Old 06-17-2006, 10:58 AM   #101
FromageTheDog
Member#: 81095
2005 WRX sedan kid-
bus. OS self-tuned!
Originally Posted by sith
hey guys.. i'm just running the stock v7 ecu and no tune in sight, and i need a replacement BCS what subaru BCS will work for a JDM V7 STI? is the 2.5 STi or WRX or LGT BCS the same?
.sith.
A 3-port will operate in bleed (2-port) mode if hooked up that way, at which point it should act just like a stock BCS. Just put a filter over the unused port for safety.
FromageTheDog is offline   Reply With Quote
Old 06-17-2006, 01:29 PM   #102
TommyWRX
Member#: 34882
2003 WRX
Stage 4
Default Wiring this?
So how do you wire this in? I mean power and ground for the solenoid? And Will how do I control it with Utec?
TommyWRX is offline   Reply With Quote
Old 06-17-2006, 02:15 PM   #103
TheMadScientist
Member#: 23717
2005 Big red
You read this thred it tells you how to do everything.
The gm solenoid comes with a filter on it.
TMS
TheMadScientist is offline   Reply With Quote
Old 06-17-2006, 03:23 PM   #104
FromageTheDog
Member#: 81095
2005 WRX sedan kid-
bus. OS self-tuned!
Indeed, and it's a bugger to get off!
Old 06-17-2006, 05:19 PM   #105
rewt
Member#: 60794
2007 Solstice GXP
Thought I'd post this here in case anyone has a similiar experience...
I've been running the GM solenoid for a while. I started running it with an internally gated TD06H/20G, and now, I'm running it with an externally gated SZ55.
My problem:
With the SZ55, boost violently wavers as soon as the gate opens. I know I'm not getting compressor surge since I can clamp the wastegate closed and run boost up to 25psi solidly...
In an attempt to fix the problem, I moved to smaller vacuum lines between the compressor, solenoid, and wastegate; and I have a restrictor in line between the compressor and solenoid. It helped when I was only running 19-20psi, but the problem came back as soon as I started tuning for AI @ 24psi.
At this point, I'm actually looking at moving to a manual boost controller. Before I do that, though, I was wondering if anyone had any other potential fixes. I use a UTEC and boost gain is set to 72 (I've tried values from 50-72 moving up in increments), and my 90% and 100% boost control columns are the same value (325) from 700RPM - 7500RPM.
rewt is offline   Reply With Quote
Old 06-18-2006, 01:51 AM   #106
TommyWRX
Member#: 34882
2003 WRX
Stage 4
TMS
But that just says how to hook up vacuum lines... I'm talking about the pigtails...
Old 06-18-2006, 01:59 AM   #107
WR^2X
Member#: 37617
The GM BCS has two wires... The stock BCS has two wires... There are pictures and wire color information in the first post. How is this hard?
WR^2X is offline   Reply With Quote
Old 06-18-2006, 09:18 AM   #108
TommyWRX
Member#: 34882
2003 WRX
Stage 4
After re-reading I understand. But the hard part is if you don't look at the plug on your own car first
Old 06-19-2006, 12:13 AM   #109
jblaine
Member#: 8512
2002 WRX chassis...
stage-infinity.com
Wait a second. I'm fighting conflicting info I think.
Freon's block diagrams for the 3-port solenoid show:
-- Energized = Wastegate references turbo inlet tube pressure
-- Rest = Wastegate references turbo outlet pressure
Based on that information, I would expect the solenoid to be energized (clicking) at idle just as I am experiencing. That is, when the ECU starts to control boost, it is allowing some 'rest' state to happen. My boost is working perfectly fine with the solenoid clicking at idle.
But TheMadScientist says this is wrong and it should be completely off at idle.
What am I missing or misreading here?
Can people who have this mod please just sound off on whether theirs is clicking at idle (regardless of it being as loud as mine)?
jblaine is offline   Reply With Quote
Old 06-19-2006, 12:23 AM   #110
djerickd
Member#: 3782
02 WRX WFC#040
Clean on 19's
Yeah thats just weird, I want to come see your car!
djerickd is offline   Reply With Quote
Old 06-19-2006, 09:16 AM   #111
TheMadScientist
Member#: 23717
2005 Big red
I have installed a "few" of these, 1 on a stock ECU, a bunch on Utec equiped cars, and some on Cobb ST equiped cars. On the utec if you have anythig but ECU in the 0% column the solenoid will click at idle. On the ST if you have anything but 0 in the WGDC maps and a boost target of vacume in the 0% tps column the solenoind will click. On the stock ECU the solenoid did not click at idle.
Hope that helps.
TMS
Old 06-19-2006, 09:18 AM   #112
djerickd
Member#: 3782
02 WRX WFC#040
Clean on 19's
Good info TMS!
Old 06-19-2006, 09:38 AM   #113
jblaine
Member#: 8512
2002 WRX chassis...
stage-infinity.com
Thanks TMS. Sounds like I need to get hold of Phil.
Old 06-19-2006, 10:23 AM   #114
jblaine
Member#: 8512
2002 WRX chassis...
stage-infinity.com
Solved. Hydra people: Set PWM Map 4 to have 0 in the cell for 0%.
Ahhhhh, no more racket.
Old 06-19-2006, 10:38 AM   #115
djerickd
Member#: 3782
02 WRX WFC#040
Clean on 19's
Awesome! i'm glad you fixed it man!
Old 08-10-2006, 12:09 AM   #116
Irishman
Member#: 29933
2004 STI
Silver/Silver
what size vacuum lines are you running to connect everything? Someone said that thought it was 1/8" but want to make sure I get the right size. I am installing this next week.
Irishman is offline   Reply With Quote
Old 08-10-2006, 10:58 AM   #117
FromageTheDog
Member#: 81095
2005 WRX sedan kid-
bus. OS self-tuned!
1/8" may work but might be a little tight. 5/32" is the typical size.
Old 08-24-2006, 11:05 AM   #118
ahains
Member#: 28823
2004 WRX Wagon
Originally Posted by fmowry
$34.73 shipped from Rockauto. Search on part numbers below
ACDELCO solenoid part # 214474
ACDELCO ABS modulator pigtale part # PT374
Thanks, very helpful!
It looks like the description for # PT374 has changed, but based on the pictures of each part it looks correct. It now says:
ACDELCO Part # PT374
Category: Coolant Level Sensor Connector {2-WAY FEMALE BLACK M/P 150 #12102747}
ACDELCO Part # 214474
Category: Turbocharger {#01997152}
The fatwallet thread has a new discount code good until 8/29 - "451727416688". It's only $1.55 in savings but hey, I'll take it
Saving another $2 by having it shipped to work instead of home (business address is cheaper)
$30.99 subtotal, $5.07 shipping (to business address), $1.55 discount, $34.51 ground total. Paid with my dividend card for 1% cash back, so $34.16 out the door
ahains is offline   Reply With Quote
Old 09-05-2006, 06:03 PM   #119
jdgrimm
Member#: 74386
02- 2.5 Hybrid
GrimmSpeed
just called a gm dealership.
25 for the solenoid, 35 for the pigtails. what a joke. rockauto here i come.
jdgrimm is offline   Reply With Quote
Old 10-07-2006, 03:08 PM   #120
jdgrimm
Member#: 74386
02- 2.5 Hybrid
GrimmSpeed
i'm getting the p0245 boost solenoid A low CEL. anyone know whats up? is it wired wrong? is the resistor broken?
Old 10-07-2006, 03:34 PM   #121
FromageTheDog
Member#: 81095
2005 WRX sedan kid-
bus. OS self-tuned!
I sure hope not -- I selected and wired the resistor in myself, and I always check resistor values with a meter to make sure they're OK before soldering. I should have a bunch more of these resistors; I'll mail some to you if this turns out to be the issue...
Old 10-07-2006, 04:33 PM   #122
jdgrimm
Member#: 74386
02- 2.5 Hybrid
GrimmSpeed
no worries. if it is broke i'll just stop over to radioshack. i just dont get why i'm gettig the error. i completely unplugged it and got the same code as when it is plugged in so i guess it has to be the wiring somewhere.
Old 10-11-2006, 08:51 PM   #123
Freon
Member#: 88322
2009 BMW 135i
jd: I'd try taking the resistor out. You shouldn't need one.
At least make sure your connections to the wires and resistor are solid.
The solenoids should work fine with polarity reversed. +/- doesn't matter as far as I know. It's just a coil of wire inside. I tested it both ways.
Freon is offline   Reply With Quote
Old 10-11-2006, 09:03 PM   #124
DjRez4
Member#: 18155
1985 4runner
AWD Pirates, Unite!
Nice writeup and way to condense that huge thread we had going. Let me tell you how much fun it was to search through huge PDFs of Typhoon wiring diagrams to find that pigtail part number!
DjRez4 is offline   Reply With Quote
Old 10-16-2006, 05:02 PM   #125
markwild
Member#: 121953
I fitted one of these to my UK 02 STI over the weekend, though I soldered the connections to the pins on the solenoid and used 'bullet' terminals to connect to the OEM wiring (Cutting the original connector off). I piped it up to act as a 2 port, pending a mapping session in 4 weeks. Though it was OK for the first 2 days, its now showing a CEL ? Could it be the wiring (I've given it a pull and it seems secure), or is another cause likely ?
Ta,
Mark
markwild is offline   Reply With Quote
DIY: Bypass Nav '08 (56k Warning) snwbdr94 Car Audio, Video & Security 18 03-02-2008 05:13 PM
Turbo XS Gasket Damaged? (a few large pics; 56K warning) lethal.adv Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 2 03-24-2006 07:13 PM
thread link to gm solenoid boost install moorebl Engine Management & Tuning 0 08-30-2005 02:33 PM
NASA AutoX Pics 5-23-04 (heavy 56K warning) InfamousDX Tri-State Area Forum 20 05-24-2004 11:52 PM
