10-29-2005, 03:20 PM | #1 |
Member#: 84313
NWIC
Vehicle:04 Aspen STi |
really late boost with utec
i just went from a internally gated fp red turbo to a ext gated gt30r, and with the red i got 20psi at 4k and i only get 20psi by 5k+
the ewg dumps to atmosphere and i cant hear it open under 5k rpm, what could be going wrong? do i need to anything special because i am going external?
10-29-2005, 03:48 PM | #2 |
Member#: 21980
NESIC
Vehicle:2002 PSM WRX (Sold) 2017 BMW X5 |
Can you post us a log? More importantly has it been tuned and still exibiting this behavior?
11-02-2005, 12:38 AM | #3 |
Member#: 84313
NWIC
Code:
2616 -6.7 2.1 19 0 0 14.3 44.7 8.1 Ecu. 0 Ecu. 2 2647 -6.7 2.2 21 0 0 14.3 45.3 18.6 Ecu. 0 Ecu. 2.2 2670 -6.1 2.4 45 10 0 13.9 46.4 9.5 Ecu. 0 500 2.4 2666 -5.1 2.5 100 10 0 17.6 43.9 10.4 Ecu. 0 500 2.4 2773 -3.6 2.6 100 10 0 16.8 42.7 11 Ecu. 0 500 2.4 2841 -2.4 2.5 99 10 0 16.3 43 11.6 Ecu. 0 500 2.5 2913 -1.6 2.5 99 10 0 15.7 42.6 11.8 Ecu. 0 500 2.5 2955 -1.6 2.7 99 10 0 14.5 42.2 13.4 Ecu. 0 500 2.5 3044 -1.4 2.7 99 10 0 14.3 41.5 13.4 Ecu. 0 500 2.5 3168 -1.2 2.7 99 10 0 14.2 41.3 14.1 Ecu. 0 500 2.6 3205 -1 2.7 99 10 0 14 41.6 14.5 Ecu. 0 500 2.6 3277 -0.6 2.7 100 10 0 14 41.4 14.5 Ecu. 0 500 2.6 3373 -0.2 2.7 99 10 0 13.8 41.6 14.6 Ecu. 0 500 2.7 3457 0 2.8 99 10 0 13.6 41.5 16.2 Ecu. 0 500 2.7 3534 0.2 2.8 99 10 0 13.3 41.4 16.5 Ecu. 0 500 2.7 3615 0.4 2.9 99 10 0 13.1 41 16.9 Ecu. 0 500 2.7 3699 0.4 2.9 99 10 0 13.2 40.8 19.2 Ecu. 0 500 2.8 3800 0.6 3 99 10 0 13 40.3 19.8 Ecu. 0 500 2.8 3866 0.8 3 100 10 0 12.3 39.7 21 Ecu. 0 500 2.9 4006 1.3 3.1 100 10 0 12.2 39.4 22.4 Ecu. 0 500 3 4105 1.7 3.2 100 20 0 11.3 39.3 24.6 Ecu. -0.8 500 3 4177 2.1 3.1 99 20 0 11.3 39.2 25.8 Ecu. -1.4 500 3 4306 2.5 3.3 99 20 0 11.3 38.6 29.8 20 -1.5 500 3.1 4391 3.1 3.4 100 20 0 11 37.3 33.3 20 -1.5 500 3.2 4516 4.1 3.5 100 30 0 10.7 36.1 37.4 20 -2 440 3.3 4662 5.3 3.7 100 30 0 10.5 34.9 40.8 20 -2 440 3.4 4782 7 3.8 100 40 0 10.4 35.5 42.7 20 -3.7 440 3.4 4938 8 3.8 100 40 0 11 35.9 45.4 20 -3.7 440 3.5 5128 9 3.8 99 40 0 11.3 37 46.2 20 -3.4 440 3.5 5291 9.8 3.8 99 50 0 11.5 37.3 47.1 19 -4 440 3.5 5420 9.8 3.9 100 40 0 11.4 37.6 50.9 20.8 -2.7 440 3.6 5583 9.8 3.9 99 40 0 11 36 51.1 21 -2.3 440 3.6 5747 9.6 4 100 40 0 10.9 36.6 54.3 21 -2.3 440 3.6 5889 9.6 4 100 50 0 11.1 37.2 51.9 20.7 -3.5 440 3.6 6093 9.8 4 98 50 0 11.2 37.6 53.4 21.6 -3.5 440 3.7 6172 10.4 4 100 50 0 11.5 38.1 54.8 22.4 -3.5 440 3.7 6253 10 4 99 40 0 11.6 38.1 57.4 22.8 -2.3 440 3.8 6410 10 4 99 40 0 11.1 38.4 57.8 23.7 -2.3 440 3.7 6587 10 4 97 40 0 11.1 38.9 59.2 24 -2.3 440 3.7 6600 9.8 4 15 0 0 11.2 38.9 58.2 17 0 400 3.6 6082 5.5 3.3 0 0 0 13.1 45 16.4 17 0 Ecu. 1.8 |
11-02-2005, 12:41 AM | #4 |
Member#: 84313
NWIC
sorry i cant figure out how to get the code to line up right, what could be wrong?
11-02-2005, 01:24 AM | #5 |
Member#: 69343
South East
Vehicle:1998 TransAm cnvrtbl Black |
Next time you log in hyper-terminal, use 'shift-1' instead of just hitting '1' for the comma delimited text. Then copy from a text file into the code tags. It should line up a bit neater like:
Code:
3949, -9.2,1.8, 0, 00, 00, +40.3, 7.4,ECU. , -0.5,400.00,1.6, 12.67 3611, -9.7,1.9, 6, 00, 00, +40.5, 7.1,ECU. , -0.5,400.00,1.6, 12.78 3035,-10.3,2.4, 14, 00, 00, +43.0, 9.0,ECU. , -0.5,376.00,2.1, 14.65 3027, -8.8,2.5, 17, 00, 00, +46.2, 9.5,ECU. , -0.5,388.00,2.2, 17.62 3019, -7.2,2.6, 16, 00, 00, +46.3, 10.6,ECU. , -0.5,384.00,2.2, 16.80 3055, -5.9,2.5, 16, 00, 00, +46.4, 10.6,ECU. , -0.5,384.00,2.2, 14.61 3052, -4.9,2.6, 16, 00, 00, +46.2, 11.0,ECU. , -0.5,384.00,2.2, 13.39 3060, -4.7,2.5, 16, 00, 00, +46.1, 11.0,ECU. , -0.5,384.00,2.2, 12.92 3052, -4.5,2.6, 16, 00, 00, +46.2, 11.2,ECU. , -0.5,384.00,2.2, 12.92 3060, -4.5,2.6, 16, 00, 00, +46.2, 9.2,ECU. , -0.5,384.00,2.2, 13.09 3069, -4.3,2.5, 16, 00, 00, +46.1, 11.2,ECU. , -0.5,384.00,2.2, 13.36 3115, -4.3,2.6, 16, 00, 00, +46.3, 9.4,ECU. , -0.5,384.00,2.2, 13.47 3095, -4.3,2.6, 17, 00, 00, +46.2, 9.3,ECU. , -0.5,388.00,2.2, 13.42 3118, -4.3,2.6, 16, 00, 00, +46.2, 9.1,ECU. , -0.5,384.00,2.2, 13.56 |
11-02-2005, 01:31 AM | #6 |
Member#: 69343
South East
Might be a plumbing problem. What sort of boost control are you using? The boost numbers drop just before 5k. If that's when boost rises, perhaps the solenoid you are using is hooked up with a normally closed valve inline instead of a normally open... or something like that. Did you change the BC from a bleed-off style to an interrupt?
11-02-2005, 11:07 AM | #7 |
Member#: 84313
NWIC
its the perrin ebcs and i have hooked it up two different ways with no luck
also it loggd in excel |
Cheap (maybe) way to control high boost with UTEC inside | serendipity | Engine Management & Tuning | 40 | 10-03-2004 09:17 PM |
Low Boost with UTEC | Konvict | Alaskan Impreza Club Forum -- AKIC | 6 | 08-24-2004 12:33 PM |
low boost with UTEC | J_R_B | Engine Management & Tuning | 21 | 06-21-2004 11:51 AM |
Fluctuating Boost with UTEC or MBC | Brian Broz | Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) | 11 | 03-14-2004 11:36 AM |
Max boost with UTEC stage 1 and ABC fully closed | Rich10 | Engine Management & Tuning | 2 | 12-30-2002 10:53 AM |
