Old 10-22-2005, 01:58 PM   #1
OneArmedScissor
Member#: 18958
08 STi
Black as my heart
Default my cig lighter just stopped working :(
my cigarette lighter just stopped wroking. i tried to plug in an old power inverter and it shut itself off.
and then nothing else worked in the outlet.
I checked the proper and corresponding fuses and they were all good. In fact, the other devices which draw power (mirrors and the auto dimming mirror power which is hooked up to my v1 now) were fine.
what gives, mate?
OneArmedScissor is offline   Reply With Quote
Old 10-22-2005, 02:07 PM   #2
Mulder
Trust no one
Member#: 11170
02 WRX
15 WRX/05 GTO
There is an integral fuse in the lighter itself, that is probably blown. It's a thermal fuse, I believe, to prevent the socket from overheating. To check it you need to remove the lighter from the console, the fuse is on the rear of it. Should it be blown the proper fix is a new lighter, although you can bypass the fuse at your own risk.
Old 10-22-2005, 02:17 PM   #3
OneArmedScissor
Member#: 18958
08 STi
Black as my heart
damnation.
how much is a new lighter from vatozone or ORLY's?
Old 10-22-2005, 02:45 PM   #4
Mulder
Trust no one
Member#: 11170
02 WRX
15 WRX/05 GTO
Don't know if a universal replacement type will fit properly. A new one shouldn't be that much from Subaru, you can check with the online vendors here who are Subaru parts depts. Also check your local junkyards for a good used one, but take an ohmeter with you to make sure the one you pick is ok.
And don't use that same inverter again or the same thing will probably happen.
Old 10-22-2005, 03:58 PM   #5
JackClark
Member#: 60264
2004 STi
It could also be the small 20A accessory fuse in the internal fuse box. Top row, 4th from the left. Did your power mirrors / auto dimming mirror stop working as well?
JackClark is offline   Reply With Quote
Old 10-22-2005, 04:14 PM   #6
Mulder
Trust no one
Member#: 11170
02 WRX
15 WRX/05 GTO
Read before posting please-
Old 10-22-2005, 05:45 PM   #7
iguanamafia
Member#: 23426
2010 Forester
Streetfighter
hmm replace it for 12 bucks
iguanamafia is offline   Reply With Quote
Old 10-22-2005, 07:40 PM   #8
OneArmedScissor
Member#: 18958
08 STi
Black as my heart
okay, so I don't know exactly hwo to pop off the interior stuff to acces the cig. lighter and put a new one in there. anyone know?
Old 10-22-2005, 07:46 PM   #9
MrH00nel2
Member#: 80474
2002 Z06
1200whp
do you know where the fuse box is on the driver side?
the fuse runs to your cig lighter also does your mirrors and rear view if you have the compass.
replace it with the spare fuse that is in the fuse box.
did you try that?
MrH00nel2 is offline   Reply With Quote
Old 10-23-2005, 07:23 AM   #10
Mulder
Trust no one
Member#: 11170
02 WRX
15 WRX/05 GTO
did you try that?
Jeez, does anybody read the thread fully before posting?
Old 10-23-2005, 10:01 AM   #11
iguanamafia
Member#: 23426
2010 Forester
Streetfighter
inside the center console cubby- 2 screws. Pull up the shifter surround, it just pops up. I think there are 2 screws under that holding down the cubby portion. pull up the cubby portion and unplug the wire harnesses.
It's been a while but I think I am pretty close on this. there might be some in better info in this forum or the audio one
Old 10-23-2005, 04:14 PM   #12
skid_mark_steve
Member#: 69775
2004 WRX Stage 4+
Java Black
i ahd the exact same problem. mini compressor blew it at autoX. where and what part number did you get to replace the lighter?
skid_mark_steve is offline   Reply With Quote
Hardwire Sirius to my cig lighter? Xxsto99xX Electrical & Lighting 7 12-17-2009 10:09 AM
Help, my cig lighter and power mirrors dont work DerrickRH Electrical & Lighting 1 10-22-2008 05:17 PM
my cig lighter outlet makes stuff Blow UP! ooberdoob Legacy Forum 9 04-26-2005 02:15 AM
My low beam HIDs just stopped working, troubleshooting help please. trail*of*dead Electrical & Lighting 17 01-07-2005 09:30 AM
Basslink just stopped working... criz Car Audio, Video & Security 6 12-02-2004 08:50 AM
