Welcome to the North American Subaru Impreza Owners Club Tuesday August 23, 2016
Old 10-21-2005, 11:50 PM   #1
keoni004
Member#: 69652
2011 BMW 335i
'05 WRX Wagon (RIP)
Unhappy Tried DRL disable...now CEL?!
Ok, tried to do the DRL disable today. I had read about it, and basically tried to do it by memory. Obviously I unplugged the wrong one, as I ended up with DRL's and a new CEL light. I started the car long enough to get the warning, then powered down. I plugged the cable back in, and the car seems as if it's running fine, but I still have the CEL. Any idea if it'll reset on its own?
Here's a pic I pilfered from saldunn83's DRL post, and I hope he doesn't mind. I unplugged the GREEN one next to the brown.
keoni004 is offline   Reply With Quote
Old 10-21-2005, 11:55 PM   #2
Casey
Member#: 82371
2002 IMPREZA
22 psi @ 2600rpm
Unplug the neg terminal on your battery, wait a few min, then plug it back in
You'll be all set
Casey is offline   Reply With Quote
Old 10-22-2005, 12:14 AM   #3
keoni004
Member#: 69652
2011 BMW 335i
'05 WRX Wagon (RIP)
( <--- newbie ) I'm not gonna get shocked to hell unscrewing the bolt connecting the cable to the negative terminal am I?
Old 10-22-2005, 12:50 AM   #4
Mulder
Trust no one
Member#: 11170
02 WRX
15 WRX/05 GTO
If you unplugged the green connector that is the fuel pump relay. The DRL module is a large rectangular unit with a white 10-pin connector, it is much larger than the relays in that pic.
Old 10-22-2005, 09:45 AM   #5
Casey
Member#: 82371
2002 IMPREZA
22 psi @ 2600rpm
Not the negative terminal. If you unplug the positive and touch it to a ground you will.
Old 10-22-2005, 10:43 AM   #6
armand1
Member#: 10309
'02 OBS 2-tone!
'95 Montego Miata
The DRL module (says "DRL" on its side) is to the right/behind the one you removed. Take out your glove box for easier access, from the right side.
Old 10-23-2005, 09:42 AM   #7
RacEoHolic330
Member#: 91581
2013 WRX Limited 5dr
ISM
That connector you unplugged is for your cruise control. I'm gonna bet that your cruise no longer works. Thats why you're getting a CEL. The DRL connector is rectangular and it further up along side the glove box. I was able to get mine unplugged without taking out the glove box, but have small hands.
RacEoHolic330 is offline   Reply With Quote
Old 10-23-2005, 10:05 AM   #8
iguanamafia
Member#: 23426
2010 Forester
Streetfighter
if you use a big enough wrench you can hit the positive(+) terminal on the battery while working on the ground (-) and cause some nice fireworks.
Good Luck!!
iguanamafia is offline   Reply With Quote
Old 10-23-2005, 11:47 AM   #9
Fast_Wrx62
Member#: 89139
2002 RIP Bugeye.
lol......
Fast_Wrx62 is offline   Reply With Quote
Old 10-23-2005, 11:54 AM   #10
Fast_Wrx62
Member#: 89139
2002 RIP Bugeye.
Is this the right wire?
Old 10-23-2005, 12:09 PM   #11
Mulder
Trust no one
Member#: 11170
02 WRX
15 WRX/05 GTO
This is what you need to disconnect (thanks Hank3)-
Old 10-23-2005, 12:42 PM   #12
Fast_Wrx62
Member#: 89139
2002 RIP Bugeye.
k let me go try it out....
Old 10-23-2005, 02:54 PM   #13
Fast_Wrx62
Member#: 89139
2002 RIP Bugeye.
It Works!
DIY Mods: Intake Silencer Delete, Disable DRL, Disable Seatbelt Warning User Banned Interior & Exterior Modification 129 11-09-2014 01:10 AM
'03 WRX DRL Disable JustDSM Electrical & Lighting 22 03-13-2003 07:20 PM
Help w/ DRL disable KillerRex Interior & Exterior Modification 9 05-22-2002 08:07 PM
Anyone worked out DRL disable yet? iceweazel Interior & Exterior Modification 0 06-06-2001 10:52 PM
