Old 10-30-2005, 01:11 AM   #1
iluvdrt
Member#: 46248
82 Brat
Tan
Default EA82T code 11 crank angle sensor help please!!!
I have a question regarding a 87 GL10 with a EA82T.
A while ago it quit making spark. I changed out the dizzy, coil, and ignition amplifier only to achieve nothing. Today I checked the codes on the ecm and it shower code 11 (no referance pulse from the crank angle sensor). I proceded to follow the steps to find my problem in the FSM's. It said I needed a harness. I pulled the entire chassis harness out today and checked every wire with a multimeter. It is ok.
Here is what I have with the key "on"
12 volts going to ECM, Dizzy, and coil. (plug 7 on ECM)
ground has continuity across harness, but not to chassis(possible problem(plug 20))
4 volts on plug 8
and the other 4th wire it said I didnt have to check, but I did anyhow and have continuity.
So what I am thinking is the plug going to the dizzy(crank angle sensor) has a bad connector. I am planning to wire in my own connectors there, and also make a new ground for terminal 20 on the ecm (black wire with a red stripe). That should provide a good connection and a positve ground for everything on that circut.
thanks for any insight. I am stumpped.
iluvdrt is offline   Reply With Quote
Old 10-31-2005, 08:49 AM   #2
Legacy777
Member#: 4800
1990 Legacy & 97 OBS
AWD 6MT EJ22T AWIC Swap
You may want to try the old school subaru forum towards the bottom, or try the USMB
www.ultimatesubaru.net/forum
Legacy777 is offline   Reply With Quote
Old 10-31-2005, 04:26 PM   #3
iluvdrt
Member#: 46248
82 Brat
Tan
Thanks, but I am a member of the USMB. Might as well post there too I suppose.
Old 11-01-2005, 07:01 PM   #4
JWX
Member#: 28990
ya cause these guys see these cars everyday
JWX is offline   Reply With Quote
Old 11-02-2005, 05:25 PM   #5
iluvdrt
Member#: 46248
82 Brat
Tan
It says pre 2002 turbo. Mine is a pre 2002 turbo is it not? I get your drift.
crank/cam sensor HELP PLEASE 199subaru Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 7 09-15-2008 04:59 AM
WTB: MAF sensor and crank angle sensor CMJ Private 'Wanted' Classifieds 2 04-06-2005 01:16 AM
Crank Angle Sensor and Cam sensor DonkeyPunch Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 6 04-02-2005 09:59 PM
Part number - crank angle sensor danci1973 Legacy Forum 2 10-22-2002 03:04 AM
Code 11 - Crank Angle Sensor danci1973 Normally Aspirated Powertrain 0 07-18-2002 06:05 PM
