Old 08-30-2007, 11:38 AM   #251
Rene2.5RS
Member#: 4574
2014 Outback 2.5i L
VRP
Originally Posted by Hyper View Post
so is this "normal?"
I've been reading everywhere that I need to drop WG, but my case has been exactly the opposite...
top - initial and max WG STOCK
bottom - initial and max WG ADJUSTED for Prodrive 3 port
when left at stock WG map, the boost was only able to climb to 14psi!
I also used hoses from the stock solenoid
I got the unit (prodrive 3 port) used from a fellow member, could it be faulty? If it was, would it be boosting at all?
This is what I have done with mine. Is it normal I have no idea. Like you said everyone says lower you WGDC by 25-30% and start tuning from there. I saw almost no need to lower DC and raise them in certain areas.
I also went with 5/32" silicone vacuum line.
The screen shot top to bottom is:
1. Pre-GMBCS - 18psi tapering to 10psi at redline
2. My First working revision - 18psi tapering to 10psi at redline
3. My current map - 20psi tapering to 13psi at redline
-Rene
Rene2.5RS is offline   Reply With Quote
Old 08-30-2007, 12:19 PM   #252
06rexwagon
Member#: 114730
2006 WRX Limited Wag
[email protected]
If you used the stock hoses chances are you don't have it hooked up right. Read the directions again.
06rexwagon is offline   Reply With Quote
Old 08-30-2007, 12:37 PM   #253
Hyper
Member#: 15822
1999 WRB GM6
2.12cc V9 Type RA
I don't have the restrictor pill in.... there are just 3 hoses, all connected according to this site
what could be installed wrong?
Hyper is offline   Reply With Quote
Old 08-30-2007, 12:42 PM   #254
06rexwagon
Member#: 114730
[email protected]
Did you use the stock T fitting? If you used stock lines I don't see how you could have hooked it up right. Maybe I'm wrong.
Old 08-30-2007, 12:45 PM   #255
Hyper
Member#: 15822
1999 WRB GM6
2.12cc V9 Type RA
of course not
I disconnected the T part and just used the long hose to reach turbine, used intake hose to connect to WG, used another hose I had somewhere to connect to intake
Old 08-30-2007, 02:17 PM   #256
Superorb
Member#: 135252
2002 WRX Wagon
86% Operational :(
Originally Posted by paktinat View Post
for anyone looking into this here is a graph showing the improved spool with the GM BCS
three setups were
stock BCS + free XPT stage 2 map
GM BCS + Ziggy's free stage 2 map
GM BCS + $77 XPT map
this is 3rd gear WOT
What's this free Ziggy GM BCS map you speak of? I need something for when I stick the GM BCS on before I sink $80 on a map.
Superorb is offline   Reply With Quote
Old 08-30-2007, 02:45 PM   #257
paktinat
Member#: 155025
2004 WRX
http://www.xpttuning.com/osecuroms/viewtopic.php?t=528
for the '04, dont see one for your '02
paktinat is offline   Reply With Quote
Old 08-30-2007, 10:50 PM   #258
Superorb
Member#: 135252
2002 WRX Wagon
86% Operational :(
Figures. Thanks anyways
Old 08-30-2007, 10:58 PM   #259
paktinat
Member#: 155025
2004 WRX
Get the XPT map, you will be very happy.
I am.
Old 08-31-2007, 09:36 AM   #260
Superorb
Member#: 135252
2002 WRX Wagon
86% Operational :(
I am.
$80 for a map right now is a bit much when A/C needs to be fixed ASAP. Gotta save save save
Old 08-31-2007, 03:05 PM   #261
silver_rocket
Member#: 123118
2004 STi Silver
Not Stock
So, at what point would an 04 STi need an after market Boost Control Solenoid???
Originally Posted by fmowry View Post
Because it's an issue that didn't exist with the 04s
"The 02-04 pills allowed for pretty good boost control (thus why I had never needed it), but now, if it's an '05, or one who lost their pill, we simply just install these and tune them."
It's catching on with me because I'll be running more boost with alky on my green. Currently the stocker is fine.
Frank
silver_rocket is offline   Reply With Quote
Old 08-31-2007, 03:19 PM   #262
KAX
Member#: 63292
2000 Subaru 2.5RS
2002 WRX powered
ive been having problems with my setup with boost fluctuation. It acts like its overboosting but it isnt. The WGDC will go up and down along with the boost, but its not going over my 20.67 psi that I have it set at.
Code:
A/F	Load	RPM	IAM	Timing	Knock	PSI	MAF	WGDC	Throttle
11.25	3.31	3966	12	17.5	7	8.56	110.88	52.55	100
11.25	4.09	4312	12	15	7	13.49	142.13	57.25	100
11.25	5.01	4581	12	9.5	7	19.88	195.18	54.9	100
11.25	4.78	4908	12	10.5	7	20.6	194.41	47.84	100
11.25	4.43	5112	12	12.5	7	17.12	190.41	54.51	100
11.25	4.72	5411	12	12	7	17.27	215.29	55.29	100
11.25	4.75	5712	12	11.5	7	18.57	224.72	54.51	100
11.25	4.64	5952	12	12.5	7	17.56	229.23	53.33	100
11.25	4.48	6239	12	15.5	7	16.69	231.7	51.37	100
11.25	4.39	6432	12	15.5	7	15.96	228.41	49.8	100
11.25	4.28	6550	12	15.5	7	15.53	234.67	48.24	100
11.25	4.13	6720	12	16.5	7	15.09	237.68	47.45	100
11.25	0.46	7069	12	17.5	6.5	14.51	235.95	42.35	0
14.59	3.66	6438	12	19.5	3	3.48	172.08	42.35	100
11.25	4.78	5016	12	10.5	7	16.4	198.98	52.55	100
11.25	4.86	5190	12	10.5	7	19.88	211.67	48.63	100
11.25	4.62	5241	12	11.5	7	18.28	204.75	52.94	100
11.25	4.81	5308	12	11	7	17.99	215.29	55.69	100
11.25	4.93	5610	12	10.5	7	19.01	229.64	54.12	100
11.25	4.81	5630	12	11	7	18.72	225.54	53.33	100
11.25	4.77	5756	12	11.5	7	17.99	228.82	52.94	100
11.25	4.67	5850	12	11.5	7	17.85	228.82	52.16	100
11.25	4.65	5952	12	12.5	7	17.56	234.67	51.37	100
11.25	4.61	6102	12	12.5	7	17.27	233.38	50.2	100
11.25	4.52	6208	12	13	7	16.98	233.81	49.8	100
11.25	4.47	6292	12	15	7	16.69	233.81	49.02	100
if you look, it does have the wastegate doing one dip, but i did that because it helped the fluctuation. its worse when i have it going straight down.
KAX is offline   Reply With Quote
Old 09-05-2007, 03:12 PM   #263
Freon
Member#: 88322
2009 BMW 135i
Your proportional is too aggressive. Multiply all the values by about 0.7. If that doesn't get rid of it, also multiply your integral maps by 0.8.
The stock shape of the map is fine, it's just the values need to be calmed down because the interrupt BCS is more reactive. Smaller changes in duty make bigger changes in boost.
Freon is offline   Reply With Quote
Old 09-05-2007, 03:24 PM   #264
KAX
Member#: 63292
2000 Subaru 2.5RS
2002 WRX powered
so i need to bring down my duty cycles percentages? wont that hurt me by not making target boost?
Old 09-05-2007, 03:56 PM   #265
Freon
Member#: 88322
2009 BMW 135i
PROPORTIONAL TURBO DYNAMICS. It's too HOT. Too AGGRESSIVE.
If your proportional looks like this:
Code:
-5, -2, -1, 0, 1, 2, 5
You'd do something like this:
Code:
-3.5, -1.5, -0.75, 0, 0.75, 1.5, 3.5
See what I'm getting at here? This is NOT the same as lowering your wastegate duty! It's just the reactionary, closed loop feedback controls.
Do NOT change the row header values (the top row, the boost error values). Just the bottom row.
Give it a shot. It should fix your problem. Try doing that to proportional first. If you still have oscillation, do it to integral as well.
Old 09-05-2007, 07:45 PM   #266
KAX
Member#: 63292
2000 Subaru 2.5RS
2002 WRX powered
ok. i see proportional gain and proportional continuous (im guessing continuous is integral?)
im not down with the lingo yet
Old 09-05-2007, 08:15 PM   #267
Freon
Member#: 88322
2009 BMW 135i
Yeah they could be mislabeled. You might want to make sure you're on the lastest version of Enguinity and the latest defs. I thought Tea Cups/Merch God renamed them back.
They really are proportional and integral. It's a standard closed loop controller type called "Proportional Integral Derivative controller" though we don't get a derivative term (generally not needed if your system is setup right). You can find an abundance of information online about them, or get a book on control theory.
You might want to go back and read some of my posts in this thread. I've written about these issues a lot.
Old 09-05-2007, 08:23 PM   #268
KAX
Member#: 63292
2000 Subaru 2.5RS
2002 WRX powered
will do, thanks for the help!
Old 09-10-2007, 03:21 AM   #269
WRB04
Member#: 153304
very informative post!
WRB04 is offline   Reply With Quote
Old 09-25-2007, 12:48 AM   #270
wuuusaa
Member#: 92894
2015 Wrx
subcribed i like this thread
Old 09-25-2007, 12:57 PM   #271
Superorb
Member#: 135252
2002 WRX Wagon
86% Operational :(
Is there an 02 GM BCS XPT map for 93 octane, or only 91? Anyone know?
Old 10-08-2007, 11:26 AM   #272
Grayguy
Member#: 147371
I've been though the thread, and I still dont' quite understand the wiring. I'm wiring this to a LINK LEM Ecu. So am I understand this right: one wire from the BCS harness goes to my ECU, and the other just goes to a ground?
Grayguy is offline   Reply With Quote
Old 10-08-2007, 12:18 PM   #273
Jager_Addict
Member#: 129230
04 STi, V8 RX-7
You should hook up both wires to the existing ones. Thats what I did. No problems yet.
Jager_Addict is offline   Reply With Quote
Old 10-08-2007, 03:21 PM   #274
Freon
Member#: 88322
2009 BMW 135i
I wrote the FAQ with the stock ECU in mind.
The solenoid needs to be fed with a 12v pulse-width modulated signal. Same type of signal as the stock soleniod. It would be hooked up the same if there are instructions for hooking up the stock solenoid.
Old 10-08-2007, 07:32 PM   #275
Grayguy
Member#: 147371
well I guess that's the issue then, I don't know how the stock one is wired. Let the searching begin....
DIY: Bypass Nav '08 (56k Warning) snwbdr94 Car Audio, Video & Security 18 03-02-2008 05:13 PM
Turbo XS Gasket Damaged? (a few large pics; 56K warning) lethal.adv Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 2 03-24-2006 07:13 PM
thread link to gm solenoid boost install moorebl Engine Management & Tuning 0 08-30-2005 02:33 PM
NASA AutoX Pics 5-23-04 (heavy 56K warning) InfamousDX Tri-State Area Forum 20 05-24-2004 11:52 PM
