Mid Atlantic Impreza Club
Old 10-29-2005, 12:05 PM   #1
BigSlick
Member#: 79919
2014 STI Hatch
Default UPDATE quick ?, swaping WRX IC for STi IC
Anything I need to be aware of or do before doing this. If most of you all don't know yet, I am still learning. Why am I swaping them, well I got a great price on it and it looks good, hehehe, anyways about to do it just making sure there is nothing that I am not aware about before doing this.
Thanks.
I am sure you all can do this in 5 min but may take me awhile
BigSlick is offline   Reply With Quote
Old 10-29-2005, 12:23 PM   #2
84SubaruDL
Member#: 42179
SON! F 22's i roll
on 33" 12 fity SON!!!
keep an eye on your egt's the tend to get high with larger intercoolers
84SubaruDL is offline   Reply With Quote
Old 10-29-2005, 01:07 PM   #3
Bundyboyz
Member#: 32764
2003 WRX with 91K
New Motor & Paint WRB
what? why? Obviously your going to have higher EGT's if you ran no intercooler. (textbook science) So how does cooling the charge even better increase EGT's?
Bundyboyz is offline   Reply With Quote
Old 10-29-2005, 02:32 PM   #4
MD04WRX
Member#: 72891
2014 Molten ST
98 2.5GT -2014 XV
Subaru Banner
If it's a USDM STi intercooler you should get longer intercooler hoses. I tried that swap with the factory hoses and could not get it to fit correctly. The mount brackets are the same but the mounts on the intercooler are in a different place. There is a thread about the problem and all the info you need to get the right hoses. Some people have been able to make it work with out getting the longer hoses but it's a PITA. I was only able to get one of the mount tabs to line up and then you could see the intercooler was setting on an angle. I sold mine and got a JDM STi Iintercooler and it fit perfect. I'll post the link if I can find it.
MD04WRX is offline   Reply With Quote
Old 10-29-2005, 02:38 PM   #5
MD04WRX
Member#: 72891
2014 Molten ST
98 2.5GT -2014 XV
Subaru Banner
Info from post noted above:
I recently purchased an 05 USDM STI intercooler for my 05 WRX. Once again, I confirmed it was NOT a direct bolt-on as covered many times. I was fully aware of this and the mounting option I believe pioneered by BIGSKYWRX as seen on http://www.clubwrx.net/forums/showthread.php?t=51348. Even though welding new bolt holes in the factory mounts (same for WRX & STI) wouldn't be terribly difficult, I decided to see if could utilize factory mounts and correct the STI's throttle body and VF39 turbo positioning differences to the WRX TB and turbo with a new coupler and elbow off the solid y-pipe.
It works so far. The TB to I/C coupler is a Greddy ~65mm ID, 75mm long silicone piece I purchased for less the $10. The stock length was ~47mm. The elbow off the hard y-pipe to my stock turbo is a Turbonetic nitrile elbow 2" x 90' (P/N 30208). About 10mm was cut off one end of the elbow to fit.
Since this mounting location makes the intercooler sit closer to the firewall (same location in an STI), I had to bend the hard A/C lines for clearance.
Old 10-29-2005, 03:14 PM   #6
rogue
Super Moderator
Member#: 7977
100% Abuse
cooler air charge = more air = lean condition = high EGTs
rogue is offline   Reply With Quote
Old 10-29-2005, 03:52 PM   #7
BigSlick
Member#: 79919
2014 STI Hatch
Ok SO, after 2.5 hours which to most of you would of taken maybe 30 min, I got it in all by myself, well with my friend but he doesn know much, infact I know more than him which is pretty bad. Anyways, I got it all to fit just fine without having to get anything else, I took it for a test drive, nothing new, felt fine, no engine light or anything (not sure if I would even get such a warning) and everything seems to be ok. So either I did it just right, or tomorrow I may need a ride.
Old 10-29-2005, 04:04 PM   #8
Bundyboyz
Member#: 32764
2003 WRX with 91K
I disagree... MAF sensor reads how much air is comming in... no matter how hot the turbo is or how cold the intercooler is it's still the same amount of air... just because something gets cold doesn't mean there is more of it.
edit: the real question with bigger intercoolers and for front mounts... the extra pipping as well is pressure drop... I'll do some reading on pressure drop. I'd imagine you'd see less air richer conditions from pressure drop but only very very marginal.
I should be clear that I'm talking from a math perspective... then end user and even monitoring of these parameters would be very minimal.
Old 11-01-2005, 03:34 PM   #9
Bundyboyz
Member#: 32764
2003 WRX with 91K
bumpers... I'm curious if I'm right
Old 11-01-2005, 03:48 PM   #10
Butt Dyno
Street's closed, pizza boy
Member#: 17301
is the "dark side"
06 Evo #7 STU, 03 IS300
Slick: do you have gauges? Which ones?
Old 11-01-2005, 04:22 PM   #11
rogue
Super Moderator
Member#: 7977
100% Abuse
unless you're near maxing out the injectors, or the map you're running isn't planned for the increased flow, or a dozen other things...
it can happen.
Old 11-01-2005, 05:17 PM   #12
BigSlick
Member#: 79919
2014 STI Hatch
ButtDyno, no gauges, if you are talking about the boost gauge, oil, etc.. I do want a boost gauge just didn't feel like paying 300 from Subaru.
Old 11-01-2005, 10:04 PM   #13
CaptinMorgan97
Member#: 57634
2005 STI
Ill sell you mine all. You dont even have to change the dash part, well just swap it :-P.
And this time I can help with the install :P
CaptinMorgan97 is offline   Reply With Quote
WTT 05 wrx hoodscoop for STI hoodscoop vu-tang SCIC Private Classifieds 2 06-08-2010 12:25 AM
Routing for STi IC spray hose? WRXRgr Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 6 09-19-2005 05:07 AM
so cal: 05 wrx turbo and Sti Ic,vf22 P&P and more sil&duckswrx&legacy Private 'For Sale' Classifieds 56 03-21-2005 02:53 PM
Wiring for STI IC Sprayer Switch/Tank adeliciouspizza Electrical & Lighting 2 04-08-2004 04:24 PM
Anyone Know Part # for STI IC Spray Nozzles? WRX300 Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 2 07-01-2002 03:36 PM
