas is hot? :P
USF97J4x4 is offline   Reply With Quote
Old 10-21-2005, 08:17 PM   #5
Tats
Member#: 5692
WTF? YES! I am
better than you!
Turbo and DP will get very hot from the exhaust gases flowing through them. The oil feed will get hot due to it's proximity to the turbo.
Tats is offline   Reply With Quote
Old 10-21-2005, 09:03 PM   #6
White 2.5rs
Member#: 39936
99RS TWE&SCAT EJ257
Hydra+HMist+PPG+35R=DEATH
wra wra wra wrong forum
Old 10-27-2005, 03:54 PM   #7
_sti_05
Member#: 72313
16 STi
it was an exhaust leak
Old 10-28-2005, 05:08 AM   #8
Sko
Member#: 90396
2005 Legacy 2.5i
Brilliant Silver Metallic
Yea, try posting this is Facory 2.5L Turbo Powertrain... They will 100% help you out.
Sko is offline   Reply With Quote
weird noise after intake install Enriched Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 19 03-26-2006 06:44 PM
weird noise after injector install fatalbertswrx Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 13 01-21-2006 12:22 PM
Weird Noise After Uppipe Install Dismo Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 5 07-04-2003 09:35 PM
loud ticking noise after turbo installed? RS2000 Normally Aspirated with bolt-on Forced Induction Powertrain 10 04-09-2002 08:51 PM
weird noise after uppipe install not a whine berto Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 8 03-26-2002 03:32 PM
