Welcome to the North American Subaru Impreza Owners Club Monday January 26, 2015
Old 10-28-2005, 06:57 PM   #1
Gruppe-S
Member#: 23216
2006 949-457-1234
949-457-1234
Default Call us believers (alky injection)!
Hey all,
So for quite awhile now, the rumors and facts about alcohol injection have swirled around. Is it safe? Is it one of the best bang for the buck power adders on the market? Are the gains real and consistent? We wanted to find out what all the fuss was about so we tested one of SMC's alky injection kits on Mike's 2.35L GT35R shop car. There are no completely new, earth moving, or mind blowing results or findings here but we were suprisingly impressed with the reliable gains shown by the kit.
A little background first:
Alcohol works by doing the following 2 important things:
1) It lowers the temperature of the intake charge thus creating a denser (and greater) air mass.
2) It raises the effective octane of your fuel which works towards avoiding detonation (the sworn enemy of engines).
These two factors are particularly beneficial on turbocharged cars because the effectiveness of turbocharging is dependent on having a dense and cool intake charge while also avoiding detonation. Boosted engines are particularly succeptable to detonation because they can see such high pressures and temperatures. By increasing the effective octane of your fuel, it allows you to run higher boost and also add more timing advance. As an added bonus, it also cleans carbon deposits in your engine.
Enough of that, here are the results:
+43.8 WHP and + 28 WTQ
Essentailly, alky injection appears to be like instant racegas for a whole lot cheaper. It runs on denatured alcohol which can be purchased for under $10 a gallon at places like Home Depot (the kit comes with a 1 gallon tank). If used correctly, it is safe, cheap, and effective way to gain reliable power. In fact, alcohol injection could be arguably the best bang for the buck power adding modification on the market. SMC is currently working on a failsafe that will be implented on their new kits. This will insure that when you're running out of alcohol, your car will revert to normal boost. We are very excited to be offering these kits for sale to the general public and look foward to testing them on many other applications. For more info, please check out our post in the Vendor thread.
Thanks,
Geoff
Gruppe-S is offline   Reply With Quote
Old 10-28-2005, 07:14 PM   #2
elucas730
Member#: 42714
'07 BMW 335i E90
Geoff,
Any idea on the ETA and cost for the failsafe? My job deals heavily with redundancy management on flight critical hardware, so I am always looking for the 'backup' plan. From what I've been reading, these alcohol injection systems are 'single point failures' (i.e. where a failure of one part causes the whole system to fail - in this case, a failure of the injection system can cause catastrophic engine failure). First of all, how true is that, and second, what else can be done to mitigate the risk?
elucas730 is offline   Reply With Quote
Old 10-28-2005, 08:09 PM   #3
the coordinator
Member#: 99448
If there is a fueling failure, will the alcohol stop immediatly?
Big Vin
the coordinator is offline   Reply With Quote
Old 10-28-2005, 09:34 PM   #4
garie
Member#: 26607
2002 wrx wagon
aquamist has a setup that autoshutsdown if something is wrong iirc
garie is offline   Reply With Quote
Old 10-28-2005, 10:01 PM   #5
Capt Crunch
Member#: 10852
Then : JDM Ver 7 STi
Now : E46 M3 / MKVI GTI
Wow, this is pretty great, I've only started considering this recently.
Capt Crunch is offline   Reply With Quote
Old 10-29-2005, 02:37 AM   #6
SSFWRX
Member#: 31789
Now with 100% more
V8 Spec C and 6MT
great results guys. Seems to be a cost effective way to skate around the limitations of 91 pump.
SSFWRX is offline   Reply With Quote
Old 10-29-2005, 09:47 AM   #7
Ohannon7
Member#: 63824
05 WRX WRB pearl
Cobb II+
would this require a custom tune if you have the Cobb AP?
Ohannon7 is offline   Reply With Quote
Old 10-29-2005, 10:35 AM   #8
AK*WRX*2004
Member#: 56485
2009 Ram 1500 CC SPT
R.I.P. Bro
I have the SMC kit and I was wondering the same. Up here in Anchorage, Alaska we only get 90 octane... I want to run the 93 map but I'm not too sure if I can get good results with the kit.
Steve from SMC is THE MAN... He will help you out with ANYTHING... no matter what, big or small. I can't stress enough how awesome he is... MANY people from the Alaska forum will vouch for Steve and his products. -Gene
AK*WRX*2004 is offline   Reply With Quote
Old 10-29-2005, 11:50 AM   #9
Crawford Performance
Member#: 42075
I would say yes.
We have a car in the shop at the moment that added meth injection without re-tuning the ECU.
It is in for a new motor
Meth injection is a great tool for adding power "and" increasing engine sales. But if you cannot afford to replace your motor, I would not recomend using it.
Quirt Crawford
www.crawfordperformance.com
Crawford Performance is offline   Reply With Quote
Old 10-29-2005, 11:53 AM   #10
notraceready
Member#: 64556
2003 Stg 4 WRX sedan
I just ordered the smc kit from them and it should arrive in about a week. I'll have it put on along with the sr30 and will be getting a tune later in the week. I'd love to get an increase something like you got! What kind of mixture did you run? From the post seems like you ran 100% alky.
notraceready is offline   Reply With Quote
Old 10-29-2005, 12:09 PM   #11
TheMadScientist
Member#: 23717
2005 Big red
I have been a beliver since earlier this year when we installed an SMC kit on Amazake's car. With a few hours of tuning he went 12.94@104, after a retune he went 13.2@105.5mph lastnight on a smoked clutch all on the stock turbo. As long as you can accept the risks involved with runing WI it is well worth it.
TMS
TheMadScientist is offline   Reply With Quote
Old 10-29-2005, 12:18 PM   #12
Member#: 42075
TMS
Well put, I will agree 100%
Quirt
Old 10-29-2005, 01:35 PM   #13
jabbott
Member#: 73054
2002 WRX 2.5, 4eat
I've been using alky for many years now and on many different cars. There is no easier or cheaper way to get that much power gain.
Also an fyi about alky.
Do not use any type of fuel cut (boost cut, rev limiter, etc).
When your injectors shut down you will still be spraying alky which cause an extreme lean condition.
You can run the 93 map with no problem, but it will probably be really rich up top.
You should really only use injection (alky or water) with a tunable engine management (utec, street tuner, etc).
jabbott is offline   Reply With Quote
Old 10-29-2005, 02:41 PM   #14
quadturbowrxgtr-s
Member#: 57515
04 WRX Ver. 8 swap
/87 FJ60 /Hewes Redfisher
By tuneable you mean end-user or could I have this with Ecutek when I get my tune. doesn't the SMC unit come with some sort of controller? also how effective would this be with a VF30 setup? I have seen insane results from extreme setups but not many from the "average" guys setup (vf-22,30,34,39,16g etc.)
quadturbowrxgtr-s is offline   Reply With Quote
Old 10-29-2005, 02:49 PM   #15
TheMadScientist
Member#: 23717
2005 Big red
TD04 traps 105.5mph. Sorry has never been on a dyno.
TMS
Old 10-29-2005, 03:57 PM   #16
quadturbowrxgtr-s
Member#: 57515
04 WRX Ver. 8 swap
can you give some comparative data, I don't have much experience in guaging things by trap speed. I understand fully what it is and what it means but just don't know what stock and others run as references. thanks.
Old 10-29-2005, 04:56 PM   #17
ride5000
Member#: 32792
2003 GGA MBP
12.9 / 105+
105+ is pushing what i would consider ~270 whp. i would also consider that ~370 chp.
jm2c
ken
Old 10-29-2005, 05:07 PM   #18
Gruppe-S
Member#: 23216
2006 949-457-1234
949-457-1234
Hey guys, just wanted to have everyone keep in mind that alcohol injection is NOT race gas, the tuning philosophy is a bit different, so please don't go applying your 100 octane maps to pump gas + alcohol injection.
Quad - On a VF34 2.0 car you should expect to see about a 20-25whp difference with alcohol injection. It's about the whp difference you'd see going from 91 octane to 100 octane. That being said the turbos are pretty much operating at maximum potential at these powerlevels.
Ride5000 - I would consider 270 dynojet numbers. Most of the cars doing about 270whp on our dyno (VF34 cars) are trapping around 108mph and in the low 13's depending on 60'.
Cheers,
Gary
Gruppe-S
Old 10-29-2005, 05:25 PM   #19
Davenow
Member#: 23676
Gruppe-S
From what I have seen the turbo buick gusy are making more power on methanol injection+93 pump gas than they were from race gas...
Also, The TD04 car that trapped 105.5, has already beaten low 13's. He has a 12 sec time slip from that setup. Had his clutch held he may have beaten quicktimes record. Oh yeah that too, he ran 105.5 with his clutch burning though first and second
Old 10-29-2005, 05:26 PM   #20
bren wrx
Member#: 59454
'10 E92 M3 M-DCT
brentuning.com/blog
mmm 25 whp on vf34 setup, does that with 93 octane?
bren wrx is offline   Reply With Quote
Old 10-29-2005, 05:28 PM   #21
Davenow
Member#: 23676
Yup.
Al gained like 49whp on an evo with no other mods. It was an evo with some sort of em, they added the SMC kit (buscher, smc makes it for buscher) and retuned and gained like 49whp.
Old 10-29-2005, 05:53 PM   #22
bren wrx
Member#: 59454
'10 E92 M3 M-DCT
brentuning.com/blog
what do these alcohol kits cost and what are the downsides of them?
you can make 18g like power with a vf34, im all over it
Old 10-29-2005, 07:36 PM   #23
Gruppe-S
Member#: 23216
2006 949-457-1234
949-457-1234
Originally Posted by elucas730
Geoff,
Hello,
I do not currently have an ETA on the failsafe but I know they're trying to get it done as soon as absolutely possible. I'll definitely be in contact with SMC on Monday. It is true that a failure of the alky injection system could potentially blow up your motor as it would cause extreme and instant detonation. The only way to truely mitigate the risk would be to have a fail safe or to not run it at all. Unfortunately, this is true for the vast majority of working parts on a car, performance or otherwise.
Big Vin
A fueling failure is highly unlikely but the progressive pump ensures that the amount of alcohol being injected is proportional to the amount of air and fuel being injested into the motor.
This would definitely require a custom tune. The benefits of alky injection allow you to run higher boost and more timing advance which can only be done with a tune.
You could definitely have this tuned with your ECUtek. The SMC kit comes with a controller for the pump. Like many other performance mods, the gains seen from alky injection are proportional to your mods; there is no flat WHP and WTQ gain that are shown. Again, expect to see gains of 20-30%.
Originally Posted by Davenow
Yup.
Because 4G63s are much more efficient than EJ2XXs, Evos respond to alky injection better than Subarus do. Static compression is higher on the Evo and at peak torque, an Evo might only run 1 degree of timing advance. A Subaru might run 14-15 degrees of timing advance at peak torque. If you then advance timing a couple of degrees on both motors when adding alky injection, the results will obviously be more dramatic on the 4G63.
-Geoff
Old 10-29-2005, 10:00 PM   #24
cdvma
Member#: 21980
2002 PSM WRX (Sold)
2009 BMW X5
One thing I'm always jealous of is the VE of the 4g63. Same power but they run 10 to 15* less timing to make the same power.
cdvma is offline   Reply With Quote
Old 10-29-2005, 11:44 PM   #25
jmussetter
Member#: 15350
2002 WRX Sedan
Midnight Black
What I want to know, is now that the UTEC can do PWM output to it's spare solenoid... what are the MINIMUM parts that are needed for a complete system.
I've seen the SMC kits before, but their progressive controllers were put on the market before the UTEC had the PWM capability and only had a simple on/off switch. The SMC progressive controller filled the gap and allowed the spray to stay consistent with the boost.
Is the progressive controller still needed? Also, a boost sensing on/off switch would also not be needed either correct?
What else would still be required in addition to...
SMC tank
SMC pump
spray solenoid (controlled by UTEC PWM output)
spray nozzle
tubing
Again, this is considering the new UTEC 5.0 firmware capabilities for control?
-jason
jmussetter is offline   Reply With Quote
omfg Stop calling us GURUS kaisersouse Off-Topic 47 04-09-2009 04:52 PM
EP Lawn & Tree: Call us now for free estimate! altima04 Mid Atlantic Impreza Club -- MAIC 4 07-27-2007 11:44 AM
Call us believers (alky injection)! Gruppe-S Water/Methanol Injection, Nitrous & Intercooler Cooling 31 10-29-2005 04:25 PM
So, these 2 guys called us the "N" word... twinbrd Off-Topic 73 05-04-2004 06:41 PM
Your wife called us.... TB RACING Vendor 'For Sale' Classifieds 27 02-21-2004 08:47 PM
