Welcome to the North American Subaru Impreza Owners Club Tuesday August 23, 2016
Old 10-27-2005, 11:53 PM   #1
Kushmasterh
Member#: 70027
2004 WRX STi
Platinum Silver
Impreza WRX STi Questions about Defi Gauges?
Just wanted to know if any one has experienced the same thing I have with the Defi Boost gauge in kPa format.
I have the TurboXs UTEC installed with the boost controller that comes with the utec but it has not been turned up, with the stock map installed it jumps up the boost to 16.5 psi like its supposed to.
But my problem lies in when I had the stocker gauge pack installed and it would read 16.5 psi and now since I have changed the gauges to the Defi's it reads 1.5 kPa at full boost, this measures out to be 21.75 psi! I had used the same boost line tube that the stocker was running off of cause it looked the same diameter as the new tube and then ran it to the relay box that defi gives you, could it be the line causing the readings? Can anybody provide any insite on why this would be happening? Thanks in advance
Kushmasterh is offline   Reply With Quote
Questions about DEFI gauges WrxRick Interior & Exterior Modification 1 10-01-2009 10:08 PM
? about DEfI gauges and Airbag light altima04 Electrical & Lighting 3 09-07-2006 09:57 PM
Questions about Defi Install Shabib67 Electrical & Lighting 0 12-20-2005 11:23 AM
question about DEFI gauges Vampyr Newbies & FAQs 8 10-13-2005 02:28 PM
Quick Question about Defi Boost Gauge BlackSun Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 3 09-18-2005 05:03 AM
