Old 10-27-2005, 06:28 PM   #1
Impr3zy0u
Member#: 93404
Default screwed idle.
Ok i cant figure out what it going on with my idle and its pissing me off. I really dont want to take is to the dealer. Anyway so when i start my car in the morning the idle is fine when its worming up at like 1500 rpms, but if i take off and come to a stop sighn the idle will bouce rapidly like 4 times then stedy off. Also when the engine is at normal idle speed but not 100% wormed up the vacume is a couple psi less then when its fully worm, not sure if this is normal. Every time i let off the gas the idle will dip down alittle past where its supposed to go and the car shakes alittle. Also when its just idleing normal it seems to be more rough and not as steady as in the past. I cleaned the sensor in the intake with alchol, and the IAC valve with gas, and that seemed to make it worse. I know that the sensors are atleast functioning because when i unplug them the idle gets even worse. ideas please
Impr3zy0u is offline   Reply With Quote
Old 10-27-2005, 06:51 PM   #2
cdvma
Member#: 21980
2002 PSM WRX (Sold)
2009 BMW X5
Do you have any modifications? Have you tried reseting the ECU?
cdvma is offline   Reply With Quote
Old 10-27-2005, 06:59 PM   #3
EagleRockWrex
Member#: 95780
2008 Infinity G37S
Ivory/Black
vaccuum leak
EagleRockWrex is offline   Reply With Quote
Old 10-27-2005, 07:03 PM   #4
silentbob343
Member#: 57307
soooo many things. I had an idle problem and the FSM threw out about 20-30 things to look at. I would check for vaccuum leak first and pray it's not an IAC problem as they cost a bit of money, at least for my car.
silentbob343 is offline   Reply With Quote
Old 10-27-2005, 07:47 PM   #5
Impr3zy0u
Member#: 93404
i did reset the ecu, i was thinking a vacume leak but the vacume goes normal once its wormed up "-18, -19", when its cold its at like -14. Mods are removed sliencer, downpipe, and catback. Stock up-pipe. Thats about it engine related. How could i check for a vacume leak. I looked around for a bit and didnt see anything. Thanks.
Old 10-27-2005, 08:00 PM   #6
cdvma
Member#: 21980
2002 PSM WRX (Sold)
2009 BMW X5
Spray carb cleaner (not insanely) around vacuum hoses and on parts of the intake. If the engine revs up when you spray it somewhere - bingo thats your leak.
Old 10-27-2005, 08:18 PM   #7
Impr3zy0u
Member#: 93404
awesome, thanks!!
Old 10-28-2005, 01:53 AM   #8
spongejosh
Member#: 62783
Midnight Black Pearl
did you use a new gasket on the iacv after you cleaned it?
josh
spongejosh is offline   Reply With Quote
Old 10-28-2005, 10:32 AM   #9
Impr3zy0u
Member#: 93404
yes..
My Outside temperature display = screwed after new radio? Myth21 Electrical & Lighting 2 06-03-2010 04:08 PM
HELP!!! Screwed up idle after clutch install! BenBortner Normally Aspirated Powertrain 10 06-20-2005 10:56 AM
HELP!!! Screwed up idle after clutch install! BenBortner North West Impreza Club Forum -- NWIC 1 06-19-2005 06:15 PM
Idle screw benjaminetanyahoo Normally Aspirated with bolt-on Forced Induction Powertrain 9 06-19-2004 11:42 AM
Where is/ or is there an idle adjustment screw for 02' Wrx? PaulRex Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 5 02-14-2003 06:19 PM
