Old 02-14-2008, 10:55 PM   #301
Superorb
Member#: 135252
2002 WRX Wagon
86% Operational :(
Originally Posted by 80884 View Post
I'm prepared to make all nessesary adjustments to anything that is going to need adjusted after the install of these parts.
I'm sure the fuel maps will need work, boost mapping will need redone and some other things will need to be changed. I'm prepared to do this stuff.
I know the OTS map isn't going to work, but it's where i'm starting out.
You could always pick up a tactrix cable and a $70 map for your mods
Superorb is offline   Reply With Quote
Old 02-15-2008, 09:20 AM   #302
80884
Member#: 56783
2004 sti
Aspen white
I have the cable. $70 for a map that was tuned for my car would be great. $70 for a more aggressive OTS map isn't what I want. I'm going to get it close and safe to drive then it's off to dyno land for some fine tuning.
I will see this weekend how much effect this front mount has on the current boost and that will help with the re working of the boost map for the new bcs.
Wish AEM wasn't so dam expensive
80884 is offline   Reply With Quote
Old 02-15-2008, 04:54 PM   #303
Superorb
Member#: 135252
2002 WRX Wagon
86% Operational :(
Well buddy, the Cobb AP cost MUCH more than any OTS XPT maps would ever cost. I'm running a map with the GM BCS and stage 2. Only thing different is the FMIC. Good luck.
Old 02-18-2008, 09:53 AM   #304
80884
Member#: 56783
2004 sti
Aspen white
IMHO the cobb ap is too much money for the accesability you have but oh well. I installed the intercooler over the weekend and on the current map boost has not changed. Kind of wierd but it will all come out in the end.
I'll keep you updated on what I do. Running pretty good on 18psi with the front mount.
Old 02-26-2008, 03:45 PM   #305
Rodwrx23
Member#: 170948
Just got mine from Fedex today. So the general concensus is 5/32" vacuum hose? Just want to make sure before I go to Autozone or NAPA.
Rodwrx23 is offline   Reply With Quote
Old 03-08-2008, 05:06 PM   #306
B-RAD_STI
Member#: 172717
2005 WRX STI
I ordered the solenoid and pigtail kit. I have to wait untill tuesday to get the parts. After I install the parts, how bad will it drive? Could i drive it to the dyno shop?
B-RAD_STI is offline   Reply With Quote
Old 03-08-2008, 06:40 PM   #307
Superorb
Member#: 135252
2002 WRX Wagon
86% Operational :(
Stay completely out of boost or everything will be way wonky. Someone had posted a how-to rough tune to get to the tuner. You might want to search this thread for that info else the tuner might have a hard time unless they're familiar with adjusting the WG duty cycle.
Old 03-08-2008, 09:23 PM   #308
B-RAD_STI
Member#: 172717
2005 WRX STI
Thanks. My tuner said he knows how to tune with the solenoid. I just have a 20 mile drive to get there. As long as I dont drive like an idiot with an untuned car i should be fine.
Old 03-09-2008, 06:01 AM   #309
Rene2.5RS
Member#: 4574
2014 Outback 2.5i L
VRP
You could also run one of the vacuum lines directly from the compressor nipple to the wastegate for the drive and when you get to the tuner hook the lines up correctly so you won't have to worry about it.
You will be running only wastegate spring boost on this setting so if you still have the vf39 you will run roughly 6-12psi max
-Rene
Rene2.5RS is offline   Reply With Quote
Old 03-09-2008, 08:42 PM   #310
B-RAD_STI
Member#: 172717
2005 WRX STI
good idea, thanks rene2.5
Old 03-16-2008, 05:25 PM   #311
SpADeZ_WRX
Member#: 160871
Anyone try running this setup on their 06-07 WRX with the XPT Race Map VF39 Setup??
Im about to get my GM BCS and looking foward to holding boost!!
SpADeZ_WRX is offline   Reply With Quote
Old 03-16-2008, 05:53 PM   #312
Bullwinkle1983
Member#: 172332
2006 WRX
You're going to need a GMBCS specific map. I am unsure if Braden makes one, but there is no way you'll be able to run a map tuned for the stock BCS.
Bullwinkle1983 is offline   Reply With Quote
Old 03-17-2008, 09:54 AM   #313
Superorb
Member#: 135252
2002 WRX Wagon
86% Operational :(
He makes a vf39 GMBCS map; I've got it now
Old 03-18-2008, 03:57 AM   #314
SpADeZ_WRX
Member#: 160871
How do you like that map?? Espcially running with the GM BCS??
Old 03-18-2008, 11:13 AM   #315
Superorb
Member#: 135252
2002 WRX Wagon
86% Operational :(
I'm just using the GMBCS stg 2 map right now since I sold all my turbo stuff. Waste of money that was since I've got the map but will never use it.
I like it, power is pretty smooth except from 2k-3k where I've got jumpiness, but I'm having some hesitation not related to the map. Not sure what it is either. The BCS holds boost to redline, and boost builds MUCH quicker.
Old 03-20-2008, 05:15 PM   #316
Rodwrx23
Member#: 170948
Rockauto sent me this discount code 955559843702 on 3/13. Thought I'd share it with the community for anyone who hasn't swapped to the GM BCS yet.
Rodrigo
Old 03-20-2008, 08:29 PM   #317
007WRX
Member#: 125884
06 Evo IX MR Black
76 Datsun ZZZZZZZ
Anyone using this with a cobb map? Do I get rid of the restrictor pill when I install one of these? Do I have to have something changed with the cobb map?
007WRX is offline   Reply With Quote
Old 03-20-2008, 11:20 PM   #318
subygirl8330
Member#: 113715
1998 wrsx RBP
www.newenglandsubarus.com
You use straight line with the GM, no restrictor pill, and yes your map will have to be modified
subygirl8330 is offline   Reply With Quote
Old 03-21-2008, 10:20 AM   #319
Superorb
Member#: 135252
2002 WRX Wagon
86% Operational :(
Old 03-21-2008, 10:23 PM   #320
007WRX
Member#: 125884
06 Evo IX MR Black
76 Datsun ZZZZZZZ
Hmm ok. How would I go around to getting an alternate map? I don't have the street tuner or know anything about that.
Old 03-22-2008, 01:18 PM   #321
80884
Member#: 56783
2004 sti
Aspen white
Take it to someone that knows how to tune it.
Just got one of these... $31.74 w/ the pigtail. Buddy works at dealership.
Old 03-23-2008, 01:23 AM   #322
daveyboy
Member#: 35419
note-- I think that the actual part number is 0199752, not 199752.
daveyboy is offline   Reply With Quote
Old 04-02-2008, 09:50 PM   #323
sbooker
Member#: 176384
2007 sti
white
I'm having one of these installed next week - hopefully it'll provide a more solid boost line than the stock 2 port.
sbooker is offline   Reply With Quote
Old 04-02-2008, 10:23 PM   #324
Superorb
Member#: 135252
2002 WRX Wagon
86% Operational :(
Hope you have some tuning to go along with it.
Old 04-06-2008, 11:47 PM   #325
kh15
Member#: 132400
forgive me in advance if this is a noobish question but why not just use a bleed type mbc to help eliminate boost spike? I know that mbc are often thrown on cars for people who just want more boost and dont realize the effects of raising boost without properly tuning other aspects of the engine but if you work with a tuner and tune your car with a mbc i dont see why it wouldnt be safe or a good idea?
thanks
kh15 is offline   Reply With Quote
DIY: Bypass Nav '08 (56k Warning) snwbdr94 Car Audio, Video & Security 18 03-02-2008 05:13 PM
Turbo XS Gasket Damaged? (a few large pics; 56K warning) lethal.adv Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 2 03-24-2006 07:13 PM
thread link to gm solenoid boost install moorebl Engine Management & Tuning 0 08-30-2005 02:33 PM
NASA AutoX Pics 5-23-04 (heavy 56K warning) InfamousDX Tri-State Area Forum 20 05-24-2004 11:52 PM
