Old 10-28-2005, 04:23 PM   #1
benetton
Member#: 99404
Default Reverse circuit 2005 STI cluster
I'm in the process of installing a 2005 STI cluster into my 2004 WRX
I know some people have had problems with the buzzer going off of the time, but I figured that one out , the only problems I have is that the ABS light stays on(or actually works backwards), in the schematic it shows a reverse circuit, does anyone here know how to make a reverse circuit???
I have search the forum, but can't seam to find anything.
Thanks Brad
and if anyone else is doing the same install, just disconnect the wire in C9 to stop the buzzing
benetton is offline   Reply With Quote
Old 10-28-2005, 04:34 PM   #2
Okita Souji
Member#: 41097
2005 WRX
Are you putting in a JDM cluster or a USDM cluster?
I'm just trying to figure out the buzzing thing cause mine didn't buzz when I installed it. Wiring schematics for that part of the cluster are the same between 2004 and 2005 which is odd.
Okita Souji is offline   Reply With Quote
Old 10-30-2005, 09:31 AM   #3
vwown3d
Member#: 69991
Leh Keen Approved
'68 Volvo Amazon
only thing i can think of is using a tiny IC and telling it to reverse the on/off sequence. otherwise just slap a huge resistor on there and try to kill the voltage to the light
vwown3d is offline   Reply With Quote
Old 10-30-2005, 02:08 PM   #4
jdm_wrx
Member#: 84977
ASPEN WHITE
how did you get the gas gauges to work?
jdm_wrx is offline   Reply With Quote
Old 10-31-2005, 07:50 PM   #5
benetton
Member#: 99404
I live in canada, the sti cluster is from a 2005 sti and I put them in a 2004 wrx, the buzzer stopped when I removed the terminal from C9 this is the dash lumination on a 2004 wrx, but casues the buzzing on the 2005 sti cluster, like I said the only problem now is the abs light is working backwards, if you look at the schematic it shows a reverse curcuit.
thats what i'm trying to find out how to make.
Old 10-31-2005, 08:00 PM   #6
benetton
Member#: 99404
the gas gauge wiring actually go in the exact location, if you look at the connector, but there are different terminal cavity numbers, because the connector actually has two extra terminals
if you want to use the cavity numbers just follow this
sti wrx
a3 a2
a11 a9
a10 a8
this if for both the temp and fuel gauge
Old 03-14-2006, 10:00 PM   #7
Bullitt 2496
Member#: 53724
2013 Subaru BRZ LS2
has anyone figured out the "reverse circuit" yet?
Bullitt 2496 is offline   Reply With Quote
Old 05-04-2006, 07:21 PM   #8
benetton
Member#: 99404
no not yet, still looking
Old 12-28-2006, 11:36 AM   #9
Chapel
Member#: 3496
1995 Roadmaster
Beige
what about the blown fuse
what wire causes that?
Chapel is offline   Reply With Quote
FS: PDX Oregon - 2005 STI cluster, 06 sti front/rear seats austinramage Interior/Dressup/Audio & Security 1 07-01-2009 06:58 AM
2005 sti cluster into 2002 wrx ThisizBrian Interior & Exterior Modification 8 12-27-2006 09:59 PM
WTB: 2005 STI cluster Trigun001 Private 'Wanted' Classifieds 1 10-17-2006 11:20 PM
2005 STI cluster in a 2002 WRX- HELP!! SPOOLDU Electrical & Lighting 1 07-31-2006 07:55 AM
F/S 2005 STi cluster with ~ 365 miles 1688 Private 'For Sale' Classifieds 4 09-19-2005 04:02 PM
