Welcome to the North American Subaru Impreza Owners Club Monday August 29, 2016
Go Back   NASIOC > NASIOC Classifieds > Vendor 'For Sale' Classifieds > Drivetrain
Closed Thread
Old 10-22-2005, 08:26 PM   #1
Gruppe-S
Vendor Sales Rating: (65)
Member#: 23216
2006 949-457-1234
949-457-1234
Default The best pricing on Exedy and ACT. New products for all you Motorsport junkies!!!
Hey all,
We have a couple of new products for you STi guys!
1) JDM 5th and 6th Gear Close Ratio Conversion Kit - 04+ STi
The USDM 6-speed transmission was compromised by stringent US regulations for cruising fuel efficiency. Sacrificed was the close ratio gearing of the JDM 5th and 6th gears. This kit includes shorter 5th and 6th gears to convert your taller USDM 6-Speed Transmission to a true close ratio JDM STi spec gear box; the way it was designed to be. This conversion will be particularly useful for those of you who regularly track or drag race your car. As I'm sure you've noticed, their is a large space in gear ratios between 4th and 5th gears on the USDM 6spd. This oftentimes causes a grinding when shifting from 4 to 5 quickly because the synchros cannot catch up quickly enough to compensate for the large difference between gear ratios. Professional installation is recommended.
- Excellent upgrade for motorsports guys
- Better accelleration in 5th and 6th gear.
- Eliminates grinding when shifting up from 4th to 5th gear
- Restores 6 spd. to intended gearing
Ratios:
-5th Gear - 1.062 (0.971 stock)
-6th Gear - 0.842 (0.756 stock)
$319 Shipped for 5/6th Gear Conversion
$769 for rebuild w/ 5/6th Gear Conversion
2) Genuine Subaru Synchro & Bearing Kit for 6 Speed Manual Transmission (13 pcs) - 04+ STi
We have packaged together the most commonly damaged synchros and bearings for the Subaru STI 6-speed transmission. In all likelihood, if a transmission rebuild is necessary, these synchros and bearings also need to be replaced. Replacing these synchros and bearings can also cure many "mystery" gear box issues such as, "why does my tranny always grind going into 3rd gear," or "how come I sometimes can't shift down into 2nd gear." These are in stock and ready to ship. You can also send us your 6spd. to be rebuilt with these.
- Should be replaced when rebuilding your tranny
- Cures many transmission gremlins
$419 Shipped for Synchro and Bearing Kit
$869 for rebuild w/ new Bearing and Synchro Kit
Save money if you do both at the same time!
$719 Shipped for Synchro and Bearing kit, and 5/6th Spd. Conversion
$1149 for rebuild w/ new Bearing and Synchro Kit, and 5/6th Spd. Conversion
We also have 1 6spd. in stock ready to ship! We rarely ever get these in this kind of condition. This thing is cherry!
6-Speed Transmission Non-DCCD Fully rebuilt
SOLD!
-Fully rebuilt
-New synchros
-New bearings
-USDM gears
-Low Mileage
-The best streetable tranny for high power WRX motors
Please contact us for ordering information!
Thanks,
Preston
Phone: (510) 783-5300
We Accept Paypal!
Paypal: [email protected]
When ordering w/ paypal, please include the following:
product name: XXXX
sales rep: Preston/Geoff
Price including shipping: $XXXX
Shipping address.
Gruppe-S is offline
Old 10-22-2005, 08:32 PM   #2
Gruppe-S
Member#: 23216
2006 949-457-1234
949-457-1234
1) ACT HD Street Disc Kit and Steetlite Flywheel - 02+ WRX
-Torque Capacity: 411 lbs/ft.
-Pressure Increase: 32% over stock clutch.
-Weight: clutch - 17lbs, flywheel - 13.9 lbs.
$649 Shipped!!!
$1100 Installed!!!
2) ACT HD Street Disc Kit and Prolite Flywheel - 02+ WRX
-Weight: clutch - 17lbs, flywheel - 9.6 lbs.
$699 Shipped!!!
$1119 Installed!!!
3) ACT HD Street Disc Kit and Steetlite Flywheel - 04+ STi
-Torque Capacity: 475 lbs/ft.
-Weight: clutch - 17lbs, flywheel - 15 lbs.
$855 Shipped!!!
$1275 Installed!!!
4) ACT HD Street Disc Kit and Prolite Flywheel - 04+ STi
-Weight: clutch - 17lbs, flywheel - 11.1 lbs.
$879 Shipped!!!
$1299 Installed!!!
And for the hardcore guys out there:
5) ACT HD 6 Pad Race Kit and Prolite Flywheel - 02+ WRX
-Torque Capacity: 527 lbs/ft.
$699 Shipped!!!
$1119 Installed!!!
6) ACT HD 6 Pad Race Kit and Prolite Flywheel - 04+ STi
-Torque Capacity: 608 lbs/ft.
-Pressure Increase: 35% over stock clutch.
$819 Shipped!!!
$1239 Installed!!!
Thanks,
Preston
[email protected]
510-783-5300
Gruppe-S is offline
Old 10-22-2005, 08:32 PM   #3
Gruppe-S
Member#: 23216
2006 949-457-1234
949-457-1234
1) Exedy Organic Clutch Kit and Steetlite Flywheel - 02+ WRX
-Clamp Load: 2300 lbs/ft.
-Pressure Increase: 44% over stock clutch.
-Weight: clutch - 14.3lbs, flywheel - 13.9 lbs.
$750 Shipped!!!
$1175 Installed!!!
2) Exedy Hyper Single Clutch/Flywheel Kit - 02+ WRX
-Clamp Load: 2655 lbs/ft.
$PM FOR BEST PRICE!!!
3) Exedy Hyper Single Clutch/Flywheel Kit - 04+ STi
4) Exedy Twin-Plate Clutch/Flywheel Kit - 04+ STi
-Clamp Load: 2205 lbs/ft.
Thanks,
Preston
[email protected]
510-783-5300
Gruppe-S is offline
Old 11-03-2005, 07:16 PM   #4
Gruppe-S
Member#: 23216
2006 949-457-1234
949-457-1234
bump for reopened thread!
Gruppe-S is offline
Old 11-10-2005, 10:17 PM   #5
Gruppe-S
Member#: 23216
2006 949-457-1234
949-457-1234
Hey all,
We have one STi Front LSD for 02-05 for a 5 spd. WRX. This LSD is a 1.5 way clutch type similar to your Cusco or Kaaz units. It is stronger and more responsive than the stock unit. This is an excellent upgrade for anyone who autocrosses or tracks their car and will dramatically increase vehicle dynamics and handling. One can expect improved turn-in, more even power application, and the ability to put the power on earlier upon corner exit. This is an extremely rare and hard to get item that we somehow just found in our warehouse.
Genuine STi Front LSD for 02-05 Subaru WRX 5 spd - $1199 shipped!
Thanks,
Preston
[email protected]
510-783-5300
Gruppe-S is offline
Old 11-15-2005, 10:16 AM   #6
blackwag
Member#: 100666
sell Exedy Organic Clutch Kit by its self?? if so how much?
blackwag is offline
Old 11-15-2005, 03:46 PM   #7
Gruppe-S
Member#: 23216
2006 949-457-1234
949-457-1234
blackwag - PM sent
thanks,
Preston
Gruppe-S is offline
Closed Thread
STi Mounts back in stock! *BEST PRICING* on Exedy and ACT. Kartboy, etc. Gruppe-S Drivetrain 0 07-18-2006 09:23 PM
*BEST PRICES ON EXEDY AND ACT* Tranny and Engine Mounts Back In Stock!! Gruppe-S Drivetrain 2 06-22-2006 08:31 PM
JDM STi Spec C 6 speed tranny, guaranteed best prices on Exedy and ACT! Gruppe-S Drivetrain 4 04-18-2006 07:17 PM
The REAL best prices on Exedy and ACT thread. Drivetrain accessories also... Gruppe-S Drivetrain 3 03-30-2006 01:58 PM
The absolute best pricing on Exedy and ACT Gruppe-S Drivetrain 13 03-06-2006 04:49 PM
