Old 07-29-2007, 03:29 AM   #226
Thormix
Member#: 118150
04 Wagon XPT HTA68
Originally Posted by Superorb View Post
Ok. Would it help if I were to post a log of 3rd gear if, after I flash to XPT map, it doesn't reach target boost?
Yes! Do a 3rd gear WOT log from 2.5K rpm to rev limiter ~7.1K and email it to me at [email protected]
I will take a look and make adjustment to your XPT GM BCS map, if needed.
Make sure to log all the good stuff. Boost, Timing, Engine load, etc etc.
OK
Thormix is offline   Reply With Quote
Old 07-29-2007, 11:18 AM   #227
Superorb
Member#: 135252
2002 WRX Wagon
86% Operational :(
Gotcha. I still haven't installed the BCS or bought the XPT map yet. I've got other priorities but I'll email it once I do it.
Superorb is offline   Reply With Quote
Old 07-29-2007, 11:29 AM   #228
Thormix
Member#: 118150
04 Wagon XPT HTA68
Cool. Your going to love the XPT map & the GM BCS!
It's defiantly a winning combo.
Old 07-29-2007, 10:15 PM   #229
Superorb
Member#: 135252
2002 WRX Wagon
86% Operational :(
Can't wait! Just installed new clutch, light flywheel last weekend so I've got another 700 miles of break-in on it. After that I'll throw the BCS and XPT map on. I'm still having trouble timing shifting with the new clutch; I've got to let off the clutch earlier than I used to, while giving gas at the same time as before since the flywheel drops revs so much faster.
Old 07-31-2007, 01:20 PM   #230
s202sti
Member#: 27689
This map was tuned without the restrictor pill and should be run with all new matching hoses w/ out the restrcitor pill or "T".
You do not need to add the 20ohm resistor. The XPT map deletes that CEL code when you flash the map to your ECU.
Enjoy your XPT Power
what size hoses should i buy? brand? type? im on rockauto right now, about to purchase the BCS and pigtail. tia
s202sti is offline   Reply With Quote
Old 07-31-2007, 03:43 PM   #231
06rexwagon
Member#: 114730
2006 WRX Limited Wag
[email protected]
5/32" . Just get it at your local NAPA or other parts store. I typically buy 6 ft and have a little left over.
06rexwagon is offline   Reply With Quote
Old 07-31-2007, 05:14 PM   #232
Thormix
Member#: 118150
04 Wagon XPT HTA68
^^^ What he said
Take a piece of your existing hose to the Parts Supply store (if you can) and match it up for inner wall size.
Old 07-31-2007, 06:02 PM   #233
Superorb
Member#: 135252
2002 WRX Wagon
86% Operational :(
If anyone needs a GM BCS pigtail I've got a few here that I bought too many of. $15 shipped.
Old 08-03-2007, 07:58 PM   #234
DinoGuan
Member#: 42233
04 WRX waGGon
I'm still having a hell of a time controlling boost spikes.
It's on the range of almost 3psi !
I'm using utec on an 04.
Ive had my boost gain from 55 - 85 ! And change my boost map accordingly to keep boost under 18psi
At first I had no restrictor, very unstable boost and spikes.
Put in restrictor, less instability, still spiking pretty badly.
I'm using smaller than usual vacuum tube, it was a real pita to fit it over the compressor outlet and solenoid.
Could this be a problem?
I also have it making a 180 degree turn right before it hits the solenoid, but its very long and smooth, no kinks.
The 10ohm resistor has nothing to do with performance right? Just a safety precaution?
Don't know what to do next, Any advice?
Here is a small log showing the spike.
Code:
[TSMP][RPM][PSIG][MAF][TPS][LOD][KN][SNB][SIG][IDC%][IGN][FMVL][BMV][MMV][WBO2]
002.14 4488 +12.3 3.9  100   70   0  12.0 27.3  35.4 14.4  -5.1 330  3.1  10.35
002.21 4456 +14.5 4.1  100   80   0  12.0 06.0  43.3 17.2  -6.0 330  3.2  10.91
002.26 4496 +16.1 4.2  100   90   0  12.0 24.8  44.5 16.3  -4.9 330  3.3  11.15
002.36 4559 +17.8 4.2  100  100   0  12.0 22.8  45.5 16.0  -6.1 330  3.3  10.94
002.41 4621 +18.4 4.2  100  100   0  12.0 23.1  45.4 16.0  -6.1 330  3.3  11.04
002.51 4685 +17.8 4.1  100  100   0  12.0 23.9  42.5 16.2  -6.0 330  3.2  11.44
002.60 4762 +17.0 4.2  100   90   0  12.0 25.4  46.7 17.2  -6.3 330  3.2  11.36
002.66 4842 +16.8 4.2  100   90   0  12.0 25.9  45.8 17.2  -6.3 330  3.2  11.25
002.75 4925 +15.9 4.1  100   90   0  12.0 27.6  46.8 17.2  -6.5 330  3.2  11.19
002.81 4969 +15.9 4.2  100   90   0  12.0 28.2  45.9 17.1  -6.9 330  3.3  11.13
002.91 5039 +15.3 4.2  100   80   0  12.0 29.2  48.0 17.1  -6.9 330  3.3  11.02
003.00 5139 +15.3 4.2  100   80   0  12.0 29.3  47.8 17.3  -6.9 330  3.3  10.99
003.05 5228 +14.9 4.2  100   80   0  12.0 29.5  47.0 17.4  -6.8 330  3.3  11.00
003.15 5318 +15.5 4.3  100   80   0  12.0 29.5  50.3 17.1  -6.9 330  3.3  10.89
003.21 5416 +15.5 4.3  100   80   0  12.0 30.6  51.7 17.0  -7.0 330  3.4  10.81
003.29 5482 +15.9 4.3  100   80   0  12.0 30.7  53.6 16.9  -7.1 330  3.4  10.86
003.39 5535 +16.1 4.4  100   90   0  12.0 30.7  52.5 16.8  -7.2 330  3.4  10.95
003.45 5583 +15.7 4.4  100   80   0  12.0 31.1  55.4 16.9  -7.2 330  3.4  11.13
003.55 5691 +15.5 4.4  100   80   0  12.0 31.6  55.6 17.0  -7.2 330  3.4  11.06
003.61 5782 +15.7 4.4  100   80   0  12.0 31.5  55.1 17.2  -7.6 330  3.4  11.01
003.69 5845 +15.5 4.5  100   80   0  12.0 32.2  57.2 17.3  -7.1 330  3.4  11.03
003.79 5889 +15.5 4.5   88   80   0  12.0 33.7  58.2 17.7  -7.5 330  3.4  11.00
003.85 5931 +15.3 4.5   69   80   0  12.0 33.9  54.8 18.1  -7.6 330  3.4  10.96
003.93 6018 +11.9 4.3   36   70   0  12.0 35.0  49.7 19.7  -2.9 286  3.2  10.45
DinoGuan is offline   Reply With Quote
Old 08-03-2007, 08:20 PM   #235
Superorb
Member#: 135252
2002 WRX Wagon
86% Operational :(
A 180 degree angle is a straight line
Old 08-10-2007, 01:21 AM   #236
DinoGuan
Member#: 42233
04 WRX waGGon
Lol
Damn noone checks this post anymore eh?
This is still pissin' me off
Spike's are down to about 2psi, but boost wavers a good +- 2psi also.
Don't know what to do.
Old 08-10-2007, 11:37 AM   #237
x99percent
Member#: 27108
2004 STi
2004 A4
Switch to PID boost control, as found in the newest firmware. Start with a VERY LOW gain, like 10 or less, along with a low/safe WG duty map. Note what the UTEC *tries* to run for WG duty versus what's in your map, and compare actual boost versus target boost.... make your changes from there.
I don't know why anyone would bother to still run the old stuff.
x99percent is offline   Reply With Quote
Old 08-10-2007, 06:53 PM   #238
Superorb
Member#: 135252
2002 WRX Wagon
86% Operational :(
Old stuff as in stock stuff, or something different? Not everyone uses a UTEC...
Old 08-11-2007, 11:38 AM   #239
x99percent
Member#: 27108
2004 STi
2004 A4
Old stuff as in old UTEC firmware. The post above mine is from a UTEC user... the same one that posted a UTEC log 5 posts up. I was trying to help him out.
If you want to take offense, be my guest.
Old 08-11-2007, 01:32 PM   #240
DinoGuan
Member#: 42233
04 WRX waGGon
I was reading up on PID boost control.
So target boost is based on rpm?
I don't know it just doesn't seem like a good solution.
Mick's guide says its rock solid once tuned, but boost is not based on TPS anymore.
Maybe I'll play with it one day.
Old 08-11-2007, 02:46 PM   #241
Superorb
Member#: 135252
2002 WRX Wagon
86% Operational :(
I didn't take offense, I was just confused. I'm an EMS newb
Old 08-11-2007, 03:15 PM   #242
x99percent
Member#: 27108
2004 STi
2004 A4
As far as I know, the boost map has always been RPM vs TPS. Even now, if you don't want full boost at part-throttle, then leave "ECU" in the boost map, up until when you have the UTEC take over (typically @ 30%).
The PID control is less sensitive to changes in weather. It's supposed to be the same logic that is in their standalone DTEC-BC boost controller.
Old 08-11-2007, 07:15 PM   #243
DinoGuan
Member#: 42233
04 WRX waGGon
So between 30% and 100%, what is the boost target?
Mick's guide says the 0% column is the boost target for that rpm range regardless of TPS.
Then the TPS% is the starting gain value or something.
What If I'm at 5k rpm, at 60% throttle in a constant radius turn, will it aim for 18psi( or whatever max is) ?
Old 08-12-2007, 07:46 PM   #244
Freon
Member#: 88322
2009 BMW 135i
With UTEC PID the boost target is always what you put in the far left column, unless you put in "ECU" in the 10-100% column. So whats up PTFB.
Freon is offline   Reply With Quote
Old 08-15-2007, 10:43 AM   #245
Rene2.5RS
Member#: 4574
2014 Outback 2.5i L
VRP
I think it is funny. Did this mod lowered my WGDC by 30% couldn't hit more than 12 psi. Went back to my previous map and there were no problems. This had no effect in WGDC. It only stabilized my boost which isn't bad just wasn't the only help I was hoping for.
-Rene
Rene2.5RS is offline   Reply With Quote
Old 08-15-2007, 10:52 AM   #246
zombiedog
Member#: 25138
85 e30
PRIMERZ!
HAHA I like how if it doesn't work for some people then it's broken or junk...
How about if it doesn't work you're doing it wrong.
zombiedog is offline   Reply With Quote
Old 08-15-2007, 11:00 AM   #247
Rene2.5RS
Member#: 4574
2014 Outback 2.5i L
VRP
Wow that is a funny statement. I don't recall ever saying it was junk, broken, or a waste of money. If I look at my post I did say it stabilized my boost which yes is a big help. I no longer ever go over my target of 18 psi, in fact in 3 hours of logging the highest PSI of boost recorded was 17.99 psi which compared to the stock BCS highest was 19.17 psi.
As well what an informative post of possible issues I should look into for the reason I need no change in WGDC.
-Rene
Old 08-15-2007, 11:04 AM   #248
x99percent
Member#: 27108
2004 STi
2004 A4
That's why you should taper the WGD down from the 90-100% columns, and not use a huge gain value. That way, the UTEC simply won't have the authority to hit full boost at part-throttle.
Old 08-30-2007, 10:48 AM   #249
paktinat
Member#: 155025
2004 WRX
for anyone looking into this here is a graph showing the improved spool with the GM BCS
three setups were
stock BCS + free XPT stage 2 map
GM BCS + Ziggy's free stage 2 map
GM BCS + $77 XPT map
this is 3rd gear WOT
paktinat is offline   Reply With Quote
Old 08-30-2007, 11:07 AM   #250
Hyper
Member#: 15822
1999 WRB GM6
2.12cc V9 Type RA
-Rene
so is this "normal?"
I've been reading everywhere that I need to drop WG, but my case has been exactly the opposite...
top - initial and max WG STOCK
bottom - initial and max WG ADJUSTED for Prodrive 3 port
when left at stock WG map, the boost was only able to climb to 14psi!
I also used hoses from the stock solenoid
I got the unit (prodrive 3 port) used from a fellow member, could it be faulty? If it was, would it be boosting at all?
Hyper is offline   Reply With Quote
DIY: Bypass Nav '08 (56k Warning) snwbdr94 Car Audio, Video & Security 18 03-02-2008 05:13 PM
Turbo XS Gasket Damaged? (a few large pics; 56K warning) lethal.adv Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 2 03-24-2006 07:13 PM
thread link to gm solenoid boost install moorebl Engine Management & Tuning 0 08-30-2005 02:33 PM
NASA AutoX Pics 5-23-04 (heavy 56K warning) InfamousDX Tri-State Area Forum 20 05-24-2004 11:52 PM
