10-24-2005, 01:29 PM | #1 |
Member#: 73054
Vehicle:2002 WRX 2.5, 4eat |
2.5 hybrid and utec
Does anyone have a base map I can use for a 2.5 hybrid with stock wrx injectors. I just need something to use till I can start tunning the car.
Thanks
10-24-2005, 02:05 PM | #2 |
Member#: 9794
TXIC
Vehicle:02 2.5LWRX-Retired 335i w/twins |
Duplicate thread: http://forums.nasioc.com/forums/showthread.php?t=864369
10-24-2005, 03:13 PM | #3 |
Member#: 73054
He's running 55 psi of fuel pressure. I would imagine that would make the fuel maps pretty lean for me to use.
Oh also I forgot It needs to be in closed loop fuel, I am running an automatic. Last edited by jabbott; 10-27-2005 at 03:42 PM. |
10-24-2005, 03:21 PM | #4 | |
Member#: 9794
TXIC
And fwiw, I started with the base Stage 4 map but reduced to timing to 17psi peak. This worked fine for low boost. |
10-27-2005, 03:41 PM | #5 |
Member#: 73054
But how would I change the injector size if i'm running the utec in closed loop fuel due to me running an automatic? I thought injector scaling was only possible in open loop.
10-28-2005, 01:20 AM | #6 | |
Member#: 9794
TXIC
2.5 wrx and 2.5 STI | 2wheeldrive | Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) | 46 | 10-12-2007 10:10 AM |
Anyone have a 2.5 hybrid VF22 Utec map? | Wrx1234 | UTEC | 5 | 05-04-2007 08:54 AM |
RS 2.5 block and STi 2.5 block | Rancid | General Community | 4 | 01-26-2004 07:57 PM |
Any difference between a 97 2.5 gt and a 98 2.5 gt | Polskino | Legacy Forum | 3 | 12-21-2003 07:51 PM |
I Got My 2.5 Motor And Fwd L 2.5 Project Has Begun | mcu81 | Normally Aspirated Powertrain | 88 | 10-30-2002 06:32 PM |
