Old 02-07-2009, 11:45 AM   #401
ogboot
Member#: 170906
psm
Originally Posted by LoveRoadRacing View Post
IAG Performance has solenoid for $25
https://www.iagperformance.com/shopp...p?prod=1997152
Summit Racing has wiring connector for $8
http://store.summitracing.com/partde...0&autoview=sku
Have both parts in hand and they're compatable.
Good find, but IAG doesn't carry them anymore, just called.
ogboot is offline   Reply With Quote
Old 02-12-2009, 09:57 AM   #402
Badmunky
Member#: 143391
2007 WRX TR
R.I.P Paul! :(
Dose any one have a map for a 07 stage 2 WRX with the GM BCS?
I want to add this to my car but have not started tuning just yet all thou I have an AP V2 and street tuner Race so I can tune. Just have not done any tuning yet and it seams most on here are using Utec.
My mods as of now are:
Cobb OTS satge 2 tune.
Titek Catted DP.
SPT catt back.
STI I/C.
SPT intake.
Car runs great so far but I want to prep for a VF39 and a front mount and this looks like a good starting point considering what I already have done to the car.
I also want to learn to tune and am on some other forums for that right now.
Thanks for any help you guys can give me.
Oh and I did read the hole thread!
Badmunky is offline   Reply With Quote
Old 02-12-2009, 10:53 AM   #403
Rene2.5RS
Member#: 4574
2014 Outback 2.5i L
VRP
I am using RomRaider for tuning so I can help you out.
For tuning the GMBCS there are a couple areas you need to pay attention to, but I am unsure of the exact names Cobb uses to describe them, so in RomRaider these are the tables:
-Initial Wastegate Duty
-Max Wastegate Duty
-Turbo Dynamics Proportional
-Turbo Dynamics Integral Positive
-Turbo Dynamics Integral Negative
Once you get a base for your initial and max duty tables then you need to start working on the dynamics tables, I believe I started out by cutting all of these values by 30%. What the dynamics tables do is correct for boost error, which is calculated by 'target boost - actual boost'. Meaning that the negative values in the Proportional and the Integral Negative tables signify over boosting. The Dynamics tables will adjust the duty cycles of the solenoid to achieve target boost. If you do not work on these table you will get a oscillation in boost which I have attached pictures to show. This is because the GMBCS is much quicker to react then the OEM Bleed style. So say when you over boost and it cuts duty cycles too quickly it drops below target, now it starts to add to quickly causing another over boost, all while it is slowly getting closer to target boost.
You can see an example of this more from the 'New Graph.jpg' example. In the image 'log data 4.jpg' what you see there is after the Negative corrections were slowed down so you only see 2 over boost and very little under boost, but that is what you are trying to tune for using the GMBCS. If you want any help just shoot me a PM.
-Rene
Rene2.5RS is offline   Reply With Quote
Old 02-17-2009, 11:28 PM   #404
Greg555
Member#: 814
Want engine mgmnt?
I sell ViPec's ECU's
so who has them cheapest these days?
Greg555 is offline   Reply With Quote
Old 03-10-2009, 09:10 PM   #405
quazimoto
Member#: 70395
IAG performance.GM boosted the price up on these things to $40.Ain't that some sheet....
quazimoto is offline   Reply With Quote
Old 03-11-2009, 11:36 PM   #406
Kjott21
Member#: 116937
2011 WRX DGM
forums.pghsubarus.com
The solenoid is discontinued now from what I have been reading.
Kjott21 is offline   Reply With Quote
Old 03-12-2009, 01:26 PM   #407
quazimoto
Member#: 70395
GM Parts Direct seems to think they can still sell them.
Old 03-12-2009, 02:28 PM   #408
Greg555
Member#: 814
Want engine mgmnt?
I called my local NAPA and GM and they all sell these for $96 + tax
screw that
For $78 I can get MAC valves which are better quality and are used by MoTec, AEM and all major engine management companies.
Greg
Old 04-17-2009, 03:06 PM   #409
Jasonzemos
Member#: 109993
2006 TR E3-16G'ed
Running E85!
The GM solenoid is garbage.
This thread should be locked.
Everyone should switch to a mac valve.
Have a nice day!
Jasonzemos is offline   Reply With Quote
Old 04-17-2009, 03:07 PM   #410
zombiedog
Member#: 25138
85 e30
PRIMERZ!
Troll much?
Thanks for the useless insight.
zombiedog is offline   Reply With Quote
Old 04-17-2009, 03:08 PM   #411
zombiedog
Member#: 25138
85 e30
PRIMERZ!
Old 04-17-2009, 03:46 PM   #412
0db
Member#: 33879
2003 WRX Sporkwagon
screw that
Greg
Do enlighten us how they are better. Or just post a pic and an completely nonquantified claim. Whatever you prefer.
0db is offline   Reply With Quote
Old 04-17-2009, 04:22 PM   #413
Jasonzemos
Member#: 109993
2006 TR E3-16G'ed
Running E85!
Ah, I believe this has already been discussed in other threads. If not, the GM solenoid is too slow, it will cause flutter on both internal and external wastegates (audible with the external ones obviously) which causes shockwaves back through the exhaust gas on to the valves. If you're running this solenoid at low boost/low duty cycle you might not be able to distinguish the flutter. The mac valve on the other hand is faster acting, and maintains a cleaner steady state. I recently switched.
Proof: http://www.youtube.com/watch?v=e67KZeG5Hrk
Old 05-19-2009, 01:34 AM   #414
ndeli55
Member#: 205255
thanks for this thread. good info
ndeli55 is offline   Reply With Quote
Old 06-12-2009, 11:43 PM   #415
dbronste
Member#: 80207
We have a ton of these where I work, for sale. Check out our ebay store: http://cgi.ebay.com/ebaymotors/GM-BO...Q5fAccessories
-Dan
dbronste is offline   Reply With Quote
Old 06-13-2009, 05:49 AM   #416
iluvdrt
Member#: 46248
82 Brat
Tan
What exactly does this able one to do? I am gussing it provides better control over boost pressures using a programmer.
iluvdrt is offline   Reply With Quote
Old 07-08-2009, 01:22 PM   #417
dbronste
Member#: 80207
Old 07-08-2009, 03:59 PM   #418
krambte79
Member#: 97452
05 STi, 02 STi
& 09Ltd Tribeca
anyone here been using the grimmspeed boost solenoid yet
krambte79 is offline   Reply With Quote
Old 07-09-2009, 12:09 AM   #419
motoryder
Member#: 111268
.... MLTMFA2
Originally Posted by dbronste View Post
-bump
Make a for sale thread....don't clog this one.
motoryder is offline   Reply With Quote
Old 07-09-2009, 12:01 PM   #420
GrimmSpeed
Member#: 136396
2015 WRX, 2012 WRX,
2013 BRZ, 2006 STI
there should be about 800 people using it already...at least thats what my sales numbers say
Justin
GrimmSpeed is offline   Reply With Quote
Old 07-09-2009, 12:13 PM   #421
krambte79
Member#: 97452
05 STi, 02 STi
& 09Ltd Tribeca
Justin
i just got one from you too, i just havnt installed and tuned w /it yet. just wondering if anyone had feedback.
Old 09-24-2009, 05:01 PM   #422
udelslayer
Member#: 117214
2003 WRX Wag'n Wagon
You can have.
Rockauto is jacking these up in price?
ACDELCO Part # 214474 {#01997152, 1997152}
$51.79
WTF?
They're prolly all made in China!
udelslayer is offline   Reply With Quote
Old 11-20-2009, 10:57 AM   #423
Dramfase73
Member#: 225608
Dram http://russian-
Dramfase73
Default Full DIY GM solenoid install 56k warning
My check engine light is on p1105 for the fuel pressure solenoid. The stealership here wants 55 for one.
Dramfase73 is offline   Reply With Quote
Old 11-20-2009, 11:10 AM   #424
zombiedog
Member#: 25138
85 e30
PRIMERZ!
I smell troll. ^
Also I'm using the GrimSpeed.
Not even tuned yet and it runs better than OEM. About 10 min install too.
Old 12-04-2009, 03:44 PM   #425
Dramfase73
Member#: 225608
Dramfase73
I got confused of what DIY said about start up map ,when i loaded to megatune I saw that they did almost every thing as a NA m20 with MAF , OK,why they warning us not to drive car ,its just a start up map ,Iam pretty sure that map was much accuret instead of my old one my first lesson of bad tune now the quistion DO I can log those data till 100kpaand keep forced tune the as same as it is ? Iam tryn to make it much smooth ,any opinion?
DIY: Bypass Nav '08 (56k Warning) snwbdr94 Car Audio, Video & Security 18 03-02-2008 06:13 PM
Turbo XS Gasket Damaged? (a few large pics; 56K warning) lethal.adv Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 2 03-24-2006 08:13 PM
thread link to gm solenoid boost install moorebl Engine Management & Tuning 0 08-30-2005 03:33 PM
NASA AutoX Pics 5-23-04 (heavy 56K warning) InfamousDX Tri-State Area Forum 20 05-25-2004 12:52 AM
