#376 |
Member#: 6307
NESIC
Vehicle:what I has no car... am carless |
#377 |
Member#: 135252
RMIC
Vehicle:2002 WRX Wagon 86% Operational :( |
Are you having the boost oscillations at stock boost? Does it just spike or does it go up/down constantly WOT 4th gear?
#378 |
Member#: 6307
NESIC
yes and yes
#379 |
Member#: 135252
RMIC
I'm not sure if a GM BCS will fix that. If it's doing it with stock stuff you might have other problems like stock stuff failing.
#380 |
Member#: 144912
SCIC
Vehicle:05 STI OBP |
Does anyone know what's the size of the vacuum line 1/8 or 5/32?
#381 |
Member#: 144436
E. Canada
Vehicle:2007 WRX GRP 1995 Justy GL AWD |
#382 |
Member#: 144912
SCIC
So 4mm is better?
#383 |
Member#: 17256
Vehicle:04 STi Blue w/ custom bug splat |
4mm = 5/32" (well actually 3.96875mm = 5/32")
#384 |
Member#: 144912
SCIC
Thanks for the help guys but now i'm confused about the pill restrictor. Where is that located in the stock set up and am i suppose to use it with the Gm solenoid and where should i put it?
#385 |
Member#: 4574
NESIC
Vehicle:2011 Legacy 2.5i LMT Silver |
If you are using the gm 3 port you no longer need to use the restrictor pill.
-Rene |
#386 |
Member#: 144912
SCIC
Thanks
#387 |
Member#: 144912
SCIC
hey guys, i just installed the solenoid but i couldn't hear it clicking at all. The car at idle would show 20 psi vacuum and it'll boost normally i hooked up the access port and the wg at idle was 0 and was going up and down in percentage depending on throttle the other # besides the percentage was showing for example 0/16, and it went up as i drove 0/20, 0/40. I connected the wires B- black A- yellow
Is this all normal and how can i find out if the solenoid is working or not. Please someone answer me asap because i don't want to drive the car before i'm sure that everything is ok. Last edited by wpwm020; 10-07-2008 at 07:06 PM. |
#388 |
Member#: 88322
Vehicle:2009 BMW 135i |
You cannot see anything in the logger that would directly tell you that new solenoid is working or not is some generic fashion. It has to be tuned. The WGDC you see in the logger the ECU is driving the solenoid, not something coming from the solenoid. You can only log boost and WGDC which is a tuned relationship, not something you can roughly tell working/not working condition. The only thing that might happen is you get a CEL if there is a big electrical problem with the solenoid. Other than that if you double checked your setup, you have to start tuning it and see if you get more than wastegate boost. Start low, general/rough tuning advice already posted, or find someone competent to do it for you.
If you mount it right on the metal bracket and use no rubber grommets it will make it considerably louder. You can also try touching the wires directly to the battery + and - and see if it clicks. I already posted about testing it this way in the first post. You can touch it to the battery and try to blow through it. Where you can blow in and where it comes out will change when it has 12v applied vs. disconnected. |
#389 |
Member#: 144912
SCIC
I connected it to the battery and it was clicking loud and clear. When it was disconnected the air could travel from wg pipe to turbo and the other way around but when it was connected it was getting blocked. I asked my tuner for a map to use until friday when i'll get protuned and the tuner is 100 miles from me.
#390 |
Member#: 152285
International
Vehicle:2004 WRX Rosso |
^^Just in case you do not get the map in time, just keep an eye on your boost gauge and drive around carefully. You do not want to overboost at any time. Given the stock map, boost targets are hit and exceeded pretty easily with the upgraded solenoid, so you wanna keep an eye out for that.
On a slightly off-topic note, I first had Perrin's EBCS installed and tuned with Open Source reflash. When my motor spun its bearings a few months later, the Perrin decided to go south as well. Now I have the GM solenoid in its place, and I can tell you straight away that this unit seems to be much stronger than the Perrin. Boost target is easily hit and exceeded given the map for the Perrin unit. More tuning is in store. |
#391 |
Member#: 80226
South East
Vehicle:2004 WrX AspenCoWhite |
I was just about to install my GM Solenoid and now NO pics. Anyone knows where I could find another good DIY Install, I've tried searching and only got the:
http://www.tarmacwolf.org/dokuwiki/d...boost_solenoid Anything else??? Thanks |
#392 |
Member#: 172332
Vehicle:2006 WRX 18g'd and RomRaided |
#393 |
Member#: 80226
South East
Great, thanks a lot... just what I needed...
#394 |
Member#: 109993
Vehicle:2006 TR E3-16G'ed Running E85! |
My GM solenoid that I installed spring of 2007 is now making a really loud clicking sound between 1700 and 2500 rpm just during daily driving. Is it toast?
#395 |
Member#: 17256
Have you changed your tune lately?
#396 | |
Member#: 4574
NESIC
-Rene |
#397 |
Member#: 94615
Vehicle:|'06 AW VF39 STi| |AgileTuned:341WHP/356TQ| |
subscribed
#398 |
Member#: 198089
Vehicle:05 suburu black/black |
keep it up
#399 |
Member#: 147328
SCIC
Vehicle:2007 WRX FlimFlamRacing.com |
Subscribed...
#400 |
Member#: 80500
Vehicle:2002 2.5L WRX Blaze Yellow |
IAG Performance has solenoid for $25
https://www.iagperformance.com/shopp...p?prod=1997152 Summit Racing has wiring connector for $9 http://store.summitracing.com/partde...0&autoview=sku Have both parts in hand and they're compatable. Last edited by LoveRoadRacing; 04-18-2009 at 01:24 PM. |
| Thread Tools | |
| Display Modes | |
| DIY: Bypass Nav '08 (56k Warning) | snwbdr94 | Car Audio, Video & Security | 18 | 03-02-2008 05:13 PM |
| Turbo XS Gasket Damaged? (a few large pics; 56K warning) | lethal.adv | Factory 2.0L Turbo Powertrain | 2 | 03-24-2006 07:13 PM |
| thread link to gm solenoid boost install | moorebl | Engine Management & Tuning | 0 | 08-30-2005 02:33 PM |
| NASA AutoX Pics 5-23-04 (heavy 56K warning) | InfamousDX | Tri-State Area Forum | 20 | 05-24-2004 11:52 PM |
