Old 10-22-2005, 04:04 PM   #1
Virusx86
Member#: 91703
Default Weird ECUTek Boost Solenoid problems
About a month ago I ran into a problem with the car not building full boost and tracked the problem down to the boost control solenoid not actuating correctly. After going over the whole system with a multimeter today I found that the solenoid will fire if given a chassis ground... indicating that the solenoid and relay are operating correctly. I tested every section of the circuit and found that the 12v signal form the relay is getting all the way to the B137 connector on the ECU (the circuit is complete), but the solenoid is still not being actuated. Strangely enough... with the b137 connector out, if the solenoid pin is connected directly to the ECU with a seperate wire the solenoid fires correctly, but with the entire plug connected it will not.
This is pretty baffling... it had been working fine for a few months before this happened and I have no idea what could have caused it (didn't change anything at all). Reset the ecu with the same results.
My car has an ECUTek tune on it, and I've contacted the people who tuned it to try and get help from them but figured a two front attack on the problem couldn't hurt. I know it's pretty crazy and obscure, but who knows :X
Thanks for your help guys.
Virusx86 is offline   Reply With Quote
Old 10-23-2005, 12:19 AM   #2
Virusx86
Member#: 91703
No ideas from anyone? The person who tuned my car didn't have any answers for me either (which was upsetting), telling me to get an aftermarket boost control system. Not really feeling like putting $300 in his pocket + tuning expenses because their product broke. I'm sure it's something simple. I heard the ECUTek can be switched into a low boost mode somehow? Maybe that's what the problem is, how would i switch it back?
Turbosmart dual port BOV, TurboXS Boost Solenoid benton0311 Engine/Power/Exhaust 1 06-04-2010 01:27 PM
Dtec boost solenoid problem, very rare Chuky UTEC 11 05-11-2009 06:02 PM
boost solenoid problem help! scobaru Subaru Conversions 0 09-28-2006 04:16 PM
Does Ecutek+Big Turbo work well with OEM boost Solenoid Ricowrx Factory 2.5L Turbo Powertrain 11 11-15-2004 09:42 AM
stock boost solenoid problem koopatroopa Factory 2.0L Turbo Powertrain 10 11-21-2003 07:52 PM
Message Board Statistics All times are GMT -4. The time now is 11:18 PM.
