10-23-2005, 01:15 AM | #1 |
Member#: 28806
W. Canada
Vehicle:05 STi WRB |
UTEC Fuel Econ Map for STi
I've been playing around with a Fuel economy map for my 05 STi and was wondering of some of the more seasoned tuners could shed some light on my log..
Log1 and here is the map Map thanks any info is appreciated.. map 2 is the Untuned T-XS stage 2 map
10-23-2005, 11:00 PM | #2 |
Member#: 8785
SWIC
Vehicle:02 c_turner@ix. netcom.com |
Why would you set 0 values in the utec maps up to the 40 colomn? There is open loop fuel now. You can set the TPS cross over point to where ever you want. Doing what you did just makes the utec less usefull. Also you have your boost map lower then when you have the utec take over. Thats not the smartest thing. It also appears you are in open loop boost mode. I suggest closed loop. You are probably better off with the base map and then just raise the TPS cross in open loop to 30-35%.
CLark |
FS:so cal:turbo xs utec w/ remote map for STi | pablosti | Engine/Power/Exhaust | 5 | 09-20-2006 12:14 AM |
UTEC Tuner or maps for download | TheReaper | UTEC | 10 | 08-01-2006 05:00 PM |
Need UTEC map for STI w/20g and fmic | AugustusMaximus | UTEC | 13 | 07-20-2006 11:44 PM |
Need UTEC start up map for MOD STI injectors please. | AXA | Engine Management & Tuning | 0 | 01-28-2005 07:43 PM |
UTEC maps for STI? | MontrealSTi | Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) | 11 | 05-26-2004 05:38 PM |
