Old 10-30-2005, 02:02 AM   #1
rally_on
Member#: 86849
2005 GMC Savana
white
Default Turbo it?
alright this is not the same thread as all the other ones. im not just wondering, im actually in the situation... my friend just totalled his WRX and is parting out a lot of parts to our group of suby friends. he wants to see me turbo my car, so he said he would sell the turbo, intercooler, and most of the other things i would need, i know next to nothing about turbos... if i went threw with it, it would be in 2 or 3 years, but i would buy the stuff now because its the only time i could buy the stuff for the project this cheap. (i dont know exact prices right now) is this a good idea? would i have a lot of problems? suggestions? ideas?
Thanks,
Greg
rally_on is offline   Reply With Quote
Old 10-30-2005, 02:03 AM   #2
rally_on
Member#: 86849
2005 GMC Savana
white
BTW what all would i need besides the turbo and intercooler?
Old 10-30-2005, 02:08 AM   #3
99subi
Member#: 78118
2002 Corvette coupe
05 Legacy
99subi is offline   Reply With Quote
Old 10-30-2005, 02:18 AM   #4
rally_on
Member#: 86849
2005 GMC Savana
white
Old 10-30-2005, 11:34 AM   #5
El_Kameleon_G
Member#: 87103
2005 Impreza RS RWD
Plat'num Plus...SOLD!
fuel pump
fuel pressure regulator
engine management-if you wan't it to last
up/down pipes. they sell some that fit the RS manifold
actuator spring-so you don't make so much boost
I don't know much else, but you can go to RS25.com to find everything you need in detail. Ty searching the forums there, because almost everything has been covered. Let me know if this helps.
El_Kameleon_G is offline   Reply With Quote
Old 10-30-2005, 12:35 PM   #6
rally_on
Member#: 86849
2005 GMC Savana
white
thanks. anyone else have any suggestions?
Old 10-30-2005, 02:40 PM   #7
saar
Member#: 43770
2013 Impreza WRX Lim
2001 Impreza WRX STi
It will Save alot of potential stress and effort, if you just pull his complete motor and swap it whole...its a very do-able swap... you can find many threads and walkthroughs to help with the swap...
if you want to go turbo...put in the turbo motor...
saar is offline   Reply With Quote
Old 10-30-2005, 11:40 PM   #8
99subi
Member#: 78118
2002 Corvette coupe
05 Legacy
Originally Posted by rally_on
yea, there is a lot more than that included in the sale (im not that stupid but thanks for assuming that). i just wanted a full list. and thanks for laughing at me a$$hole
wow whats your problem
Old 10-30-2005, 11:49 PM   #9
t3hWIT
Member#: 58779
95 STi RA (rhd)
98 Tacoma (300k Club)
hey noob, shut your piehole. i had a bit of advice for yah, but upon seeing this all I have to say to you is to watch yourself or you won't last long on here
t3hWIT is offline   Reply With Quote
Old 10-31-2005, 12:09 AM   #10
Handsdown
Member#: 29355
you posted something about turbocharging in a normally aspirated forum... then you get pissed someone called you stupid?
you need to check yourself before you wreck yourself, kid. when mi_system and i agree on something, you KNOW you need to pay attention to it.
Handsdown is offline   Reply With Quote
Old 10-31-2005, 02:22 AM   #11
rally_on
Member#: 86849
2005 GMC Savana
white
wow. that was out of line and rude on my part. i hope you guys can accept my apology. i had a bad night... once again sorry.
Old 10-31-2005, 03:21 AM   #12
Sko
Member#: 90396
2005 Legacy 2.5i
Brilliant Silver Metallic
Ok, back to the question at hand, what all will you need to turbo your RS... Well if your friend intends to make any money on this part out of his, he should be selling the motor and tranny and all that complete, unless the motor dont work. If he for some reason not selling it complete you will need lots of various parts etc. there are lots of lists in lots of places, but to really make it easy on yourself, just buy a complete used kit from someone on these forums, 1.5-2k and you'll have everything you need.
FYI if you do still try and do a conversion somehow understand that ALOT of parts from that rex will need to be modded and you might as well get different parts that already work like... the intercooler won't fit w/ out modification... the this, the that. Especialy if you know nothing about turbos, you should really be reading and reading and reading!
Some links:
http://auto.howstuffworks.com/turbo.htm - Read if you don't know anything about turbos...
http://www.rs25.com/forums/forumdisplay.php?f=7 - Read the 1st post "Official turbo..."
http://forums.nasioc.com/forums/showthread.php?t=185230 - Read em all.
And after all have been read and understood, you may then ask questions. ^_^
Good Luck,
Nick
PS- might want to look into swaps as well, just so you can compare the costs of turbocharging your car, and swapping a wrx/sti engine into your car.
PPS- ALSO, your going to need to put in a new clutch, yours will be no good. Go easy on your transmission and you won't have to replace your transmission. And get a new cat-back exhaust system.
Sko is offline   Reply With Quote
Old 10-31-2005, 07:02 AM   #13
munkis
Member#: 1847
Team Broken: V6 GF
rallyarmor.com
the first edit was free, keep it civil
Old 10-31-2005, 07:30 AM   #14
t3hWIT
Member#: 58779
95 STi RA (rhd)
Understood. One thing youre forgetting is a turbo crossmember, for routing of the exhaust, and while I know the turbo front antisway wont work on NA cars, I'm not sure if the NA front antisway will fit a turbo conversion.
Old 10-31-2005, 07:56 AM   #15
WallyKincaid
Member#: 90566
1999 Legacy 2.5 GT
I want JDM WRX!
On a 2.5 liter if he runs low psi does he really need to change out his stock clutch? If hes only getting say, 25 HP from it should he be ok? I thought the stock clutchesare good to around 200HP. (I drive Legacy, think its the same as 2.5RS).
WallyKincaid is offline   Reply With Quote
Old 10-31-2005, 08:35 AM   #16
Handsdown
Member#: 29355
"with any large increase in power you need a stronger clutch"
if he's only getting 25hp out of it(3-4 psi perhaps?) then he *might* be okay... but you don't want to notice some clutch slippage and have no money left over in order to fix it when it becomes a problem.
that said, yes if it's a small increase in torque then you might be able to get away with the stock clutch. and since he's not thinking of doing any internal work or anything the "while you're in there..." mentality isn't really applicable.
Old 10-31-2005, 10:09 AM   #17
Sko
Member#: 90396
2005 Legacy 2.5i
Well I'm going to be running 7 psi, and that will push me up at least 100 hp... so yea... I think he will need a new clutch.
Old 10-31-2005, 04:21 PM   #18
leondal
Member#: 43114
1998 Legacy GT Turbo
Green
I don't know, are you going to drag race this thing?
If so, then yes. Otherwise, I would suggest buying
one of those +25% clutches with the stock pressure
plate for $100.
You can get one at SPO Motorsports
http://www.spomotorsports.com
If you're not dropping the clutch at 6000 rpms, then
even a new stock clutch will hold up for a long time
(3 years so far, here).
leondal is offline   Reply With Quote
Old 10-31-2005, 04:21 PM   #19
leondal
Member#: 43114
Green
And that's running 7-8 psi, for 3 years.
Old 10-31-2005, 06:56 PM   #20
Sko
Member#: 90396
2005 Legacy 2.5i
What is your turbo setup and estimated hp?
Old 10-31-2005, 07:04 PM   #21
99subi
Member#: 78118
2002 Corvette coupe
05 Legacy
sorry bro
Old 10-31-2005, 08:36 PM   #22
Sko
Member#: 90396
2005 Legacy 2.5i
OMG, how dare you TAUNT him w/ the powers of the dancing banana!!! Absurd!!
lol, j/k guys.
Old 10-31-2005, 11:35 PM   #23
Kawikid20o2
Member#: 86291
'97 LegaSTi-2.5XTR
'96 BrightonCoupeWRX-SR30
If he gets the up pipe that is made for retaining the stock exhaust manifold then he doesn't need the turbo X member. You would need to tap the oil pressure sensor with a banjo fitting and get some good oil lined that you can trust not to leak. Get the coolant resevoir from his car and tap the heater hoses to supply it with coolant
But the clutch is a good idea considering the wastegate spring cannot be changed so it shoud be making 7psi about if there are no real bad leaks. so figure an increase of about 100hp at the crank, you will probably fry that stock clutch if you drive it hard. Of course you are going to romp on it, otherwise you wouldnt be turboing. If you want it to last you will buy an emanage or a perfect power to pull timing.
Kawikid20o2 is offline   Reply With Quote
FS : St. Louis 2005 STI longblock, good compression. Just got pulled need it gone!!! deuce189 Engine/Power/Exhaust 10 06-05-2010 03:33 PM
metal resiover for turbo it is on ebay 12hrs left on auction jeremywrx15554 Engine/Power/Exhaust 7 10-20-2009 03:48 AM
2004 sti, need to tell what turbo it is *pics* xrocket21 Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 37 03-20-2009 10:56 PM
Turbo it??? rally_on Subaru Conversions 2 11-01-2005 11:20 PM
should i turbo it? marioej18 Normally Aspirated with bolt-on Forced Induction Powertrain 1 12-22-2002 10:00 PM
