South East Region Club
Go Back   NASIOC > NASIOC Regional Areas > South East Region Forum
Old 10-27-2005, 05:54 PM   #1
Warp3
Member#: 161
06 WRX TR (SGM)
89 MR2 (Ice Blue)
Default FS: 1991 Subaru Legacy Sport Sedan (redux)
Yes, this is the same car I was attempting to sell previously (then pulled from the market for a while), but with fewer parts included and thus a lower price. For those of you already familiar with the previous listing, there are only two major differences (except for the price, of course). First, the wheel/tire combo has changed from 16x7 RS wheels with Falken 512s to 15x6 Legacy alloys with RE92s. Second, five of the line items that were under "not installed" previously, are now no longer included with the car. The exhaust has already been sold and the other four entries (the ICs/BPVs, the PS pump, the bumper turn signals, and the power antenna) will be individually posted for sale soon (however, if you desire any of these parts they can, of course, be negotiated into the price of the car).
For Sale:
2.2L H-4 Turbo
4-speed automatic (4EAT)
Fulltime AWD with rear VLSD (only the '91 models had the rear LSD)
Silver with Gray interior
190k miles
Factory oil cooler (also a '91 only feature)
CarFax Report:
http://warpthree.com/images/warp3/le...egacySport.pdf
Photos:
Here is what it looked like when I bought it about it about a year ago: http://warpthree.com/gallery/?folder.../legacy/040821 and not much has changed since then. I've deyellowed the headlights somewhat (wet sanding followed by clearcoat) and it now has bronze wheels (they are stock Legacy Turbo alloys, just painted bronze).
Updated pics are coming as soon as I get the chance to wash the car and take some snapshots of it...
Mods / Extras:
- OE 15x6 Legacy Turbo 7-spoke alloys, painted bronze (with 195/60-15 Bridgestone Potenza RE92s)
- TD05H-16G turbo (installed by Boxer4Racing and Deadbolt Enterprises)
- Motul Synthetic ATF
- Custom made diagnostic cable and bootable CD for Vikash's BC/BF scan tool utility
- Haynes 1990-1998 Subaru Legacy repair manual
Parts replaced since purchased:
- Initial round of "tune-up" parts (plugs, wires, fuel filter, air filter, wiper blades, etc.)
- Turbo inlet boot
- Torque Converter, flex plate, and tranny mount (installed by Boxer4Racing)
- Trunk badge ("Legacy Turbo" badge was missing when I purchased the car)
- Radiator (incl. radiator hoses, thermostat and thermostat gasket)
- Starter (however, the solenoid contacts are sticking again after only 6mo; needs replaced again, preferably with one from the dealer this time)
- Rear brake pads
- Front passenger side axle (Subaru OE)
- Front ball-joints
- O2 sensor (Subaru OE)
Parts / mods that were purchased but never installed (but are included with the car):
- Hard pipe and two hoses for the oil cooler (as the current ones aren't in very good shape)
- Alternator (suspect the alternator (or at least the voltage regulator in it) is dying (though the alternator does still work); I've purchased a replacement, but haven't found the time to install it)
Known issues:
- Compressor bypass valve stuck in the closed position
- Occasional odd noise under load...my guesses are that it is either tranny or heat-shield related
- Tranny seems sluggish under acceleration...possibly needs a rebuild or maybe the bands need adjusted...still perfectly drivable
- Has apparently had crash damage to the left side in the past as the rear part of the left-rear door will not hold a magnet
- Rust spot just behind the left-rear door (see pics)
- Previous owner sealed around the outside edge of the sunroof with a bead of silicone as it was leaking
- Passenger visor is from a different car (though the color and style matches perfectly, so it blends right in)
- Runs 10psi of boost even though there is a 7.5psi wastegate on the turbo...car runs perfectly fine at 10psi on 93 octane, so it isn't a pressing issue, but it is still kinda odd
- Leaks oil (it is a Subaru after all )
- ABS acts strangely for the first couple minutes, then the ABS light comes on the ABS shuts off for the duration of the drive (and I haven't had the chance to pull the code from the ABS computer).
- Passenger side bumper turn signal is cracked
Reason for selling:
Since I have the Legacy GT as my daily driver and the 2.5RS as my race/project car, I no longer have any real need for (nor any time to expend on) this car.
Price: $1500 SOLD!!!
Shane
Warp3 is offline   Reply With Quote
Old 10-27-2005, 06:15 PM   #2
newscooby
Member#: 995
2000 MkIV GTi&23 LSV
Red cars PWN me
Damn you Shane. I just bought another beater...but this would have been MUCH cooler.
newscooby is offline   Reply With Quote
Old 10-27-2005, 06:19 PM   #3
racepimp
Member#: 76623
2002 WRX sedan
Black Pearl
dibs...pmed you
racepimp is offline   Reply With Quote
Old 10-27-2005, 06:19 PM   #4
Longfury
Member#: 36047
2013 BRZ
Galaxy Blue
I just bought a new computer.
Maybe I can sell my old one and scrape the rest together...I'll PM you later.
Longfury is offline   Reply With Quote
Old 10-27-2005, 08:16 PM   #5
Warp3
Member#: 161
06 WRX TR (SGM)
89 MR2 (Ice Blue)
Originally Posted by racepimp
dibs...pmed you
Replied.
Shane
Old 10-27-2005, 09:54 PM   #6
IronMonkeyL255
Member#: 38120
1991 Rio Red
Legacy Turbo
Guess who bought some of the parts off of him.....
The exhaust sounds awesome, BTW.
IronMonkeyL255 is offline   Reply With Quote
Old 10-27-2005, 10:08 PM   #7
kwh29
Member#: 22100
Hey, either of you want a set of new front rotors and factory pads? I have some that I bought to go on my '92 that it ended up not needing. Cheap!
--Kevin H.
(and a free bump Shane)
kwh29 is offline   Reply With Quote
Old 10-27-2005, 10:10 PM   #8
Warp3
Member#: 161
06 WRX TR (SGM)
89 MR2 (Ice Blue)
Some? You've been my only buyer of the 1G Legacy parts thus far. You sure you don't want the rest of the parts at a discounted bulk rate?
Wow, you got it installed already? Sweet!
Oh and speaking of exhaust, I forgot to mention the side of the muffler on this car is pretty much rusted through, so it kinda sounds like it has an upgraded exhaust. The rest of the exhaust is in *great* condition, though (much better than I had expected with a car this old and with that many miles).
Shane
Old 10-27-2005, 10:17 PM   #9
IronMonkeyL255
Member#: 38120
1991 Rio Red
Legacy Turbo
It was a royal pain to install. The stock axleback and midpipe were completely rusted together. I had to drop that all as one piece. Neither of the tranny mounts lined up, so I am currently without.
I got most of it in in about an hour and a half, and was waiting for the gaskets from dale to install the downpipe.
Old 10-28-2005, 10:11 AM   #10
Performance Driven
Vendor
Member#: 75855
04 Dynapack
pm me your phone number please.
Performance Driven is offline   Reply With Quote
Old 10-28-2005, 07:45 PM   #11
Warp3
Member#: 161
06 WRX TR (SGM)
89 MR2 (Ice Blue)
The car is now sold! Thanks.
Old 10-28-2005, 09:47 PM   #12
racepimp
Member#: 76623
2002 WRX sedan
Black Pearl
Just got it home, thanks again Shane!
Runs perfect down the freeway, I can't wait to start the swap. Nice doing business with you, talk to you soon. - Enrico
Old 10-28-2005, 10:31 PM   #13
Warp3
Member#: 161
06 WRX TR (SGM)
89 MR2 (Ice Blue)
Great doing business with you, too.
Turbos are fun when it's cold out, aren't they?
Shane
Old 10-29-2005, 10:39 PM   #14
racepimp
Member#: 76623
2002 WRX sedan
Black Pearl
Swap started.
Old 10-29-2005, 10:55 PM   #15
IronMonkeyL255
Member#: 38120
1991 Rio Red
Legacy Turbo
Awesome.
FS: wrecked 1991 Subaru Legacy Sport Sedan Hardware89 Legacy Specific Parts 26 04-20-2010 02:33 PM
1991 Subaru Legacy Sport Sedan Turbo 4WD \ AWD - Cleveland OH dolinga Private Vehicle 'For Sale' Classifieds 0 05-04-2008 10:30 AM
F/S: 1991 Subaru Legacy Sport Sedan (Turbo) Opie Private Vehicle 'For Sale' Classifieds 12 03-25-2004 04:01 PM
F/S: 1991 Subaru Legacy Sport Sedan (Turbo) Opie South East Region Forum 22 03-20-2004 10:51 AM
