Old 10-28-2005, 01:16 AM   #1
ColesSTi
Member#: 99205
2005 Impreza WRX
Default how to make the STi 300WHP?
What do I need I already have 4 things GP header, GP full race exhaust, and short ram intake,ground wire kit.
ColesSTi is offline   Reply With Quote
Old 10-28-2005, 01:18 AM   #2
BOOST3DWRX
Member#: 96454
2012 STi Stage 2
turbo, em, injectors, fuel pump
BOOST3DWRX is offline   Reply With Quote
Old 10-28-2005, 01:25 AM   #3
Usaf*STi
Member#: 88063
06 STi
Black as night
all you need is some good EM, and a TBE. search and you can find some ppls dynos with just those 2 mods. some ppl have seen as high as 308whp. turbo and injectors you better be getting up to 400whp soon.
Usaf*STi is offline   Reply With Quote
Old 10-28-2005, 01:33 AM   #4
jchuiy03
Member#: 85204
2005 stg 4 FP Green
Obsidian Black Pearl
EcuTek reflash plus what you have there will get you there. No need for larger injectors or high pressure fuel pump until you get a bigger turbo. Also, 300whp on which dyno? Stage 2 should read over 300whp on a dynojet vs. just around 300whp or a little less on a Mustang.
jchuiy03 is offline   Reply With Quote
Old 10-28-2005, 01:50 AM   #5
NaVaWRX
Member#: 48381
intake header dp and exhuast and ecutek, u'll be at 300 awhp .. easy if not enough, get a fmic add some more ..and then after all u'll want to upgrade turbo
NaVaWRX is offline   Reply With Quote
Old 10-28-2005, 05:27 AM   #6
dl337j00
Member#: 58049
1990 Skyline GTR
Gunmetal Grey
most ppl will say that a good intake, EM, and catless TBE will get you 300whp.
my personal preferance for those three are:
- Invidia catless downpipe w/ catless race catback.
- K&N Typhoon shortram
- TurboXS UTEC
dl337j00 is offline   Reply With Quote
Old 10-28-2005, 04:03 PM   #7
ColesSTi
Member#: 99205
2005 Impreza WRX
Whats wrong with the stock turbo? I want to keep it reliable. I really like the ESX
setup. GP moto now makes one close to it its a kit, mkes 420 at the crank, its $6000 also is GP motos chip good they tune it for you they said they do it very aggressive so it makes a lot of power.
If you think I should up grade the turbo whats a good one I just want to make some more over the stock turbo maybe 320chp or 350chp? Thanks
Old 10-28-2005, 04:11 PM   #8
GTWORX.com
Member#: 97303
2009 WRX and Boxster
Gray and Black
You should be almost there, no need for a new turbo just to get over 300whp.
TurboXS UTEC will get you over the mark.
Myles Williams
www.GTWORX.com
GTWORX
(division of Racecomp)
9123 Old Annapolis Rd
Columbia, MD 21045
410-730-7223 Phone
410-707-0108 Mobile
410-730-5503 Fax
GTWORX.com is offline   Reply With Quote
Old 10-28-2005, 04:43 PM   #9
WrxWonderWagon
Member#: 67265
04 35r Sti meth
What Spelluring?
300whp is never enough
WrxWonderWagon is offline   Reply With Quote
Old 10-28-2005, 04:51 PM   #10
OMEGA SUPREME
Member#: 89995
05 Broke STI
Amen to that
OMEGA SUPREME is offline   Reply With Quote
Old 10-28-2005, 11:06 PM   #11
scoobyimpreza
Member#: 11454
1998 impreza L
brillant red
add water/alky to the mix!
scoobyimpreza is offline   Reply With Quote
Old 10-28-2005, 11:35 PM   #12
KEVINL
Member#: 3525
2004 Duramax W/500HP
And Want another STi
It also depends if you are using 91 or 93 octane I have been told 300whp won't happen on 91 with the stock turbo
KEVINL is offline   Reply With Quote
Old 10-29-2005, 09:55 AM   #13
Tuning Factory Inc.
Vendor
Member#: 3600
On 93 octane I get around 305 WHP with:
GT Spec header
Turboback
UTEC
Tuning (being the key element)
Tuning Factory Inc. is offline   Reply With Quote
Old 10-29-2005, 11:28 AM   #14
keaniegenie
Member#: 94494
2005 Element 92x
The only problem with a stock turbo is it's size. Being that the 2.5l block has pretty good torque, and that the gears are short due to your 6 speed, you will have a pretty responsive car on the bottom end even if you go with a larger turbo (especially if you are doing other mods such as tbe, uppip, dp, em). You may get to 300whp on the stocker, but you'll feel it all at the bottom to middle range. The power will drop off very quickly on the top end of the power range.
A larger turbo can give you a more consistant hp and torque curve through out the power band. 300whp is very easy to get on an STi. It's a lot more fun if it's 300whp & 300wtq all the way to redline. Then you don't have to worry about an M3 passing you on the freeway. Just my IMO.
keaniegenie is offline   Reply With Quote
Old 10-29-2005, 03:17 PM   #15
ColesSTi
Member#: 99205
2005 Impreza WRX
my dad was going to get a M3 but the dealer had problems ordering it.
I talked to Paul at primitive he said the WRC's are 300whp and he said thats what there rally cars are. So I think around 300whp would be good.
If i put all the stuff on with a EM I will have around 370chp
right now it is stock at 300chp and 238whp...numbers from subiesport
Old 10-30-2005, 01:34 PM   #16
dl337j00
Member#: 58049
1990 Skyline GTR
Gunmetal Grey
238whp is being a bit conservative... i like to say 245-250whp.
and most people dont say 'chp' for crank hp.. they just say bhp (brake hp, same thing)
How hard is it to make the STi seats heated? UltimateLurker Interior & Exterior Modification 14 11-08-2005 12:59 PM
How to make the wiper stop moving? Hojai Interior & Exterior Modification 3 07-10-2002 04:53 PM
Any ideas on how to make the doors feel/sound more substantial? AllWheelsDriven Car Audio, Video & Security 33 06-07-2002 01:00 PM
How to make the doors lock when the car is put in gear? jmonusko Car Audio, Video & Security 3 05-07-2002 04:12 PM
How to make the loudest noise from these mods jImp Normally Aspirated Powertrain 17 03-07-2001 06:32 PM
