Old 10-22-2005, 01:12 AM   #1
tahrndt
Member#: 1315
Default Help with CEL and knock sensor
My CEL came on a couple of weeks ago. Intermittent at first. When I had it scanned they told me it was the "knock sensor". Is this a part that I can easily buy and throw in or does this sound like a job for the stealer ship?
The light cycles off about ever 5 days, then will stay off for the next 4 or so key cycles.
Any help here?
Thanks,
Tim
tahrndt is offline   Reply With Quote
Old 10-22-2005, 01:30 AM   #2
burnera
Member#: 56232
89 325I
i don't know
i'm wondering too. it came on for me for a day then went off.
i'm miffed.
burnera is offline   Reply With Quote
Old 10-22-2005, 01:47 AM   #3
XenoWolf
Member#: 64029
1999 Impreza L Wagon
Sun Bleach Red
Well, the knock sensor detects engine 'detonation' (pre-ignition). Detonation can be caused for various reasons (I'll let someone more knowlegable handle those) and if left unfixed could cause terminal damage to your engine...
I can't really be more specific with 'its the knock sensor'. Could also mean (I assume) that the sensor has gone bad as you've assumed. They are typically mounted directly on the block, so replacing one most likely wouldn't be a big hassle.
XenoWolf is offline   Reply With Quote
Old 10-22-2005, 01:55 PM   #4
burnera
Member#: 56232
89 325I
i don't know
for mine its a bad sensor, per the codes after looking them up detailed on ravensblade.
now i just need to find where it is?
Old 10-22-2005, 02:12 PM   #5
quynce
Member#: 15409
Knock sensor replacement is a piece of cake. If you're looking at the engine, it is on the right side between the two intake manifold pipes. It is held on with a 12mm bolt and has one wire coming out of it.
FWIW, I had the same CEL come on a couple weeks ago. I pulled the knock sensor out, cleaned it up and put it back in and haven't had any more CELs. You might try that firtst before spending $70 on a new one.
quynce is offline   Reply With Quote
Old 10-22-2005, 03:22 PM   #6
burnera
Member#: 56232
89 325I
i don't know
went to the service parts locally and they wanted $105 for the thing. lol
i'll live with the CEL. it went away yesterday on the way to work anyway..
does it matter what you clean it with?
Old 10-22-2005, 08:46 PM   #7
tahrndt
Member#: 1315
I am in the process of selling my Legacy, so, for me the $80 I spent could mean the difference between a sale and no-sale.
Taking it off was very easy, it is located directly under the throttle cables on the drivers side of the engine. Putting the new one in was a total PITA!!! I have somewhat XL hands, and it took me a long time to line up the 12mm bolt and the damn hole it was to go in. It is in such a funky position, it is a real pain, oh, yeah, there is also some vacuum line thingy directly above the fricken thing.
Oh well, bottom line is that I do not have any CEL!!! yea!
Cheers.
Tim
Old 10-23-2005, 12:25 AM   #8
burnera
Member#: 56232
89 325I
i don't know
the parts guy at the desk looked at me and goes " i didnt realize they were so expensive. i sell about 3 or 4 of these things a day too"
Old 10-23-2005, 07:40 PM   #9
tahrndt
Member#: 1315
Yeah, they must be a real POS, the parts guy I talked to just nodded and said, "yep, that sounds right for that year" when I told him I needed a knock sensor for my '01.
Also, by the fact that they had 8 in stock made me believe they go through these on a regular basis.
Cheers.
Tim
Old 10-23-2005, 07:56 PM   #10
bl_easy
Member#: 91407
Ver. 2 WRX STi wagon
BRetty green
Cheers.
Tim
+1 on the thing with the hands! It took me so long to get that bolt to catch just enough to screw it in... my hands were scratched up pretty good after that.
bl_easy is offline   Reply With Quote
HELP! flashing CEL and knocking from engine k-money Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 42 02-06-2010 08:44 PM
Pulled CEL code - knock sensor 1 circuit high input squeeks Engine Management & Tuning 1 05-10-2006 09:18 AM
Help With Cel and AP PO300?? DanBelford Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 24 10-20-2005 03:46 PM
HELP with cel and a/f ratio imprezach Engine Management & Tuning 3 08-29-2004 10:48 AM
need help with the J&S knock sensor ChAi Normally Aspirated Powertrain 7 10-20-2000 10:32 PM
