10-28-2005, 10:02 AM | #1 |
Member#: 84482
Vehicle:2005 STI.UR gt4088r E85 pro comp sti |
manual boost controller question
i just installed a manual boost controller in my 05 sti. I believe i have the correct hoses going into the controller. I also am using all new hoses, none of the stock hoses are being used. The problem is i can't change the boost. I turn the nob clockwise and it does nothing. Since the new boost controller i am only boosting at .5 bar on my stock boost gauge. I was told if u remove the one vac. hose from the incar controller it would cause the car to overboost. I tried this and my car would still not overboost...anyone have any ideas or know anything about this problem of not being able to increase psi.
10-28-2005, 11:03 AM | #2 |
Member#: 28823
NWIC
Vehicle:2004 WRX Wagon Black |
If boost levels are unchanged, you must not be affecting how much pressure is reaching the wastegate actuator.
Take a look at the wastegate actuator and tell us where the hose goes that is connected to it. Is it a bleeder style or ball and spring style controller? BTW I don't know anything about STi's, but you would definitely not want to run a manual boost controller to replace the OEM boost control on a WRX. Even more so an a 2004 or 2005 model. You may want to search around to see if this is safe on an STi (assuming you have not already done so). -Adrian |
10-28-2005, 11:12 AM | #3 |
Member#: 75129
Vehicle:09 WRX stg 2+ Lost the boxer rumble |
Do you still have the OEM boost solenoid in place and hooked up? If so you need to bypass itThus the name Manual boost control, remember to leave the electrical connection on the boost solenoid hooked up so you don't get a (cel)
10-28-2005, 12:38 PM | #4 |
Member#: 1531
RMIC
Vehicle:2008 GRB Red |
try reversing the lines to the boost controler and make sure to cap off the solenoid so dust and debris dont get inside the unit and ruin it.
10-28-2005, 08:24 PM | #5 |
Member#: 36528
Vehicle:2002 Impreza Wrx Silver |
If you take the tube off the turbo or actuator, you should be hitting more boost. Sounds like your wastegate might be stuck open?
peace |
10-29-2005, 12:00 AM | #6 |
Member#: 88698
NWIC
Vehicle:'05 Best e.t. 11.8 Best Trap: 123 MPH |
I'm predicting the title of this starters next post: "So Subaru denied my warranty..."
10-30-2005, 10:10 AM | #7 |
Member#: 90566
Vehicle:1999 Legacy 2.5 GT I want JDM WRX! |
what kind of MBC did you get? Im trying to do a bit of research. I need one for a crazy set up I bought to turbo my Legacy GT.
11-07-2005, 09:57 AM | #8 |
Member#: 84482
boost controller failure
i bought it off e-bay, just look under the manual boost controller and it was the 50 dollar one, so i guess the quote what u pay for is what u get, b/c i couldn't get it to work, so i just purchased a electronic greddy controller, i can't wait for it to get in
manual boost control question | nasiocjunkie | Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) | 6 | 07-06-2005 04:51 PM |
manual boost controller question | WEBZ090909 | Mid West Subaru Owners Club Forum -- MWSOC | 4 | 06-23-2005 09:01 AM |
Manual Boost Controller Question | Tarmac Terror | Normally Aspirated with bolt-on Forced Induction Powertrain | 6 | 02-05-2002 11:58 AM |
manual boost controller questions | david angenend | Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) | 1 | 08-22-2001 04:58 PM |
manual boost controler question | bttune2.5rs | Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) | 2 | 05-30-2001 06:26 AM |
