10-22-2005, 03:08 PM | #1 |
Member#: 72897
SCIC
Vehicle:2004 wrx wr blue |
lost of boost,back to 11 psi
my 2004 is tuned on the ecutek system and was running fine. i was boosting 18 psi that is what it was tuned at. all of a sudden it went back to the stock 11 psi and that is all it is reaching. i cant see any holes in any hoses but ive only check on top like the hoses going to the turbo, wastegate and boost controller. what else can this be. i tried doing the reseting by unplugging the neg battery cable and holding the break for about a min, ive never known how long you have to hold it for but still nothing. please give me some ideas this is very frustrating thanks guys....
10-22-2005, 03:39 PM | #2 |
Member#: 77483
NWIC
Vehicle:2009 Audi A3 2.0T q Lava Grey |
Erm. Stock boost is NOT 11psi.
if you are only seeing 11psi, you have something wrong mechnaically. |
10-22-2005, 03:43 PM | #3 |
Member#: 36528
Vehicle:2002 Impreza Wrx Silver |
There's a low and high boost mode with ecuteks. I forget exactly how to change it, but that might be something you'd wanna look into.
peace |
10-22-2005, 04:05 PM | #4 |
Member#: 59136
BAIC
Vehicle:04/5 APRWidebody STi 500/500 - Snail Tuned |
What he said. Could be on low boost mode. Alternatively the solenoid has quit working. This is a common problem for the stock part. You could try cleaning it(I didn' have any luck) or replace it with stock or the Perrin EBCS. Both are under $100. Good luck.
10-22-2005, 05:06 PM | #5 |
Member#: 91703
I'm having a similar problem.
I checked my solenoid (i have the GM Solenoid mod, but it's basically the same) and it seems to be working fine (it clicks when given power from a 9v battery, and it blocks the right ports ). I found the ECUTek is actually sending the wrong signal to the solenoid... didn't hear anything about that low boost thing... i wonder if that's my problem. Just wondering though, is it possible the solenoid could be switching correctly but still be broken somehow? |
10-22-2005, 05:26 PM | #6 |
Member#: 36528
I think to switch boost modes, ya push the throttle in all the way with the ignition on but the engine off and hit the defrost button. I could be wrong though.
peace |
10-22-2005, 05:34 PM | #7 |
Member#: 69991
NESIC
Vehicle:Leh Keen Approved '68 Volvo Amazon |
thats the right way to switch boost modes. go WOT then hit the defrots button, not sure if driving or just on accessory
Boost Drops to 0 psi @ 5K RPM in 2nd and 3rd (4EAT) | wtdash | Subaru Conversions | 0 | 06-19-2009 03:58 PM |
Boost Drops to 0 psi @ 5K RPM in 2nd and 3rd (4EAT) | wtdash | Pre-2002 Factory Turbo Powertrain | 0 | 04-18-2009 04:21 PM |
Boost spike to 25 Psi!! | midtwnman | Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) | 9 | 09-18-2006 08:46 AM |
Boost Only hitting 11 psi when it was set to 19 ? | zigger | Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) | 2 | 12-16-2005 03:50 PM |
Lost of boost in Legacy | Prostho | Legacy Forum | 2 | 04-09-2001 10:18 AM |
