Old 10-27-2005, 12:14 PM   #1
bluestone
Member#: 36583
2004 WRX sedan
Default Help with installing boost gauge
wooo first post since hte catastrophe...
i read the OEM subaru instructions and some threads on scoobymods so i have the basics down, just not sure where to find some things.
1) there are two rubber stoppers behind the intercooler, which one do i use to put the rubber hose through? the one with an impressed groove (smaller) or flat one (larger)? where does it come out in the compartment? i can't see any holes by the gas pedal.
2) where can i tap 'dimmed' power, possible from the gauge cluster? i will take apart the center console to get the one above the stereo if that is the only one available but would rather not do all that work. for that connector, what size spade connectors can i use or should i just strip the wires?
thanks
bluestone is offline   Reply With Quote
Old 10-27-2005, 12:17 PM   #2
enewtabie
Member#: 18928
2002 jdm wrx v7/v8
inter/w Spec C roof vent
look near the brake pedal..theres a grommett that you can use there.
You can tap the power from the clock,but it depends on where ya want to mount it.
enewtabie is offline   Reply With Quote
Old 10-27-2005, 12:34 PM   #3
bluestone
Member#: 36583
2004 WRX sedan
hm brake pedal ok i'll look there. is that the one that comes out behind the intercooler or is it lower? seems like it would be alot lower.
the power above the stereo i'm talking about the spare harness subaru left for the oem gauge (how nice), just don't know what size the connector would be. i'm using an autometer-style gauge bezel, should string it straight across when everythings apart right?
Old 10-27-2005, 12:36 PM   #4
enewtabie
Member#: 18928
2002 jdm wrx v7/v8
Yes its low.Make sure not to lose that little grommett.Lets in noise.
I did my pod where the clock was and just tapped the clock harness.
Old 10-27-2005, 01:51 PM   #5
SupraToWRX
Member#: 43942
'05 White/Gold STi
If your hose is long enough, you could also pass it through the grommet near the turbo. There's a lot more room there to work with, and all you have to do to get it out the other side is remove the glovebox. Just a thought. It's what I did for my wrx and now sti.
SupraToWRX is offline   Reply With Quote
Old 10-27-2005, 02:10 PM   #6
bluestone
Member#: 36583
2004 WRX sedan
can't seem to find that one... got any pics ?
also do i need to seal up the grommet with silicon like the oem instructions say
Old 10-27-2005, 02:29 PM   #7
SupraToWRX
Member#: 43942
'05 White/Gold STi
If you look under your hood and face the engine bay, it should be the only grommet in that wide open space behind the turbo/downpipe and just to the left of it.
The instructions may say to use silicone, but I never did on my wrx and I had no problems for the two years it was installed. I just poked a small hole in it and squeezed the hose through.
Help on installing boost gauge sleepysubie Rocky Mountains Impreza Club Forum -- RMIC 7 08-13-2009 04:34 AM
help with greddy boost gauge dnomyar Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 7 03-20-2004 03:12 PM
Need help with turbo boost gauge! JDMSubaru Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 7 12-10-2003 03:29 PM
would anyone help me install boost gauge?( o.c. area) axion7606 Southern California Impreza Club Forum -- SCIC 10 07-18-2003 03:17 PM
need help to install Boost Gauge Mechanical chobits Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 1 04-01-2003 11:01 PM
