10-24-2005, 04:41 AM | #1 |
Member#: 95982
Vehicle:2002 WRX PSM vf39 RAGearset 94 Accord Daily |
UTEC ABC Question
I have my ABC open 6 turns and the datalogger says im peaking at 13.8 psi....any help with this matter would be great...i installed it between the restrictor and w/g solenoid...thanks in advance
cameron
10-24-2005, 04:24 PM | #2 |
Member#: 57608
NWIC
Vehicle:All your boost are belong to us! Mwahahahaaa |
Not knowing anything more about your mods, I'm guessing here. You can only make 13.8 and expect more, right? 6 turns sound like alot to me. I don't remember the exact number, but I thought about 3 turns from bottoming out was a good starting point. Are you thinking more turns should be more boost?
I look at the ABC as an adjustable leak. Leak more vacuum to atmosphere (by turning the screw out more), and you get less action on the solenoid. |
10-24-2005, 05:23 PM | #3 |
Member#: 78285
NESIC
Vehicle:2006 EVO GG 2019 WRX LB |
do yourself a favor and get the perrin ebcs. works perfect with the utec and is adjustable from the boost map. and its cheap
10-24-2005, 05:43 PM | #4 |
Member#: 88322
Vehicle:2009 BMW 135i |
Or get a GM solenoid, does the same thing, less than half the price.
http://forums.nasioc.com/forums/showthread.php?t=870619 You'll have to completely retune your boost map, but it will absolutely block pressure from reaching the wastegate when energized. If you can't build boost with a blocking solenoid configuration, you've got a problem elsewhere. Anyway, 13.8psi is about stock level. You shouldn't need the ABC at all to do that I would hope. Try one thing. Change nothing else, but tighten your ABC back down all the way. Does your boost go down? I'd just make sure the ABC is doing anything at all. |
10-24-2005, 05:46 PM | #5 | |
Member#: 21980
NESIC
Vehicle:2002 PSM WRX (Sold) 2017 BMW X5 |
10-24-2005, 06:08 PM | #6 |
Member#: 7194
Vehicle:2011 997.2 Turbo Black |
6 turns out? i'd say he is making too little!!!~ Is this on the stock turbo? What values do your have in your boost map? (90% and 100% column?)
10-24-2005, 08:03 PM | #7 |
Member#: 36528
Vehicle:2002 Impreza Wrx Silver |
What rpm are you reading the boost at? What's the boost control set to in parameters(open or closed loop boost)?
10-24-2005, 08:14 PM | #8 |
Member#: 13833
Vehicle:2002 Impreza WRX Silver - Sold :( |
Isn't 2 turns out the de-facto standard starting point? I'd check the values in the UTEC boost map...
10-28-2005, 10:29 AM | #9 |
Member#: 95982
yes it is a stock turbo...my values are the stage 3 map for the utec...i thought it would hit 16.5 psi with fewer turns that 6...IM NOT TRYING TO MAKE INFINITE BOOST ON MY SETUP...just concerned that the abc isnt working correctly..
10-28-2005, 11:37 AM | #10 |
Member#: 21980
NESIC
Have you tried to turn the set screw in some more to make higher boost? If its not changing things much you might have to up the values in your boost map.
10-29-2005, 07:39 AM | #11 |
Member#: 69343
South East
Vehicle:1998 TransAm cnvrtbl Black |
Have you set up the gradient and intercept values in the paramemters according to the manual? You might be recording a bogus value.
I think that's the first time I've ever typed, or even used the word "bogus." Huh. Bogus. I like that. And not being familiar with the values in the "stage 3 map"... aren't they still supposed to be tuned to your setup. They aren't a page full of 500s are they? |
UTEC ABC "Y" size | JAUNE | Engine Management & Tuning | 2 | 07-31-2004 04:23 AM |
TXS Stg4 UTEC ABC Tuning | jetskizero | Engine Management & Tuning | 5 | 09-13-2003 10:11 PM |
UTEC ABC wont move boost | 1FastREX | Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) | 14 | 08-22-2003 08:14 PM |
The ABC on the Utec...a question? | Jduke | Engine Management & Tuning | 1 | 03-25-2003 11:23 PM |
UTEC ABC used as an MBC? | eingram | Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) | 1 | 03-25-2003 09:15 AM |
