10-23-2005, 06:52 PM | #1 |
Member#: 64150
SCIC
How do you reset Utec?
I've been having a misfire code on cylinder 3 since I installed Perrin modified injectors, so I reinstalled factory size injectors 550cc back in my 04sti. I changed the injector sizing back to 550cc and reset the Utec by removing the 100amp fuse in the fuse box, but I only waited a few seconds before reinstalling the fuse.. After I started the motor I got a **** load of white smoke coming out of my exhaust and motors running very rough probably since Utec didn't recognize the change injector size. , Now I removed the fuse and will wait a few minutes before putting it back. What is the proper way to reset the Utec?
10-23-2005, 07:33 PM | #2 |
Member#: 21980
NESIC
Vehicle:2002 PSM WRX (Sold) 2017 BMW X5 |
When you remove the key from the ignition wait until you hear a click from a relay in the passenger side footwell. That relay powers the ECU/UTEC so when it clicks off the UTEC will perform a full reset. It takes anywhere from 2 to approximately 20 seconds.
10-23-2005, 07:38 PM | #3 |
Member#: 64150
SCIC
Thank you.
How do you Reset the ECU | BlueByYou | Newbies & FAQs | 16 | 03-28-2003 02:01 PM |
How do you reset the ECU to get rid of a CEL? | Jasno999 | Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) | 9 | 05-19-2002 01:54 PM |
How do you reset the ECU | khai yang | Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) | 4 | 12-22-2001 10:21 PM |
How do you reset your ECU | IcedOutRS | Newbies & FAQs | 10 | 03-27-2001 04:41 PM |
How do you reset ECU? | Rez | Technical Forum Archive | 4 | 07-27-2000 12:02 AM |
