Welcome to the North American Subaru Impreza Owners Club Sunday August 28, 2016
Old 10-12-2007, 06:31 PM   #276
jonnies
Member#: 84430
2006 wrx
i just looked as how my GM solenoid is installed and its a bit different from what this threads says....
here it shows this:
Port 1: To turbocharger, or optionally another line on the charge air side.
Port 2: To wastegate
Port 3: Back into intake, after the MAF.
and mine is installed as this
Port 1: To wastegate
Port 2: To turbocharger, or optionally another line on the charge air side.
you see port 1 and 2 are switched....is there any problem/ difference????
thanks
jonnies is offline   Reply With Quote
Old 10-12-2007, 07:04 PM   #277
Thormix
Member#: 118150
04 Wagon XPT HTA68
Check your Wastegate Duty cycles in your Data Logging Program and if it is hooked up backwards you will know it right away. (ie 0% Duty Cycle)
The boost will be controlled by the throttle and will build uncontrolled as the Wastegate will never open.
Thormix is offline   Reply With Quote
Old 10-12-2007, 07:17 PM   #278
jonnies
Member#: 84430
2006 wrx
im sorry for the dumb question...but when i should see 0???when i go wot, my waste gate goes to 94,6%, so is it good??
Old 10-12-2007, 07:39 PM   #279
Thormix
Member#: 118150
04 Wagon XPT HTA68
No a stupid questions lol. Yes if your seeing Wastegate duty you should be ok. What are your boost levels at WOT in 3rd gear. Are you hitting your target boost for your custom Map?
Old 10-12-2007, 08:27 PM   #280
KAX
Member#: 63292
2000 Subaru 2.5RS
2002 WRX powered
a duty cycle of 0% would mean it opens at the spring pressure, not that it stays shut. the higher the duty cycle, the harder its trying to stay shut.
but 94.6% is really high, see what happens when you switch ports 2 and 3, it should drop dramatically.
KAX is offline   Reply With Quote
Old 10-12-2007, 08:45 PM   #281
jonnies
Member#: 84430
2006 wrx
sorry still didnt get it.....are you saying that i should change port 2 with port 3? or i can leave it do way it is??or should i chande port 1 with port 2?
im having a little bit of trouble to reach my target boost...
thanks
Old 10-12-2007, 08:53 PM   #282
KAX
Member#: 63292
2000 Subaru 2.5RS
2002 WRX powered
oh im sorry, switch 1 and 2, whichever were mixed up. you cant reach target boost because your solenoid is pretty much maxing out trying to keep it shut, but it cant. thats what the 94.6% means.
Old 10-13-2007, 12:45 AM   #283
jonnies
Member#: 84430
2006 wrx
thanks mate!
Old 10-13-2007, 01:06 AM   #284
Thormix
Member#: 118150
04 Wagon XPT HTA68
sorry dude I think I got my duty cycles backwards. I must be working too hard. Just listen to what KAX said!
Old 11-05-2007, 11:42 AM   #285
vanchysti
Member#: 108063
HI People!
Recently I installed a Profec B spec 2 on my Sti, but i didn't how to tune it. It seems that is not spooling enough in both low and high. I don't know if a missed something in the installation. My parameters are
low
set 30%
gain 12%
set gain 10psi
high
set 42%
gain 15%
set gain 14psi.
However, it did not reach more than 10 in low. The car started to pullback and push and my blow off started to go on and off. I dont' know is it for the fuel cut defenser or my blow off is leaking. Can anybody help me on this?
vanchysti is offline   Reply With Quote
Old 11-05-2007, 11:59 AM   #286
Superorb
Member#: 135252
2002 WRX Wagon
86% Operational :(
Originally Posted by vanchysti View Post
HI People!
low
set 30%
gain 12%
set gain 10psi
high
set 42%
gain 15%
set gain 14psi.
Was everyhting working fine before the Profec?
Superorb is offline   Reply With Quote
Old 11-06-2007, 05:11 AM   #287
vanchysti
Member#: 108063
Everything was ok before it. There is a couple of question when I installed the profec. I cap off the stock solenoid but i kept connected to avoid the CEL turn on. I don't know it is affect something.
Old 11-06-2007, 11:25 AM   #288
alexmccann33
Member#: 132309
2004 STi
Black on Gold
This is a great write up, but I have a question (or two)...
I noticed some people specifically mentioning 2004 models; is there something different about them regarding the boost solenoid? I am getting a stage 2 protune using a V1 Accessport (for my 2004 STi) in a couple weeks and my buddy said to get a GM boost solenoid and install it right before the tune. Is this a worthwhile mod (my only power mods are catless TBE and the Accessport)?
Thanks in advance...
Alex
alexmccann33 is offline   Reply With Quote
Old 11-06-2007, 12:50 PM   #289
Freon
Member#: 88322
2009 BMW 135i
I guess I'd ask whomever is tuning the car whether they want you to put the new solenoid on or not. If they're ok tuning for it, do it. You might get some minor gains on boost threshold down low, maybe slightly less lag. It's not huge on a stock turbo, but it is also a really cheap mod.
Freon is offline   Reply With Quote
Old 11-17-2007, 09:00 PM   #290
Hyper
Member#: 15822
1999 WRB GM6
2.12cc V9 Type RA
I am still researching the issue of "lazy boost" in my car
22psi @ 4000, that's with a vf36 twinscroll!
I have prodrive solenoid in, along with stronger actuator and I had to RAISE WG duties to hit targeted boost
nobody has an answer for that one, so I will move on to next question
COBB site seems to contradict itself, while showing this diagram
it then says:
3-Port EBCS Internal Wastegate Set-up, Interrupt-type
For the mechanical set-up you will need one vacuum line plumbed from the turbo compressor housing (pressure source) to the pressure inlet port. If you blow through this port you should notice that air is coming out of one of the other two ports . Attach a 2nd vacuum line from the port which air comes out to the intake system, prior to the compressor inlet and after the air filter. A 3rd vacuum line should be connected from the 3rd port of the solenoid to the wastegate actuator. This set-up uses a 3-port electronic boost control solenoid valve to interrupt the air stream to the wastegate actuator. This set-up usually does not employ a restrictor pill which is located in the vacuum line just between the compressor housing and the solenoid valve, although a restrictor pill can be used here to help increase minimum WG pressure.
So following the above, I would have to connect the WG to where the intake port (as per the diagram above)
So which way is correct for interrupt?
I did a test (all ports below are as per the diagram above)
car off - blow through WG port, air comes out of compressor port
car on (just on, but not running) - blow through WG port, air comes out of compressor port! :???: Isn't it supposed to switch?
Checked voltage, the solenoid is getting 12v on BOTH wires with the car ON (but not running)
Can someone shine some light over this?
Hyper is offline   Reply With Quote
Old 11-18-2007, 01:04 AM   #291
Freon
Member#: 88322
2009 BMW 135i
None of what you posted is wrong. Yes, you see 12v on both solenoid terminals. It is ground switched, so you see 12v on both sides unless the solenoid is actually actively being used. (Even then, it is PWM and it will be hard to gauge its activity with a volt meter.) And thus, the air passage is not changed. Put the volt meter down, you don't need it.
I'm not sure what you're trying to do with your tests. None of them tell you what you need to know. I explained in the first post how to identify the ports. Hook up the solenoid to the battery so it gets 12v and ground directly for testing. Look at post #1 so you can test the ports by blowing through them either hooked up to the battery (energized), or unhooked (at rest).
The Cobb stuff you posted is for a different solenoid than yours. Either way, post #1 explains how to identify the ports on any brand 3 port solenoid.
Old 01-09-2008, 08:57 AM   #292
ownnij
Member#: 70459
2002 AW Bugeye ej257
6spd, GT3076R, Alky & EWG
I have a question.. i have a FP18g and the vacuum nipples on the turbo are larger then the stock ones and i'm trying to install the gm bcs. should i use a bigger hose and then use a reducer to use the smaller hoses? i also have the utec ABC, should i take that off when i install this? i have a utec for EM.
ownnij is offline   Reply With Quote
Old 01-09-2008, 12:36 PM   #293
Superorb
Member#: 135252
2002 WRX Wagon
86% Operational :(
Test post.
Old 01-24-2008, 11:20 AM   #294
subi_rex
Member#: 115095
test good! I have a STG1 Vishnu setup. It runs 18psi in 3rd gear at WOT. Boost comes on later in the RPM range. Would adding a a GM BCS help with this setup?
subi_rex is offline   Reply With Quote
Old 01-24-2008, 11:50 AM   #295
a6n6d6y
Member#: 123347
1993 POS
burgandy legacy
you will need a retune for it work right
Quick word on tuning:
This will make your current boost map OBSOLETE. You must retune boost. If you have no way to tune your boost map, you should NOT do this mod
a6n6d6y is offline   Reply With Quote
Old 02-06-2008, 07:36 PM   #296
bucket7788
Member#: 124263
2004 WRX Wagon
RomRaider + UTEC Tuned
This mod is freakin A awesome! Boost builds much more quickly and will go much higher than the stocker will allow.
I reduced WGDC by 30%. That wasn't enough. I still got spikes >2psi above the set point. I'll lower them a bit more before taking my next set of logs. I'm also lowering the values of the Turbo Dynamics Continuous table a bit.
Regarding the noise. I can't hear it. I mounted it using the stock rubber grommet. I ground out the hole in the GM part to accept the grommet and it works fine that way. No clicking whatsoever. Here are a couple of pics...
Thanks Freon! You rock!
Buck
bucket7788 is offline   Reply With Quote
Old 02-07-2008, 12:52 PM   #297
Superorb
Member#: 135252
2002 WRX Wagon
86% Operational :(
I didn't use the grommet, and I hear NO clicking ever. It does build boost sooner and more quickly and hold it closer to redline.
Old 02-14-2008, 09:52 AM   #298
80884
Member#: 56783
2004 sti
Aspen white
I'm going to do this soon. Stage two car right now with custom map running 18psi tapering to 12psi, I pretty much have it set to die after 6k.
Getting the ebay front mount kit this week and going to buy the gm solinoid and put it all on the same time. I might just try the ots cobb stage 2 map and see where it goes, lol, I'm looking to run 20 psi till 5500 then cut it to 14 after that. Just curious to see how high it is going to go with the ots map, don't worry, I won't blow the car up. If it hits 20psi i'm letting out of it.
I guess it's time to get the wideband out and have some fun this weekend
Thanks for the write up OP. T taps FTW
80884 is offline   Reply With Quote
Old 02-14-2008, 10:34 AM   #299
Superorb
Member#: 135252
2002 WRX Wagon
86% Operational :(
If you only use the Cobb OTS map with the GM BCS and FMIC, you're gonna blow something up. I've never heard of a Cobb OTA map for GM BCS, so be prepared to tune the WG duty cycles and other things for the FMIC.
Old 02-14-2008, 01:30 PM   #300
80884
Member#: 56783
2004 sti
Aspen white
I'm prepared to make all nessesary adjustments to anything that is going to need adjusted after the install of these parts.
I'm sure the fuel maps will need work, boost mapping will need redone and some other things will need to be changed. I'm prepared to do this stuff.
I know the OTS map isn't going to work, but it's where i'm starting out.
DIY: Bypass Nav '08 (56k Warning) snwbdr94 Car Audio, Video & Security 18 03-02-2008 05:13 PM
Turbo XS Gasket Damaged? (a few large pics; 56K warning) lethal.adv Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 2 03-24-2006 07:13 PM
thread link to gm solenoid boost install moorebl Engine Management & Tuning 0 08-30-2005 02:33 PM
NASA AutoX Pics 5-23-04 (heavy 56K warning) InfamousDX Tri-State Area Forum 20 05-24-2004 11:52 PM
