10-29-2005, 02:26 AM | #1 |
Member#: 34661
What should I log to compare a power gain between parts?
I'm going to log two different axlebacks on my car. What parameters should I log to see if there is a noticeable difference in power between the two at WOT? Or would the values be too variable run to run to compare?
I'm using the free Tari logger (latest version ECUexplorer which should have a higher resolution). I assume MAF and RPM would be the key ones, but should I log grams/sec or volts for MAF? I'm going to log on the same stretch of road, same time period (to avoid weather changes).
10-29-2005, 04:34 AM | #2 |
Member#: 2998
VIC
Vehicle:2002 WRX WRB |
Dyno back to back
10-29-2005, 11:35 AM | #3 | |
Member#: 34661
10-29-2005, 12:40 PM | #4 |
Member#: 7327
NWIC
Vehicle:2008 Mazdaspeed3 2006 Wrangler Sport |
Log rpm vs time, nothing else. That's the only way you can really use a logger to determine "power". Of course, you'll need to do some post-logging data analysis to convert that information to a torque/power curve.
10-29-2005, 12:43 PM | #5 |
Member#: 25905
SCIC
Vehicle:2003 Silver Wagon Tuned with Enginuity |
Yep, MAF (either voltage or gram/s is OK), RPM, boost, timing knock correction, and TPS should do the trick.
RPM vs time as mentioned will also work, make sure you use the same stretch of road (which you will want to do regardless). |
10-29-2005, 01:50 PM | #6 | |
Member#: 34661
10-29-2005, 01:53 PM | #7 | |
Member#: 25905
SCIC
10-29-2005, 01:59 PM | #8 |
Member#: 7327
NWIC
yep, you need gear ratio*final drive, tire rolling diameter, rpm, time, mass, aero drag as a function of speed....
those should all be accomplishable in excel. |
10-29-2005, 02:35 PM | #9 | |
Member#: 2992
NESIC
Vehicle:02 WRX Sedan Silver |
For each configuration you should collect data from multiple runs to get a handle on your experiment's variance. You'll likely find that any difference between mufflers will be small and not statistically significant. Last edited by Jon [in CT]; 10-29-2005 at 02:47 PM. |
10-09-2007, 07:45 PM | #10 |
Member#: 125153
Vehicle:2006 Black |
just log MAF grams/sec, more air flow=more power
04STI swap Misfire around 4K rpm, what can i log to rule out fuel components? | bstoehr83 | Open Source Reflashes | 5 | 10-20-2009 09:52 PM |
what should i do next for more power??? | SB347 | Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) | 15 | 08-09-2008 02:07 AM |
Newbie Question - What Should I Log? | adeliciouspizza | Open Source Reflashes | 4 | 07-13-2008 03:51 PM |
GT30R- Greddy evo2 to HKS Hi-power gains ? | WhiteKnight | Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) | 1 | 03-31-2008 07:28 PM |
What turbo came on a ver5/6 sti? What should I upgrade to? | JeremyRS | Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) | 2 | 09-07-2006 08:42 PM |
