10-23-2005, 04:08 AM | #1 |
Member#: 84969
Vehicle:2002 252.8whp 259tq Stock turbo |
Live wire? I hear crackling around utec with ignition on??
When the ignition is on (not when just the key is turned) I hear crackling from around the utec like there is a live wire. It wouldn’t make any sense though that it doesn’t make the sound when the car is on by turning the key. This only started happening after I upgraded the utec software to 5.0 (following the utec instructions) and loaded 1-3 parameters w/ the stage2 base map. I recently just installed gutted uppipe/full tbe, but i didn't have this sound with stage1 map + 4.2c version before i upgraded to 5.0. Could it be something else?
Thanks in advance! Bill
10-23-2005, 02:33 PM | #2 |
Member#: 84969
I have concluded that its not coming from the utec, but somewhere in the footwell/behind radio area. Ill move to electrical.
10-23-2005, 02:44 PM | #3 |
Member#: 81123
Vehicle:2002 2.5 WRX BY RIP 02' 2.5WRX PSM |
Sounds like a loose ground that keeps making and "un"making contact. Check it quick, could be potential fire hazard.
10-23-2005, 06:16 PM | #4 |
Member#: 21980
NESIC
Vehicle:2002 PSM WRX (Sold) 2017 BMW X5 |
Or its a relay clicking rapidly. Either way search for the source soon.
10-23-2005, 07:16 PM | #5 |
Member#: 16200
Vehicle:OK buy Nates beans westcoastroasting.com |
.....d0000d.....localize the area as close as possible.....set it up so that you can 'make it do that' easily.......sit in a totally dark car in a totally dark garage for an hour or so----take a bit of a nap .....and then 'make it do that' while looking for the spark.
You may be amazed at how easy it is to spot a small spark in total darkness |
keyless with ignition on | first suby 2010 | Car Audio, Video & Security | 1 | 03-18-2010 08:00 PM |
Help with ignition wire on my wideband.. | 05Scooby | Electrical & Lighting | 4 | 05-02-2009 06:37 PM |
No "CEL" with ignition on | Saetern | Electrical & Lighting | 0 | 11-06-2008 04:44 PM |
Keyless entry with ignition on.... | mtskibum16 | Car Audio, Video & Security | 0 | 02-16-2007 08:21 PM |
Won't start, no accessories with ignition on. | joshuagore | Electrical & Lighting | 2 | 08-20-2006 11:16 PM |
