Old 10-28-2005, 08:12 PM   #1
SubieWahn
Member#: 38107
2003 WRX Wagon
Default HIghly Stupid Question - How to remove headlight bulb?!
I'm used to working on American cars, where you simply turn and click, and the bulb comes out of the housing, and the wiring harness clicks into the end of the blub. I went to change the bulbs on my '03 WRX, and while it's dark outside, I noticed that there is a little red cap on the end of the bulb with wiring, and the bulbs wouldn't turn, nor would they squeeze straight out. So - what am I missing?
Doesn't help that it's 30 degrees outside, and I'm holding a flashlight trying to see what I'm working on.... Grrrrrr.
I feel like an idiot.
SubieWahn is offline   Reply With Quote
Old 10-28-2005, 08:23 PM   #2
Mulder
Trust no one
Member#: 11170
02 WRX
15 WRX/05 GTO
The cap is the socket. You push the release tab and remove the socket from the bulb, then turn the retaining ring on the headlight housing counterclockwise to release the bulb from the headlight. If it's easier you can release the bulb first, then disconnect it.
Old 10-28-2005, 08:54 PM   #3
SubieWahn
Member#: 38107
2003 WRX Wagon
Thanks. What do you suggest I use to release the tab? I need to stick something in and push the tiny red part, right?
I gotta do this on a full night's sleep!
Old 10-29-2005, 06:03 PM   #4
SubieWahn
Member#: 38107
2003 WRX Wagon
Update - it was blindingly simple once I figured out that the thing sticking out on top of the socket you push in, and then the entire plug, including what you are pushing on comes out. I was trying to separate the red part from the plug with little success. Now I see how it works, easy - but I would never have figured it out on my own. Thanks!
How to remove headlamp bulbs Chrisnonstop Electrical & Lighting 1 01-30-2004 05:21 PM
How to change headlight bulbs? obsrules Electrical & Lighting 3 12-17-2003 09:19 AM
How to remove/replace bulb on MY02 fog lamps? ChinkyWRX Interior & Exterior Modification 2 10-27-2002 02:13 AM
Help: Can't figure out how to install headlight bulb and harness back into headlight Gypsum2 Interior & Exterior Modification 2 07-29-2002 12:25 PM
How to remove headlights on the 97-01 RS? STi - IMPREZA Interior & Exterior Modification 2 07-21-2001 10:55 AM
