#1 |
Member#: 1170
BAIC
Vehicle:2005 STi White |
I'm wondering what the max boost the 4eat has seen. I've seen a couple 7psi people but anyone running 10+?
#2 |
Member#: 626
Vehicle:2001 Impreza 2.5 RS Black Diamond Pearl |
Joe Hogan is the man to talk to. I ran 7.4# in my 2000 with no tranny work (and no electronics).
#3 |
Member#: 481
adam bloom did over 20psi, didnt he?
though i think it broke the motor at 24#. my memory isnt what it used to be though so i may be mistaken. g |
#4 |
Moderator Member#: 922
Vehicle:04 FXT Red |
giulio - I think he ran like 18, actually. But that was on a STi RA manual trans, not a US-spec auto.
I think Kevin Thomas would be the man to talk to about this one, though he was running on an EJ22 instead. |
#5 |
Member#: 1170
BAIC
oops, forogt bout the tranny forum. if this shoudl be moved, move it.
#6 |
Member#: 330
12 psi is the max anyone should run on the stock EJ25 for racing, not even using it for daily-driving. all the blown engines are resulting from people pushing their boost too far. As for the tranny, gears can be broken on light boost. it all depends the driver. I drag raced my five speed gears at 10 psi and drove around for about two weeks and did not have any problems.
#7 |
Member#: 1170
BAIC
well thats nice for your MT but I just want to know the max someone has boosted on the Automatic 4EAT. I KNOW the MT can handle a fair amount of boost but everyone talks about the 4eat being stronger. well i want to know the boost limit at when things start to break down and what exaclty breaks down. is it that it just gets too hot? does the torque converter fail or something? what happens?
#8 |
Member#: 626
Like I was saying Andrew, Joe Hogan is the man to talk to. He has a EJ25 4EAT. As far as i know you need to do some work to the TC, maybe some more stuff.
#9 |
Member#: 9316
Vehicle:1997 Legacy GT 14.767@93.54 |
Andrew,
If you can post your findings on that here that would be great. I'm wondering the same thing. I have almost all the parts for my turbo, wonding if/how soon i'm going to need trans parts. Mike |
#10 |
Member#: 699
Vehicle:2002 golf TDI Blue |
It appears that the 4EAT can handle somewhere around 300-325 HP. When you push more than that the clutches begin to slip at the shift points. This is with very high line pressure and street tires. R tires would probably cause more slip.
This info was gathered with a Level 10 competition tranny, valve body and TC. We are on the third edition of the competition tranny. Most trouble has been with the TCU and the everyday grind of a daily driver. When everything is working with this tranny it is very powerful. However the electronics are a bear. Most people that race with this tranny use a MY98 or earlier. Rally Khight uses a MY98 4EAT with a manual shift valve body. Not something that can easily be lived with on the street .... though I have considered it:P I'm going for broke [literally] with the 4EAT. Pat at Level 10 and I are close to getting it right. Then I can get back to making 400 HP with the Cobb motor in the car ![]() |
#11 | |
Street Racing Instructor
Moderator Member#: 110
Vehicle:1989 1989 XT6 |
I don't know what 5psi of boost and a 70 shot of nitrous is comparable to boost only but that's the highest I have gone (A big mistake but didn't notice the 70 shot nozzle until 2 bottles later and lots of unnatural burning metal smells coming from my engine bay). ![]() |
#12 |
Member#: 1170
BAIC
isnt 1psi equal to around 10hp. if thats true, then kevin you might have been pushing an equivalent of 12psi. but im probably wrong.
#13 |
Member#: 626
yeah as far as i know (reason it out) it wont equate like that. psi = lbs per square inch i.e. a pressure. so since nitrous is only adding oxygen and nitrogen (catalyst right?) to the air/fuel mixture you dont add the two together for a turbo/nitrous car.
unless you were equating it to psi needed for a turbo car to match the hp output of turbo/nitrous. |
#14 | |
Member#: 1170
BAIC
kevin, you were doing 70shots with or without the bottle warmer? IIRC once you put on the bottle warmer it shot the bottle PSI through the roof and lead to the failure of the tranny. or am i wrong? |
#15 |
I didn't mean for you to put the two together. I was only running a 60 shot when the tranny went and the 60 shot was with a newly installed bottle warmer. I ran a 70 shot a few months back by mistake. Nothing happened bad. I just noticed odd metal scents coming from the engine bay.
On the other hand, I was wondering what the hp equivalent of pure boost was/is as compared to a 60 shot (with bottle warmer) and 5psi of boost from a Minnam turbokit. If somoene new the answer (Say 10psi of boost) then I am assuming you can say this is where you could expect your tranny to fail. Everyone's car is different and someone else's tranny may fair much better or worse but this could give you an estimate of sorts on where you can expect tranny failure (without a tranny cooler or any upgrades to your transmission). |
#16 |
Member#: 626
well kevin you maybe are overlooking the easier comparison, instead of equating it to boost, equate it to hp. if with 5psi and a 70 shot you are getting peak 310 at 6krpm then your tranny may not last much longer.
but i have an interesting quesiton here: dont most good nitrous systems inject at WOT and stop when the throttle closes (come off the gas to shift? oops exclude the auto guy)? oh well since this is an auto related thread skip that wondering. cuz i was saying no nitrous off-throttle would drop your hp output down enuff to make it a less stressful shift. |
#17 | |
#18 |
Member#: 1170
BAIC
if the problem is when it shifts and the clutches slip, then an EBC should work wonders. we could lighten the PSI as we get higher in the RPMS and around 6k drop it to around 5-6psi. that should help it shift better than at a flat 10psi. or am i wrong?
#19 |
Member#: 626
True kevin. That was what i meant... torque. just didnt say it
![]() EBC? I do not understand how that helps the situation. I am not saying they do not exist (maybe the expensive fuzzy logic ones do this) but i do not know of any boost controller that tapers off boost at higher rpms. but when you think of it, this is not that hard of a feature to have in a boost controller so maybe they do exist. The truth about our AWD tranny and high torque output is sometimes even stock cars get broken gears (some have this bad claim to fame like Danny). so tapering off the boost from 10psi to 5psi will help, but once the shift isnt smooth the shock may still kill your tranny. Seems to be no cheap way around more power and bulletproof tranny. I think the auto guys are gonna have the best chance tho. shouldnt have jumped on the manual train. only if level 10 returned my emails!!! |
#20 |
Member#: 1170
BAIC
i thought all EBCs can tapper off boost. I KNOW the AVC-R can do it.
#21 | |
I had my tranny rebuilt after I got the valve body job but my tranny was already going south. It still preserved it just long enough for some more racing. Remember that Level 10 isn't the only game in town, just the most popular autotranny shop. A shop near me swears they can upgrade any autotranny valve body and torque convertor of a car that I bring in. I'm sure there are autotranny shops all around a good bit of us that we have not bothered to give a call. Keep the info coming. |
#22 |
over boosted again
Moderator Member#: 1458
RMIC
Vehicle:2006 B9 Tribeca LTD 2005 Impreza 2.5 RS |
Mark Josetsky (he was "mjos" here) ran his AutoTranny turbo at 14 psi here at 6,000 feet a few times with no problems.
Joe at JC Sports bought the car when Mmark got a new S4 as a company car, and still has no trouble with the autotranny a year later, although he did blow the motor and dropped a 2.2L in it with 8.5:1 pistons and runs 7 psi now. Larry |
#23 | |
#24 |
over boosted again
RMIC
Wow, that was a slow turbo then, running a 14.6 @ 14 psi at 6,000 feet - my 5 speed got a 13.7 on only 3 cylinders and 8-10 psi at Bandimere
![]() Larry |
| Thread Tools | |
| Display Modes | |
| stock EJ25 and stock EJ18 crank pullies swappable? | annointed | Normally Aspirated Powertrain | 5 | 01-16-2006 09:31 PM |
| MAX pump gas boost on Superzilla's | 13secwrx | Factory 2.5L Turbo Powertrain | 7 | 05-16-2005 01:54 PM |
| What is the most power anyone has made on a usdm 2.0 | slowwrx | Factory 2.0L Turbo Powertrain | 10 | 03-18-2005 07:28 AM |
| Whats the max number of PM's before your box gets full? | Extraze | General Community | 4 | 09-07-2002 02:00 PM |
