Old 10-22-2005, 01:36 PM   #1
Tats
Member#: 5692
WTF? YES! I am
better than you!
Default E-Manage maps...
I'm putting my stock EJ25 with the AVO kit back in the RS.
I'm dicting the Link 1 that came with it in favor for the E-Manage.
Any one have some basic maos they can e-mail me to get started?
BTW:
MY01 RS w/ AVO kit, E-Manage w/ MAP sensor, ignition and injectors harness, and 255 fuel pump. Stock injectors.
ANy help would be appreciated.
(Also posted in Tri-State Forum)
Tats is offline   Reply With Quote
Old 10-22-2005, 06:53 PM   #2
PHATsuby
Member#: 13617
2001 Legacy GT back
to stock is a project too
sorry, not related, but why are you going back to that from the 30R and 257? selling?
more projects coming?
Ben
Old 10-22-2005, 09:41 PM   #3
Tats
Member#: 5692
WTF? YES! I am
better than you!
EJ257 is getting "Built" WRX heads and going into a black 03 WRX wagon with the GT30R and maybe the FMIC. I havn't decided how far I want to go with it yet.
The RS-T is gonna be my toy for now.
Old 10-22-2005, 09:42 PM   #4
Storm
Member#: 5218
96L Most Over-
Developed Beater
Wanna get rid of the link?
Old 10-22-2005, 11:40 PM   #5
Tats
Member#: 5692
WTF? YES! I am
better than you!
Tell ya what...if you decide you really want a Link 1 piggyback....well make a deal after my emanage is in.
Old 10-23-2005, 02:03 AM   #6
Derk1127
Member#: 9134
2000 Impreza RS-T
BRP w/Hydra+EJ257
are you going with the ultimate or the blue? if you want a blue i might give mine up for a good price to try out the ultimate.
Derk1127 is offline   Reply With Quote
Old 10-23-2005, 02:45 AM   #7
kgb
Member#: 1366
2000 RS-T -> RSTi-8
Blue Ridge Pearl
OT - I think I had enough of my Link, but I think I would probably spend the big bucks for an SM4
kgb is offline   Reply With Quote
Old 10-23-2005, 11:58 AM   #8
Tats
Member#: 5692
WTF? YES! I am
better than you!
I went with the blue. A guy around here bought one for his turbo celica project but it really wan't working out with his VVT-i so he went AEM instead.
Blue, ignition harness, injector harness, map sensor, map harness, and tuning tool all for $450.
Old 10-23-2005, 03:59 PM   #9
PHATsuby
Member#: 13617
2001 Legacy GT back
I am going SM4(sorry just had to say that)
I actually want to see a megasquirt in action. seems like a very capable system if you can figure it out.
Ben
Old 10-23-2005, 04:43 PM   #10
Hitokiri
Member#: 2604
1999 2.5RSt
RBP
Tats the problem is that you really need bigger injectors, and that proves a problem with using the MAP sensor as load.
Hitokiri is offline   Reply With Quote
Old 10-24-2005, 11:01 AM   #11
Tats
Member#: 5692
WTF? YES! I am
better than you!
Not that I'm doubting you but if the link 1 can run the stock fuel system up to 7 psi of boost, why can't the E-Manage runt it up to 7psi with a 255l pump?
Is it something specific to the unit/map sensor?
Also...can stock RS injectors be modded like the WRX ones?
Old 10-24-2005, 11:09 AM   #12
Hitokiri
Member#: 2604
1999 2.5RSt
RBP
I would be impressed if you got 7psi boost to 11's afr with 100% on those stock injectors.
You for sure will be able to get 100% out of them with the emanage, but believe me you make alot more power at 7psi than can be supported by stock injectors even given the slight increase fuel pressuse from a 255.
at 7psi boost I need 90% of my wrx injectors to maintain low 11's afr. So hats off to ya! you can always put wrx injectors in there. People say it desn't work because the bosses are different, but if you stack some odd sized orings in there and block the air assist tubes coming in, it works fine. I put RC750's in a MY00 manifold. Took a little fileing till they fit snug but they sealed fine. Spray pattern might have been a little off but not too bad.
Todd
Old 10-24-2005, 12:50 PM   #13
Tats
Member#: 5692
WTF? YES! I am
better than you!
hmmm.....maybe i'll just drop to 5psi till i can find injectors.
MAybe a RRFPR will do it?
I don't seem to recall any plug and play injector upgrades for my01.
Old 10-24-2005, 07:27 PM   #14
GregBolby
Member#: 498
1981 jdm swapped gc
sniklfritz
i just put in a new clutch on sat, and gutted the downpipe, anyways its boosting to 7psi now, and at 6ish im at around 92% duty cycle on 280cc inj at around 5300rpm.....i have some green top ford lighting 42lb 440cc inj im going to try and get to work this weekend ill let you know whats up, they are bosch style inj. Measure very close to rc inj...have to shim up the rails a 1/2 inch.... ill keep i updated
GregBolby is offline   Reply With Quote
Old 10-27-2005, 02:14 PM   #15
Hitokiri
Member#: 2604
1999 2.5RSt
RBP
do you have a wideband?? any knock detection??
remember to take out tons of timing, your ecu runs up to 34 degrees up top.
Old 10-27-2005, 04:12 PM   #16
kgb
Member#: 1366
2000 RS-T -> RSTi-8
Blue Ridge Pearl
Exclamation
I guess it all depends on the AFR you're targeting - I know I get beyond 100% IDC somewhere between 5psi-7psi, near torque peak (possibly soon after 3500). Stock injectors and fuel pump. The bigger concern is the timing since stock ECU have loads of advance, and I'm not sure the MAP and TPS signals can be manipulated enough to give a nice rich AFR on boost. Even a WRX has some sort of RRFPR
Old 10-27-2005, 04:17 PM   #17
Tats
Member#: 5692
WTF? YES! I am
better than you!
M'kay.....I have an LM-1 wide band....and some modded WRX (740cc) injectors in the mail. No 255 pump though. The local shop tried to rape me (197.00 for a walbro 255...yeah right!).
At 740cc I don't think I'll need it any way.
May by the end of next week I'll have time to install everything and start tuning.
And helpful hints for the emanage n00b?
Old 10-27-2005, 04:18 PM   #18
Tats
Member#: 5692
WTF? YES! I am
better than you!
KGB- I am using the greddy map sensor, injector, and ignition harnesses so I shound be able to pull all the timing I want correct?
Old 10-27-2005, 07:15 PM   #19
jkjersey
Member#: 8399
GC8 JDM STI V swap
cardinal red
KGB - question .... I am going to use the emanage to for an engine swap what do you mean when you say...? "The bigger concern is the timing since stock ECU have loads of advance, and I'm not sure the MAP and TPS signals can be manipulated enough to give a nice rich AFR on boost. Even a WRX has some sort of RRFPR"
RRFPR ... elaborate... on this please. When you speak of MAP and TPS signals are you saying the Emanage's range isn't wide enough to tune to a proper AFR under heavy boost? Even if its tune with a wideband installed?
What are you running in your setup?
jkjersey is offline   Reply With Quote
Old 10-27-2005, 09:27 PM   #20
Hitokiri
Member#: 2604
1999 2.5RSt
RBP
its going to be difficult to tune out injectors that big with map correction. I would seriously trading up that blue emanage for an emanage ultimate if you are going with injectors that size.
I don't think you understand the reason that you need the fuel pump. Its not to increase the fuel pressure, its to increase the potential for higher fuel flow. Big injectors is not a reason to forgo the fuel pump but rather increases the need for one.
helpfull hinkts for the emanage newb:
pull tons of timing to start out. Like 1.5degrees / psi boost so at 5psi boost you should be seeing -7 or -8 degrees. You will ikely be able to run more, but give yourself the headroom for mistakes in your fuel basemap. Here is a datalog from a 02 RS which will give you an idea as to what your base timing is: Note: my car runs about 4 degrees more timing than this stock. I always thought that the phase 2 cars ran more timingm but the ecu logs down back it up.
Code:
(RPM) - Ignition Timing (BTDC)	- Manifold Relative Pressure (PSI)
2071	21	-5.804
2094	31	-5.659
2150	31	-4.933
2175	30	-4.353
2240	29	-3.482
2284	28	-3.337
2350	28	-3.192
2415	28	-2.902
2479	28	-2.612
2554	28	-2.612
2612	28	-2.322
2694	27	-2.031
2747	27	-1.886
2825	25	-1.451
2898	24	-1.306
3006	22	-0.871
3065	24	-0.725
3153	23	-0.435
3245	21	-0.29
3330	19	-0.29
3428	20	-0.29
3518	20	-0.145
3621	18	-0.145
3706	17	-0.29
3805	18	-0.145
3896	20	0.145
4006	19	0.145
4089	20	0
4230	21	0
4303	24	-0.145
4414	22	0.145
4507	24	0.29
4615	25	0.29
4723	25	0.29
4802	26	0.435
4924	27	0.435
5020	29	0.58
5123	30	0.725
5226	30	0.58
5346	30	0.725
5439	32	0.58
5551	30	0.871
5626	30	1.016
5774	30	0.871
5828	31	1.016
5952	30	1.161
6039	30	1.306
6117	31	1.596
note also that this car is running turbo with the wategate ties open, thats why you see slight boost there after 5k RPM
remember to be conservative. shoot to richen it up around 3500 and get to mid 10's and hold till readline. from there you can experiment with less fuel and more timing if you have knock detection.
Old 10-27-2005, 10:06 PM   #21
kgb
Member#: 1366
2000 RS-T -> RSTi-8
Blue Ridge Pearl
I suspect you will need a pump other than stock, as well as a bigger FPR - the stock ones doesn't flow enough and without a pump to put up the pressure, you might not get the full 740cc flow.
Old 10-27-2005, 10:10 PM   #22
kgb
Member#: 1366
2000 RS-T -> RSTi-8
Blue Ridge Pearl
jkjersey - the key is stock injectors + pump + FPR. With only MAP/TPS fiddling, you are still bounded by the stock fuel MAP. I'm not sure the blue e-Manage intercepts the injector signals as well - the PerfectPower didn't. From what I read here, the WRX might have a a RRFPR as well to help squeeze more fuel out of the injectors (might not be a big ratio one though).
Tats - pulling ignition should be fine
Old 10-30-2005, 06:37 AM   #23
Tats
Member#: 5692
WTF? YES! I am
better than you!
Mmmmkay.
740cc Injectors are here.
Walbro 255 is in mail.
O-ring kit from Sean @ Rallitek to fit WRX injectors in 99-02 manifold are in the mail.
Can't wait to get this going. Before I know it snow will be here making life way more difficult than it should be.
Old 10-30-2005, 03:54 PM   #24
Derk1127
Member#: 9134
2000 Impreza RS-T
BRP w/Hydra+EJ257
740cc injectors are huge for the emanage, I tried that setup on another piggyback system the Split Second FTC-1 and I was never able to tune the injectors down enough so the car wouldn't spit fuel out the exhaust
Old 10-30-2005, 07:57 PM   #25
Hitokiri
Member#: 2604
1999 2.5RSt
RBP
like I said.
going to have to get an emanage ultimate to get that to happen..
Can someone send me their E-Manage MAP... Jaredm83 Engine Management & Tuning 1 01-11-2005 07:53 PM
Does boost gain setting change (on EBC) require a revised engine management map? rjhang Engine Management & Tuning 2 12-20-2004 10:50 AM
E-Manage Maps tony_subaru Normally Aspirated with bolt-on Forced Induction Powertrain 2 02-24-2004 04:36 PM
E-manage Maps!!! AntonioS Normally Aspirated with bolt-on Forced Induction Powertrain 2 11-10-2003 03:08 PM
E-manage maps AntonioS Engine Management & Tuning 0 04-27-2003 10:30 PM
