Welcome to the North American Subaru Impreza Owners Club Friday January 30, 2015
Old 02-21-2007, 12:40 PM   #176
ride5000
Member#: 32792
2003 GGA MBP
12.9 / 105+
Originally Posted by IMPREZive 02 WRX View Post
I thought it was supposed to be re-routed to the intake when the solenoid's energized.
When the solenoid's not energized, the intake's blocked off, and when it is energized, the intake is connected to the wastegate if you plumb it the way it's described in the OP.
solenoid on = more boost = block signal from wga
solenoid off = less boost = route signal to wga
it doesn't matter what you do with the other port. block it off.
hth
ken
Old 02-21-2007, 08:17 PM   #177
IMPREZive 02 WRX
Member#: 11436
1999 Impreza RS
eBay racing edition!
I understand that You can achieve that by plumbing it either way, but plumbing it so that the boost signal is diverted to the intake (like the stock setup) instead of blocking it puts less stress on the solenoid. I was just trying to set the record straight for which port does what. I give up, everyone plumb it whatever way you want. I know which way I did mine.
IMPREZive 02 WRX is offline   Reply With Quote
Old 02-27-2007, 02:24 AM   #178
bren wrx
Member#: 59454
'10 E92 M3 M-DCT
brentuning.com/blog
looks like there is more to it then the pigtail and the solenoid
is the vacuum line restrictor and 10ohm a must with a reflash? id rather rock solid boost
bren wrx is offline   Reply With Quote
Old 02-27-2007, 03:02 AM   #179
KAX
Member#: 63292
2000 Subaru 2.5RS
2002 WRX powered
resistor not a must, no.
for vacuum line restrictor, you do not want one at all.
basically you need the solenoid, pigtail and hoses.
KAX is online now   Reply With Quote
Old 02-27-2007, 10:58 PM   #180
B16A2NR
Member#: 88676
How long did it take to recieve your solenoid and pigtail from Rockauto? I purchased mine Feb21st and it still says "awaiting shipment"
B16A2NR is offline   Reply With Quote
Old 02-27-2007, 11:35 PM   #181
xFactor
Member#: 65470
02 Hong Norr Wrx
rock chip red
This mod worked out so well for me.
I had 100% wgdc's only netting me 19.5psi max on a 2 liter vf39 combo. Now 70% wgdc is hitting 20psi in first gear and targeted 22psi @ 4150 in second. Once boost onset occurs, watch that needle swing! No boost hunting or any issues of the sort, even with aggressive turbo dynamics maps.
...and if you drill out the mounting tab a bit and reuse the factory isolator grommet, it's just as quiet as oem.
Good times...
later, x
xFactor is offline   Reply With Quote
Old 02-28-2007, 12:16 AM   #182
06rexwagon
Member#: 114730
2006 WRX Limited Wag
9.8@150
Good times...
later, x
who tuned your car?
06rexwagon is offline   Reply With Quote
Old 02-28-2007, 01:22 AM   #183
KAX
Member#: 63292
2000 Subaru 2.5RS
2002 WRX powered
id say about a week, + or - a day (business days of course)
Old 02-28-2007, 08:56 AM   #184
xFactor
Member#: 65470
02 Hong Norr Wrx
rock chip red
Originally Posted by 06rexwagon View Post
who tuned your car?
Me, with Streetuner.
later, x
Old 03-14-2007, 12:07 AM   #185
TheDaneTrain
Member#: 118092
Sedona Red Pearl
Default XPT stage 2 map
Has anyone run the XPT 2002 stage 2 + GM solenoid map?
http://www.plasmatize.com/xptstore/i...products_id=12
TheDaneTrain is offline   Reply With Quote
Old 03-14-2007, 03:55 AM   #186
0db
Member#: 33879
2003 WRX Sporkwagon
I just ordered it for my 2003... have the map but haven't got the solenoid installed yet. Will post with results.
From what I've seen, there's no real need to put the resistor in, right? Stock ECU is ok dealing with the GM solenoid's lower resistance?
0db is offline   Reply With Quote
Old 03-14-2007, 11:48 PM   #187
blkscooby
Member#: 44422
2009 G8 GT
Cammed, sprayed, stalled
No you do not need a resistor at all. Most of us here running the GM BCS have no resistor installed.
blkscooby is offline   Reply With Quote
Old 03-15-2007, 05:08 AM   #188
0db
Member#: 33879
2003 WRX Sporkwagon
Outstanding, thanks! Just finished installing the GM BCS (somebody slap me for deciding it would be 'easier' not to take the IC out - those vac lines onto the WG and compressor nozzle are NOT fun to get to!)
Going to go flash the XPT Stage 2 w/ GM BCS map and see how she drives!
Old 03-15-2007, 09:51 AM   #189
blkscooby
Member#: 44422
2009 G8 GT
Unless you have a larger TMIC, there is no need to remove the IC to change the lines. If you have a larger TMIC, I can see why it might be an issue.
Old 03-15-2007, 11:58 AM   #190
0db
Member#: 33879
2003 WRX Sporkwagon
ebay tmic - front corner is RIGHT on top of the lines!
all the better for enhanced heat soak at stop lights!
Old 03-15-2007, 10:13 PM   #191
Dr freedom
Member#: 92175
2002 STi
Had my tuner put the solinoid in last week.
Stock controller was running at 95% all of the time, GM one is around 70% .. boost feels a little more stable & than previous now. Hits the target of 21psi with ease.
The stock restrictor is still in place though on the line.
Dr freedom is offline   Reply With Quote
Old 03-16-2007, 12:18 AM   #192
blkscooby
Member#: 44422
2009 G8 GT
You do not need the resistor. But if you are happy with the tune, then leave it. You should be able to run even lower WGDC if the resistor were not installed.
Old 03-28-2007, 04:15 AM   #193
Dr freedom
Member#: 92175
2002 STi
hmm .. might have a little play around then. Should I expect surging or something like that upon initially removing it?
Old 03-29-2007, 03:45 PM   #194
neo-sti
Member#: 101778
2010 Ford Taurus
Company Car
So I went to order the soleniod and the pigtail from rock auto and they said that it won't ship until the 13th of april. Does anyone know where I can get it sooner?
neo-sti is offline   Reply With Quote
Old 03-29-2007, 04:02 PM   #195
06rexwagon
Member#: 114730
9.8@150
Your local GM dealer should be able to get it within a day or 2, but they're around $28 for the solenoid.
Old 03-29-2007, 07:45 PM   #196
Gethin
Member#: 2998
a smaller boost pill size (if you are using the stock bcs) will also allow you to run lower wdc numbers if they are maxed out without switching to the gm unit (but go too small and you risk overboosting).
Gethin is offline   Reply With Quote
Old 04-05-2007, 07:07 PM   #197
scooby2.0t
Member#: 127092
2002 WRX WRB
05 Kawi ZX6R Plasma Blue
ok i read the thread and i dont think this was covered. with the xpt stage 2 and the GM boost control solenoid, is the xpt map tuned for the solenoid?
scooby2.0t is offline   Reply With Quote
Old 04-05-2007, 07:12 PM   #198
cbarth3
Member#: 67249
2004 WRX
there are 2 maps available
XPT Stage 2 - 2002 WRX $52
http://www.plasmatize.com/xptstore/i...&products_id=4
XPT Stage 2 - 2002 WRX w/ GM BCS $77
cbarth3 is offline   Reply With Quote
Old 04-06-2007, 04:57 PM   #199
scooby2.0t
Member#: 127092
2002 WRX WRB
i wasnt sure if those maps were different or not. take it they are though.
Old 04-22-2007, 09:56 AM   #200
dja_rs
Member#: 146538
great writeup
dja_rs is offline   Reply With Quote
DIY: Bypass Nav '08 (56k Warning) snwbdr94 Car Audio, Video & Security 18 03-02-2008 06:13 PM
Turbo XS Gasket Damaged? (a few large pics; 56K warning) lethal.adv Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 2 03-24-2006 08:13 PM
thread link to gm solenoid boost install moorebl Engine Management & Tuning 0 08-30-2005 03:33 PM
NASA AutoX Pics 5-23-04 (heavy 56K warning) InfamousDX Tri-State Area Forum 20 05-25-2004 12:52 AM
