10-28-2005, 04:54 AM | #1 |
Member#: 19346
Vehicle:2003 MBP WRX Wiseco / Oliver EJ257 |
UTEC map for PE800 on EJ257
I need a utec map to use as a base for my tune. I'm going to be running an ej257 with V7 heads and pe800's. I'm really just looking for a starting point, so your setup matching mine exactly isn't necessary.
10-28-2005, 08:33 AM | #2 |
Member#: 32792
NESIC
Vehicle:2003 GGA MBP 12.9 / 105+ |
do you have an obd2 scanner?
by scanning fuel trims and adjusting the injector scaling on the utec to zero them out while in closed loop you can get pretty close to a baseline. |
10-28-2005, 03:11 PM | #3 |
Member#: 19346
I don't have a scanner that can read fuel trims...
UTEC map for V7 heads/ecu and EJ257 | Javier | Engine Management & Tuning | 1 | 10-07-2005 12:59 PM |
looking for a utec map for wrx 2.5 liter sti motor | wrx1105 | Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) | 1 | 07-07-2005 07:48 PM |
Anyone have a UTEC map for a EJ257? | All8up | Engine Management & Tuning | 2 | 01-30-2004 08:29 AM |
WRX desperate for UTEC map for running on nitrous at 5000 ft+ | ABQnitrous | South West Impreza Club Forum -- SWIC | 1 | 12-15-2003 07:32 AM |
WRX desperate for UTEC map for running on nitrous at 5000 ft+ | ABQnitrous | Engine Management & Tuning | 0 | 12-10-2003 01:04 PM |
