Old 10-29-2005, 09:18 PM   #1
SLIGHTLY
Member#: 47909
2004 PSM WRX Wagon
awd+corner, WEEEEEE!
Default Clifford cyber 2+ wireing help
well in my old car the allarm is haveing some problems with the starter kill, I think one of the internal relays is haveing issues so wanted to just bypass it any one have the wireing diagram for it handy?
SLIGHTLY is offline   Reply With Quote
Old 10-30-2005, 09:07 AM   #2
thedaddyb
Member#: 64374
07 WRX SWP *SOLD
03 2.5ts BRP long gone
you don't really need a wiring diagram to disable the starter kill.
(usually on dei alarms though, the starter kill wires will either be purple-green, black-black/white or green-green/white))
you will need to take your under dash down and find your ignition harness. you can trace it from the back of the key cylinder. look for larger gauge wires that are tapped in that harness. (usually 10 or 12 gauge) one of them will be cut. that is your starter wire. you will need to disconnect the alarm from that wire on both cut sides and then reconnect the wire together. either solder it or use a good crimp cap.
note: the factory starter wire will be a black/white wire.
thedaddyb is offline   Reply With Quote
Old 10-30-2005, 01:38 PM   #3
SLIGHTLY
Member#: 47909
2004 PSM WRX Wagon
yea its not a subaru and who ever did the allarm replaced good sized sections of the origional wireing thats left me baffled. But i will look for some of those wires.
Old 10-30-2005, 02:55 PM   #4
thedaddyb
Member#: 64374
07 WRX SWP *SOLD
what type of car is it? I have access to wiring diagrams to pretty much any car out there
also if you think the whole ignition harness was cut you can just test for the starter wire.
you will need a volt-meter (multimeter) to test for voltage. the starter wire will rest at ground (0 volts) unless the engine is cranking. so it will be ground, 12 volts while cranking, and then back to ground when the car is started.
Old 10-30-2005, 04:50 PM   #5
SLIGHTLY
Member#: 47909
2004 PSM WRX Wagon
its a 93mustang 5.0 dug out the install sheet for my intelegaurd 750 and was not matching. will take the mm and test wires.
Old 10-30-2005, 05:41 PM   #6
thedaddyb
Member#: 64374
07 WRX SWP *SOLD
your starter wire from the factory should be either. red/blue or white/pink
at least if it is still the factory wiring.
wiring up a link plus to a 98 2.5RS, wiring help (pinout included) Keith Engine Management & Tuning 7 08-31-2005 02:04 PM
Clifford / DEI Cyber 2 alarm with battery backed siren wcbjr Electrical & Lighting 0 09-16-2004 05:18 PM
Clifford Matrix 2.5X alarm, need advice wheresmycar Car Audio, Video & Security 2 07-26-2004 08:01 AM
Can I splice my Clifford alarm LED wires to run a second LED? ImportVenom Car Audio, Video & Security 5 08-23-2003 11:32 AM
what 2 wires for the turbo timer & security system? installing now...need help! wrx182 Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 6 10-21-2001 05:17 PM
