Old 08-29-2001, 08:20 PM   #1
elemental
Member#: 2701
'00 obs
Default orbital buffer burn marks--help
if you get slight burn marks from an orbital buffer, would just taking off the whole wax deal through like dish soap take off the burn marks and then you can start over? or is there less or more that i have to do to get them out?
elemental is offline   Reply With Quote
Old 08-29-2001, 10:03 PM   #2
Jeff 2.5RS
Member#: 1590
2004 Rx8
Dish soap is made to take off the toughest grease, so there goes you're clearcoat and other protective elements if you do that, you should be able to use a light hand polish maybe, I don't have much experience with burn marks though, try going to Griots Garage , they have a lot of polishes and other cleaning agents.
Jeff 2.5RS is offline   Reply With Quote
Old 08-29-2001, 10:44 PM   #3
elemental
Member#: 2701
'00 obs
... i don't think clearcoat comes off that easy... i was under the impression that dish soap took off the wax and after the wax was the clearcoat which would not be harmed... i've heard this from reputable places so... this is wrong?
what im really asking is where are the burn marks, are they on the wax layer, are they on the clearcoat, one means just removing the wax, the other means... professional detailing job to work their wonders with the clearcoat or get a new paint job or something, but they're not that bad at all, so i wouldn't go that route if that was the only way.
Old 08-30-2001, 12:34 AM   #4
RawCode
Member#: 3115
2002 Impreza 2.5RS
Dishsoap will NOT strip your clearcoat. You need thinner or brake fluid to do so... but if you do that you also strip the pigment layer also... hehehe
MikeyG
RawCode is offline   Reply With Quote
Old 08-30-2001, 01:30 AM   #5
Tats
Member#: 5692
WTF? YES! I am
better than you!
My sister in law gave me one of those buffers for x-mas last year. It's still in the box in the closet. I'm scared to death of those things. I'm too dangerous to try that.
tats.
Tats is offline   Reply With Quote
Old 08-30-2001, 02:41 AM   #6
elemental
Member#: 2701
'00 obs
well supposedly those random ones that move around i guess kind of randomly are good but they're also expensive but my dad bought a like 40 buck one from home depo
and i can see marks in direct sunlight in some places, mostly the sides... and it pisses me off cuz i did the meguiares three step and im starting over tomorrow but all by hand this time.
Old 08-30-2001, 11:22 AM   #7
NoSaabs
Member#: 7688
2008 Legacy GT Sedan
Diamond Grey
if you get burn or swirl marks from an orbital buffer, it's because you're pressing too hard! you just have to let it float on top, no pressure is required. you have to get some hard compound and some medium cut to get it off. if you stripped the clearcoat, you're pretty much screwed. i stipped the clearcoat off a mustang when i was learning how to use a buffer at a ford dealer. compound, buff, cut, buff, wax, hand shine, finish spray. do these steps if it's not through the clear coat and it should be just fine.
and i agree, go for the maguier's 3 step...
NoSaabs is offline   Reply With Quote
Old 08-30-2001, 12:45 PM   #8
elemental
Member#: 2701
'00 obs
what do you mean by 'medium cut' ? and i don't think i pressed so hard that i did anything irreparable, the only place i see the marks are on the side of the car, where you can't actually rest it on the surface, so i must have pushed a little when fatigued and trying to get the job done
Old 08-30-2001, 01:46 PM   #9
auricom
Member#: 3088
'01 2.5 RS
maybe try the clay bar kit from Mothers. that detailing spray with the clay might remove it.
auricom is offline   Reply With Quote
Old 08-31-2001, 03:08 AM   #10
Silver_Bell_WRX
Member#: 7677
2005 WRX
You might try using windsheild washer fluid. I heard that it takes off the dried on bug guts fairly well.
Silver_Bell_WRX is offline   Reply With Quote
Old 08-31-2001, 09:16 AM   #11
nikkicalves
Member#: 3608
Location: the T-dot - The green igloo billowing black smoke
2000 Impreza
Tanned - BRP
I would have to see the burn, but usually the only way to get rid of it for sure would be to wet sand it! Tha is the only method that I know will not harm that much.
Nick.
nikkicalves is offline   Reply With Quote
Zaino / Orbital Buffer in Fort Worth treybomb Texas Impreza Club Forum -- TXIC 6 11-26-2003 11:32 AM
Tried the orbital buffer for the first time veloLexus Bay Area Impreza Club Forum -- BAIC 3 02-03-2002 12:54 AM
Any orbital buffer experts here? veloLexus Bay Area Impreza Club Forum -- BAIC 17 01-29-2002 11:20 PM
Porter Cable 7424 Orbital Buffer??? veloLexus Bay Area Impreza Club Forum -- BAIC 0 01-26-2002 02:18 AM
Orbital Buffer ??? Sobelizard109 Car Care & Detailing 11 10-15-2001 09:17 PM
