Old 10-23-2005, 04:59 PM   #1
bren wrx
Member#: 59454
'10 E92 M3 M-DCT
brentuning.com/blog
Default 18g'd ej205s come forward.....
and post your timeslips, mods, trap speeds
thanks!
bren wrx is offline   Reply With Quote
Old 10-27-2005, 11:11 PM   #2
oneoverWRX
Member#: 74793
02 WRX
BLAZE YELLOW
Are you running an 18g?
oneoverWRX is offline   Reply With Quote
Old 10-28-2005, 12:17 PM   #3
turbocrazy
Member#: 44715
2002 wrx
bump, I have an 18g but untuned.
turbocrazy is offline   Reply With Quote
Old 10-28-2005, 12:19 PM   #4
Ssleeping
Member#: 60353
2002 Stg. 4 WRX
I have a tuned 18g that detonates like nobodys business. It's not int he tune, and I have no idea what it can be.
Ssleeping is offline   Reply With Quote
Old 10-28-2005, 12:39 PM   #5
jbotage9er
Member#: 85193
I dont have one but I got a ride in one. Its top end felt significantly faster then my sti at the time. I think it was making 320 wheel....does that sound about right for a rex with 18G + TBE + UTEC + FMIC + intake? It was a real nice set up. What I liked about it was it didnt have the huge lage of an over sized turbo. Totaly streetable. It was a nice combination.
jbotage9er is offline   Reply With Quote
Old 10-28-2005, 01:17 PM   #6
davidm_sh
Member#: 5994
2004 Impreza WRX STi
Java Black
I went from a VF22 to an 18G on my 02 WRX. Also did my runs at Bandimere (5280ft asl) on pump gas.
Mods with VF22:
-MRT 3" catless TBE
-UTEC
-pinks + GSS342
-TXS TMIC v1
-lightened pullies
-AEM CAI
-boost up to 17psi down to 15psi by redline - all it would hold to redline
-pump gas 93 octane
ran a 1.85 60' - 13.2@101
Mods with 18G:
-same
-added GP MOTO 4-2-1 headers
-did NOT change tune one bit for headers
-20psi peak and to redline for boost
ran a 1.96 60' - 12.9@106.4
Same spool as the VF22 but more topend.
davidm_sh is offline   Reply With Quote
Old 10-28-2005, 01:43 PM   #7
pezman04wrx
Member#: 66558
^^^ Wow, that's one heck of an improvement ...
pezman04wrx is offline   Reply With Quote
Old 10-28-2005, 01:51 PM   #8
nuhga
Member#: 80770
2005 v7 spec-c
i have FP18g but never been to track. injectors a little small but i will get alky soon.. i'm still on stock tranny i would like to know if anyone else is running these on stock tranny?
Utec custom tuned 18psi all the way
fp18g
pink
txs fmic, rfl bov, shorty intake
walbro fuelpump
3' TBE
nuhga is offline   Reply With Quote
Old 10-28-2005, 01:59 PM   #9
BlackSnake
Member#: 42850
WTB 04-07 STI
Roller/Blown Engine
I have a fp18g also on stock tranny/clutch
Vibrant CB
Perrin DP
Turbo XS UP
Turbo XS FMIC
UR 785cc INjectors
Cobb AP ( Protuned by Riftswrx)
Tuned for 100oct at 21.5-22psi
Car Dyno'd 324whp and 303wtq
12.4@115
BlackSnake is offline   Reply With Quote
Old 10-28-2005, 02:03 PM   #10
McBain_TP
Member#: 43986
2002 WRX wagon RIP
2003 330ci black/tan
You've seen my dyno sheet, 315/270, 13.0@109.2. I've got tonight and tomorrow to get back into the 12's at NED before it closes.
McBain_TP is offline   Reply With Quote
Old 10-28-2005, 02:58 PM   #11
drwrx
Member#: 50891
Mods with VF22:
-MRT 3" catless TBE
-UTEC
-pinks + GSS342
-TXS TMIC v1
-lightened pullies
-AEM CAI
-pump gas 93 octane
Mods with 18G:
-same
I'm not certain I agree. The extra 3 to 5 lbs of boost and the set of headers could be all the difference. And while his post says 15psi was "all it could hold at redline" I'm not certain what that means. Every person I've ever known with a vf22 has never had any problem running 20+psi all the way to redline. The problem has always been "not enough fuel", and too much boost. It's no suprise where the "more topend" is coming from, the extra 5psi of boost. 5 lbs is a huge difference!
I'm not dissing the 18G, it's a great turbo and should perform better than a vf22. But what is stated above is not what I would call a fair comparison.
drwrx is offline   Reply With Quote
Old 10-28-2005, 04:42 PM   #12
davidm_sh
Member#: 5994
Java Black
You are absolutely correct IMHO. And the reason the VF22 couldn't hold more than 15psi to redline WITH the stock wastegated spring (~7psi) is just one of the many reasons it's so much fun to live at high altitude . Over the winter I added a helper spring to the VF22 so it could hold 20psi to redline and it felt quite a bit better... for about 8,000 miles that is until I my car turned into the spy hunter smoke screen car under boost [heh]. After that I went with the 18G with a 18psi wastegate to hold 20psi to redline (lost about 3-4psi to redline with the headers with the weaker 15psi can I had on the 18G originally).
But I then ran the 18G at 20psi daily for about 10,000-15,000 miles which btw up here worked out to be in the 3.0-3.2PR range = VERY high turbine rpms. I then sold it to another owner who ran it just as hard for about the same amount of miles maybe more. Then the 3rd owner opted to have it rebuilt just as a precaution and precursor to installing it.
So IMHO, totally can't verify this, the VF22 with the helper spring to hold 20psi to redline would have probably made about the same hp/trap speeds in the 1/4 mile but it only lived about 8,000 miles at the 3.x+ PRs that come from running 20psi at 6000ft asl. So the 18G is a much more durable and cheaper turbo to maintain in the long run.
FWIW.
Old 10-28-2005, 08:17 PM   #13
sprx19
Member#: 51091
2006 Evo
Vibrant CB
Perrin DP
Turbo XS UP
Turbo XS FMIC
UR 785cc INjectors
12.4@115
I've run a 12.6, but at only 109. Do you have the 7cm housing? I need to get on a dyno because I only have a road tune. I run race gas and am not afraid to run big boost. I just always thought the trap speed should have better. Its nice to see someone trapping high with an 18g.
sprx19 is offline   Reply With Quote
Old 10-29-2005, 02:04 AM   #14
verc
Member#: 41754
03 wrx
gt35r, 2.5L, meth
Vibrant CB
Perrin DP
Turbo XS UP
Turbo XS FMIC
UR 785cc INjectors
12.4@115
WOW that some nice trap, I'm going for 100 octane myself and will seriously consider getting an 18g if I see more times/trap like yours!
verc is offline   Reply With Quote
Old 10-29-2005, 01:22 PM   #15
BlackSnake
Member#: 42850
WTB 04-07 STI
Roller/Blown Engine
Yeah. I launched the s*** out of it lol
Quick question to those who are running 20+psi. Any ones boost taper down up near redline? Mine is going down from 22 to 19.5 and I am thinking about tightening the wastegate a little. Oh and ill be getting a headersoon . So maybe 11's? (Probably not)
-Bogus
Old 10-29-2005, 01:30 PM   #16
testes1010
Member#: 47145
2005 LGT 5MT VF52'd
^ did Jorge tune it to taper at redline?
testes1010 is offline   Reply With Quote
Old 10-29-2005, 02:33 PM   #17
BlackSnake
Member#: 42850
WTB 04-07 STI
Roller/Blown Engine
we tryed to get the most out of the turbo we could. He said it was tapering down. ( I might have loosened the wastegate on accident when installing) But I thought 18g's could hold that boost to redline. So he Tuned me on 22psi and up top he leaned me out a little so i still had power and not notice the boost drop as much.
-Bogus
Old 10-29-2005, 03:14 PM   #18
bren wrx
Member#: 59454
'10 E92 M3 M-DCT
brentuning.com/blog
115 wow!
i trapped 108 with a vf34 at low boost stock i/c
it just seems that the 18g isnt safe for a stock tranny/motored 2.0
Old 10-29-2005, 03:27 PM   #19
McBain_TP
Member#: 43986
2002 WRX wagon RIP
I'm pretty sure I saw an 18G'ed WRX blow first gear at the last Import Wars.
Old 10-29-2005, 03:32 PM   #20
BlackSnake
Member#: 42850
WTB 04-07 STI
Roller/Blown Engine
Hey im on the stock tranny and CLutch. Which both have seen 30+ pass's down the 1/4.
3 of them were with the 18g ( plus a number of street launches)
Old 10-29-2005, 03:35 PM   #21
McBain_TP
Member#: 43986
2002 WRX wagon RIP
I'm just glad I preempted a tranny failure with RA's. They did make my 1/8 times suck, however.
Old 10-29-2005, 03:36 PM   #22
bren wrx
Member#: 59454
'10 E92 M3 M-DCT
brentuning.com/blog
1st gear im not worried about
i just upgraded slightly to a brand new 03 RA width gear box with a brand new clutch
i did however shred 3rd gear from a ROLL in my 02 box with a vf34
Old 10-29-2005, 04:07 PM   #23
testes1010
Member#: 47145
2005 LGT 5MT VF52'd
Hey im on the stock tranny.....
same here, stock internals, upgraded clutch w/ a DB20G tuned by Jorge...but no drag racing on this turbo....
soon to be retuned w/ alky injection by Jorge....
Old 10-29-2005, 07:51 PM   #24
scoogan
Member#: 85673
2007 Legacy Spec B
would '04 + transmissions hold up better at those power levels (~290-320) due to the revised gear widths?
scoogan is offline   Reply With Quote
Old 10-29-2005, 07:58 PM   #25
BlackSnake
Member#: 42850
WTB 04-07 STI
Roller/Blown Engine
yeah. I have an 04. and tranny hasnt givin me a problem
FS : Coming to Jacksonville, FL. STi intake manifold, Springs, Misc. 48mpg South East Region Private Classifieds 6 06-04-2010 08:52 AM
Deepthroat comes forward? Suby1128 Political Playground 15 06-11-2005 10:55 PM
('93-'01) 98 True Green's come forward grnlantern1 Impreza Forum 8 06-26-2003 01:20 PM
Big Game Pool Ticket holder finally comes forward romanom Tri-State Area Forum 1 04-30-2002 03:14 PM
('93-'01) US Meet planners, Come forward Patrick L Impreza Forum 22 05-09-2001 10:08 AM
Message Board Statistics All times are GMT -4. The time now is 07:21 AM.
