Old 10-28-2005, 10:28 AM   #1
dingy
Member#: 95843
2002 WRX & 98GT
SILVER / GREY
Default HELP! 98 Legacy Gt Just Turbo'd
Yo what up i just got done doin my turbo set up looks awsome & runs like s**t ...... im using a wrx intercooler and a t3 garrett custom uppipe and downpipe.... the only thing that i noticed that looks bad is the charger line from the turbo to the intercooler is kinked.... i car idles ok (untill) you drive it you can hear the turbo spool but NO bov noise... when you come to a stop the car wants to die any idea what i got goin on.....
also right now im babing the car b/c i have no management on the car.... but i cant see that beening the problem b/c it even does the dieing thing when you shift it at 2500rpms at 1/4 throttle......
dingy is offline   Reply With Quote
Old 10-28-2005, 11:45 AM   #2
Sko
Member#: 90396
2005 Legacy 2.5i
Brilliant Silver Metallic
Engine management. Perfect power is a good piggyback EM setup with pre-made maps that would work fine for your setup I suggest you talk to the guys at Rallitek. www.rallitek.com even if you don't want perfect power, they can probably diagnoss your problem if you tell em whats going on.
Nick
Sko is offline   Reply With Quote
Old 10-28-2005, 12:03 PM   #3
Tats
Member#: 5692
WTF? YES! I am
better than you!
How much boost are you running?
Factory 98 MAF, pump, and injectors should be able to add enough fuel for 4-5psi.
Engine management is definately recomended when you can get some.
As for the dying all I can suggest to check is:
1. Possible blown MAF? Check the voltage with a meter.
2. Check all you vacuum lines. You will get all kinds of crappy stuff is one is not connected good. MY RS-T used to die all the time until I found a vacuum leak.
Hope this helps.
Tats is offline   Reply With Quote
Old 10-28-2005, 12:13 PM   #4
dingy
Member#: 95843
2002 WRX & 98GT
SILVER / GREY
Im running 4.5psi with a adjusted wastegate actuator.... i know the top of the purge sensor broke off also the MAF is fine.... let me ask you another question is the where did you connect the bov vacuum line to... i connected mine at the (stock fpr) fuel pressure regulator
also where do i hook up my vortech fmu..... (only using the fmu till i get enough money for a piggy back)
Old 10-28-2005, 06:54 PM   #5
leondal
Member#: 43114
1998 Legacy GT Turbo
Green
What BOV are you using? You probably have to tighten it
so it doesn't open so easily.
leondal is offline   Reply With Quote
Old 10-29-2005, 07:11 AM   #6
sixpack subaru
Member#: 64974
1995 WRX,APEXi,HKS,$
Faded, Stonechipped Red
Subaru Stars
I would not do that way thing also my friend not good, many broken parts litter your undertray...!! HA
CHeers bud, keep up the good work!
Sixpack Subaru
sixpack subaru is offline   Reply With Quote
Old 10-29-2005, 07:28 PM   #7
dingy
Member#: 95843
2002 WRX & 98GT
SILVER / GREY
well my soga continues i got my idling fixed, i think the purge selinoid top was cracked off and i also disconnected the bov the car idles fine now, but i think my turbo crapped i no longer have boost i checked all the vacuum lines all the charger lines the boost gauge goes to (0) and thats all i got i dont hear the turbo spooling... this is not goin the way i planned.... im goin to mess with it tomarrow to see if the wastegate cracked or if the actuator is stuck open i will keep you guys post... i dont have access to post pics yet if so direct me in the right direction and you will get to see my non boost lookin awsome turbo setup
Old 10-30-2005, 05:39 AM   #8
Tats
Member#: 5692
WTF? YES! I am
better than you!
Looks like you now have enough posts....try a hosting place like we-did-tood racing.com
Old 10-30-2005, 08:34 PM   #9
dingy
Member#: 95843
2002 WRX & 98GT
SILVER / GREY
ok got everything goin now ... the turbo is fine the wastegate rod popped of thats why i had no boost .... i got a turboxs bov today i made a plate so all i need to do now is have a aluminum bung welded on and im good to go....anyone have any idea on where to hookup my fmu (what line)
Old 10-30-2005, 08:35 PM   #10
dingy
Member#: 95843
2002 WRX & 98GT
SILVER / GREY
oh also im still lookin for a hosting site
Will a 97-00 Impreza front Strut Tower Bar fit my 98 Legacy GT? jacobhorn Legacy Forum 4 11-14-2001 08:10 AM
Found: 98 Legacy GT Limited FS Cheap!! MY99 2.5GT South East Region Forum 11 07-28-2001 10:18 AM
Exhaust for 98 Legacy GT. Any Suggestions? jacobhorn Legacy Forum 4 03-25-2001 09:15 PM
Trading MY00 RS rims for 98 Legacy GT rims Kilalee Legacy Forum 18 02-26-2001 12:18 AM
98 legacy gt noises? front end? jagcars26 Technical Forum Archive 1 10-11-2000 01:51 PM
