Old 10-30-2005, 01:38 AM   #1
ncskier96
Member#: 97598
1997 OUTBACK SPORT
blue over gray
Default ej20TT swap question
Ok i know there are a few post on this issue saying to stay away from the ej20TT for LHD cars, how ever i'm thinking of building an engine to swap into a free 92 legacy loyal. I got the car just for learning purposes, tear it down to learn as much as i can about cars, like the pumbing, electrical, as much as possible.
Back to my question I want to take a ej20tt take the left turbo off and change the exhaust manifolds, would it work? also the engine i'm planning on getting has a cut wiring harness, what would be the easiest way to get one.
my plans for the car are to keep only the block, heads, and turbo stock, i want around 325 awhp, with a complete suspension, drivetrain ,brakes
ncskier96 is offline   Reply With Quote
Old 10-30-2005, 01:45 AM   #2
subbyspeed
Member#: 16274
2001 GM6 2.0L vf30
e30 black/rust
stock turbo won't get you 325awhp.. I've seen guys getting around 300 on a td04 (usdm wrx) but thats stressing the hell out of that poor thing.
I'd say you'd be getting into a nightmare if you try the twin turbo option and then trying to make it single turbo and doing whatever else. Especially if you are only getting a cut harness.. eeeek.
subbyspeed is offline   Reply With Quote
Old 10-30-2005, 10:31 AM   #3
jimbobrand
Member#: 21935
2010 '13 BRZ Premium
WR Blue Pearl
You can usually get JDM EJ20G motors that were pulled from old legacy's cheaper than the twin turbo motors (and they already have a single turbo). There is even a full legacy front clip on ebay for $1650 here.
-Jim
jimbobrand is offline   Reply With Quote
Old 10-30-2005, 11:01 AM   #4
ejsportcom
Member#: 88905
if you get a TT version and take off the headers, i want them. i've been looking for a set for a while now. so even if you can tell me where you found them it would be appreciated.
ejsportcom is offline   Reply With Quote
Old 10-30-2005, 12:23 PM   #5
99WRXEJ20
Member#: 34545
1999 GC8
74f
Talk to supermoose!
I just bought the long block so he might have some lying around.
99WRXEJ20 is offline   Reply With Quote
Old 10-31-2005, 10:30 AM   #6
jkjersey
Member#: 8399
GC8 JDM STI V swap
cardinal red
Ok I have a question for a impreza conversion. Can a EJ20TT long block be converted to work with a single turbo. Essentially when you strip it down is the shortblock the same as a EJ20T? Is there any fitment issues with the power steering pump ... could my power steering pump just bolt onto the block?
jkjersey is offline   Reply With Quote
Old 10-31-2005, 12:45 PM   #7
99WRXEJ20
Member#: 34545
1999 GC8
74f
Well, I hope so cause supermoose just sold me one and says he has one in his car and he converted everything no problem. From what I understand for the research I have done the motor is an Ej20H It has 9:1 cr. It also has same valves and head ports as STi-RA, and 264 cams. valvetrain is mechanincal shim UNDER bucket - good to 8K no problem. Hopefully he will chime in and give some more information.
Old 11-02-2005, 12:31 AM   #8
supermoose
Visiting NASIOC Timeout
Member#: 9093
1995 RHD STi RA Ver2
swap starr
your powersteering and acessories brackets will swap over. how do i know? its in my car.
all ej is smae casting, so:
ej25 dohc with ej18 ps pump / lines / alternator / ac compression - check. ive done it
ej20H longblock with EJ20G all accessories, brackets - check. ive done it
ej18 sohc with EJ20 sti-ra timing belt tensioner, waterpump, pulleys, sprokets - check. ive done it
EJ207 with EJ25 ac compressior for 99 usa RS - check. ive done it
etc etc etc.
how good is the EJ20H 9:1 longblock you ask?
stock EJ20G turbo setup conversion with Stock EJ20G ecu. 4:1 grupp-s headers, and ebay turbo back exhaust. walked a 996 twin turbo sunday afternoon. stock boost at 1 bar.
pretty good eh?
i have pictures of shim under bucket, lemme find and link them
supermoose is offline   Reply With Quote
Old 11-02-2005, 12:32 AM   #9
THAWA
Member#: 44581
3 Boxers 2 AWD
3 turbo 1 6cyl & a 13BT
What's a 92 Legacy Loyal?
THAWA is offline   Reply With Quote
Old 11-02-2005, 12:49 AM   #10
supermoose
Member#: 9093
swap starr
no idea man. i hart EJ20h
a little help please....ej20tt swap question tiger20002 Subaru Conversions 12 11-14-2009 12:25 AM
EJ20TT swap into a 97 Legacy GT, would it have the same difficulty as swapping in RS Deucalion Legacy Forum 2 11-09-2009 03:25 AM
ej20tt engine swap question tiger20002 Normally Aspirated Powertrain 1 10-23-2009 09:24 AM
ej20tt motor swap questions marc l Subaru Conversions 6 04-19-2007 04:39 PM
EJ20TT swap question AKSubie Legacy Forum 13 07-10-2002 11:07 PM
