Welcome to the North American Subaru Impreza Owners Club Thursday April 24, 2014
Old 10-24-2005, 12:34 AM   #1
(a.a)
Member#: 99259
1999 Impreza Out 2.2
Default Battery output voltage 17.76V
I have checked my battery output voltage (Engine running) and it shows 17.76 Volts. The pover is steady at all RPM's. How to adjust a "Voltage regulator", or do I have to buy a new one? I believe it's external, not inside the alternator.
I also found these "Voltage Stabilizers" are they really necessary?
(a.a) is offline   Reply With Quote
Old 10-24-2005, 01:20 AM   #2
Master2192
RIP 10/12/83 to 02/10/08
Member#: 83254
98 2.5 RS
04 WRX
Well, you didn't list what year car you've got or anything. But usually newer cars have the voltage regulator inside the alternator. You can goto a shop and they can diagnose it better and most likely replace the regulator pretty cheap. Or they may recommend to replace the alternator. As far as i know, my 98 RS does not have an external voltage regulator.
Old 10-24-2005, 01:30 AM   #3
(a.a)
Member#: 99259
It's 1999 Impreza Outback Sport F4-2.2L SOHC.
I checked the Voltage again, now it's 18.36V.
Is it too dangerous to drive due to battery explosion at this voltage?
ALLDATA shows "Voltage Regulator" as a separate part [OEM Part 23815AA140] Price - 180.00$
There is a link to "Internet Catalog" on this:
ww.transpo.de/cgi-win/product.exe?IM848
It seems replaceable.
Old 10-24-2005, 01:47 AM   #4
White 2.5rs
Member#: 39936
99RS TWE&SCAT EJ257
Hydra+HMist+PPG+35R=DEATH
yes get that fixed, jesus
the VR is inside of the alternator iirc
pull the alt adn have shucks test it or something
normal car electronics are made to operate within 11-15 volts iirc
Old 10-24-2005, 08:52 AM   #5
2phless
Member#: 69343
2000 nothing good
slow
Blowing up your battery would probably be the cheapest thing that could go wrong. I'd stop driving it like that immediately and fix it.
2phless is offline   Reply With Quote
Old 10-24-2005, 09:05 AM   #6
Mulder
Trust no one
Member#: 11170
02 WRX
05 GTO/11 Sonata(!)
I agree. Don't drive it until you get that fixed.
Since readings that high are unsual, I'd also recommend verifying the voltage with a different meter before you go replacing anything.
Old 10-24-2005, 11:27 AM   #7
Rapid_Roo
Member#: 31511
03 GD2 95 GM4
www.ITNRally.org
ditto
Rapid_Roo is offline   Reply With Quote
Old 10-28-2005, 09:14 AM   #8
White 2.5rs
Member#: 39936
99RS TWE&SCAT EJ257
any updates?
Old 10-28-2005, 02:02 PM   #9
Freon
Member#: 88322
2009 BMW 135i
Yes, fix that before you blow your ECU or something equally expensive. That is not safe.
ditto to the above, the voltage regulator is usually part of the alternator, but you may be able to have it repaired rather than get raped for a whole new alternator.
You should read about 11.5-12.5V when the engine is off. That would be a good check for your multimeter.
Freon is offline   Reply With Quote
Old 10-30-2005, 03:26 AM   #10
(a.a)
Member#: 99259
Yeah I got it fixed for now. I have dismantled the alternator a part to see that regulator. Nothing could be fixed. Ordered a new one online at Subaruparts. The same alternator goes to Mitsubishi and a few other cars. If they had one at the time it would be cheaper.
What about that "Voltage regulator" on eBay is is really useful?
Old 10-30-2005, 06:49 AM   #11
Mulder
Trust no one
Member#: 11170
02 WRX
05 GTO/11 Sonata(!)
Nothing. Just replace your alternator if it's bad and you're done. You can add some DIY ground wires if you like but don't buy anything that claims to regulate or stabilize the voltage, those things are BS and totally unnecessary.
how do i check my battery voltage? Caddy Daddy Off-Topic 50 12-13-2005 07:52 AM
normal battery voltage rfoubi Electrical & Lighting 6 03-04-2004 12:57 AM
boost raised=heavy load in 3rd=battery voltage kills car Otaku64 Factory 2.0L Turbo Powertrain 11 03-13-2003 02:21 PM
battery voltage?? initialx Newbies & FAQs 6 11-16-2001 12:08 AM
pillar mount battery voltage meter.. bratmantlz Normally Aspirated Powertrain 3 06-11-2001 09:16 AM
